New pc build. crashes randomly shortly into bios screen
  • 341 Answers
Can you describe your hardware (brand names a part numbers of the hardware and speed)Do you here beeps at the post. Here is something you can try. Remove the motherboard with the processor, memory and video card if you have an external one left in place and connect the power supply.Make sure all your power connectors are in where they need to be. Somtimes there are as many as four connectors from the power supply to the motherboard.Make sure everything is indexed and seated properly. See if it works up to the no operating ayatem error. If not use only one memory stick and try that. Still nothing try one of your other memory sticks only if you have more than one.If nothing and you have a onboard video card enable it in the bois and remove the external one and try that. It micht get you going. A common problem with new setups is a standoff connector that mounts your motherboard to the case is in an unused position and shorts the board at that spot.
Posted on Nov 30, 2008
Dv7 230m laptop blue screens randomly, more often during gaming.
I had similar issue recently and had to replace my video/audio card. I think yours is frying up!
Jan 02, 2013 | Computers & Internet
My computer keeps shutting down randomly. Also when i try to use F10 it will not respond if i try and run error checking the system will crash/shut down or give me a black screen. Basicly it randomly...
1. overheating, and automatic shutdown.
Check that the fans are working.
2. bad RAM, causing "random" crashing.
On a "good" computer, download the free 'MEMTEST86+' software, and run it, to test your RAM.
3. Leaking capacitors on motherboard, causing "voltage-spikes", leading to "random" errors.
4. Bad disk-drive. Remove the disk-drive.
Connect it as a "slave" drive in another computer,
and run 'CHKDSK' ("Check Disk") to look for problems.
Apr 16, 2010 | HP Pavilion a450n PC Desktop
I have a fujitsu laptop with bios crashed
Insert A new Operating System in it (window) For that yu will have to buy a CD
Aug 27, 2009 | Computers & Internet
Ive recently upgraded my BIOS on my Compaq Presario SR2050X Media center PC. ever since then i have been getting nothing but blue screen errors and random crash/restarts whenever i play a game, watch a...
check if you bios built in video is enable and try to disable that and use your video card, if you are running in built in video card then increase the size of the video memory
Jun 09, 2009 | HP Compaq Presario SR2050NX PC Desktop
Fatal1ty FP-IN9 SLI + Q9400 + BIOS16 = wrong CPU temp + noisy fan
I notice that the solution from myself was posted as a comment. This may prevent some from locating it. I reposted as a solution under a different name. Hopefully it would help those have the similar problem.
In addition to the following solution, you may also set the CPU core voltage to your CPU specification. My Q9400 VCore specification is 0.85~1.3625V. The BIOS auto setting sets it at 1.1625V. I just manually set it to 1.3625. CPUZ shows that C1E and stepping will lower it as necessary. It should provide the CPU more juice when it needs it, while keeps it cool when it is idle.
Ok, this is myself (Recnelis). I may find the solution for this problem. The trick is to use the beta BIOS 18 and increase the "CPU VTT Voltage" in the BIOS "SoftMenu Setup".
The beta BIOS 18 could be found here:
To make the long story short, BIOS 16 is relatively stable for Q9400 but could not recognize the CPU correctly. BIOS 18 (beta) can recognize the CPU correctly but is very unstable - random application crashes, blue screen, freeze, etc.
Here is some "history" about the issue. Fatal1ty FP-in9 SLI uses nVidia 650i SLI. If you google "nVidia 650i 45nm quad core", you will find a lot of people has the similar issue. Many websites suggest that it is because of the difference between the release version of the Intel 45nm quad core and the one sent to nVidia for testing (due to that nVidia turned off Intel's request for acquiring its SLI technology according to some rumors). Some forums suggest voltage is among those differences.
In the BIOS, you may notice that the voltage settings in the "SoftMenu Setup" are different from the actual voltages in the "PC Health Status". In my case, the actual voltages are similar but lower than the settings. One exception is the "CPU VTT Voltage". The BIOS automatically set it at 1.2V, while the actual voltage in the "PC Health Status" shows it is only a little above 1.0V. That is more than 16% drop. 1.0V is too low to keep the system stable. Guys in o/c world usualy increase the "CPU VTT Voltage" up to 1.5V to keep the system stable. Since I'm not o/c'ing my system, I do not go that far. For my particular case, when I set it to 1.31V in the "SoftMenu Setup", the actual voltage in the "PC Health Status" is 1.2V, which is what the auto setting trys to do. For your system, you may want to increase the setting one notch at a time to safely increase the actual voltage reading.
Before this tweak, my system cannot even run more than 30 minutes under BIOS 18. After this small tweak (under BIOS 18), my system becomes a whole lot more stable (no crash so far after a few days of using). It passed RealTemp torture test (using Prim95) many many times without a single hiccup. I tried to post this at least one week after the system runs in stable status; but I think some of you may still be searching for the solution.
More good news for those who want to keep the Fatal1ty IN-FP9 SLI/Q9400 for a while: I even installed Windows 7 RC (build 7100) with the new nVidia Windows 7 mobo driver and graphic driver. Everything is running smoothly so far.
Good luck to your tweaking.
Apr 02, 2009 | Abit Fatal1ty FP-IN9 SLI Motherboard
Geforce 8500 GT Causes "Snowy" screen
You have Vista 64 bit right? I looked and the newest nvidia driver is 182.08 located here:
1. Download this driver.
2. Go to the Control Panel, Programs and uninstall the current nvidia driver.
3. Shut down computer.
4. Remove video card and re-install it.
5. Start computer and install new nvidia driver.
Mar 11, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Memory Errors
Download the latest stinger and runn it it mite be a welchi virus or download a bios update
Nov 04, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
