Question about Microsoft Xbox 360 Console
It will start reading then it stops - Microsoft Xbox 360 Console
    Top Expert:
  • 4,961 Answers
Clean the disc and clean the laser lens in the Xbox with a laser lens cleaning kit.
http://www.gamestop.com/xbox-360/accessories/xbox-360-cleandr-laser-lens-cleaner/93068
Good Luck!
Posted on Jun 11, 2012
SOURCE:
Having problems with stop start button
have the OBD codes read as will pinpoint the problem saving you time and money
May 01, 2014 | 2005 Renault Megane
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
Key fobe button for remote start doesn't always work, even with new batteries.
I had this problem. I read the manual and it states that if you remote start your car and then remote-stop the ignition twice, you must place the key in the ignition and start the vehicle once to reset it. I think it is to keep children (or anyone else) from playing with the key fob and playing the start-stop-start-stop-start-stop game! Hope this helped!
Jan 21, 2011 | 2008 Dodge Grand Caravan
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
I have a compaq presario v 2000 i up graded to vista 32 bit now it doesnt play sound. when i went to the hp site and downloaded the driver it said device not detected
1.At first you need to click on Start and in start search type Services.msc and then hit enter.
2.This would take us to the Service Manager Window.
3.Try locating a service which reads as Windows Audio.
4.Right click on Windows Audio and then click on properties.
5.There would be a Tab which reads as STOP as well as START.
6.If the service is already started then STOP tab would be highlighted.
7.We need to click on STOP and then again click on START.
8.Now right at the middle of the page there would be an option which reads as START UP Type.
9.There would be a drop down below it.
10.We need to check that the start up type should be Automatic.
11.Select Automatic and then click on APPLY and OK right at the bottom.
12.Restart the computer and then try installing the driver from HP's Website.
Hope it Works..
Regards
Ken
May 12, 2010 | HP Compaq Presario V2000 Notebook
97 Olds Achieva starts, then dies, gages crazy,then stop working
Brakes don't work when I try to stop while making a right turn.
Mar 04, 2010 | 1997 Oldsmobile Achieva
My xbox 360 only pays old games(like pgr3) and not new games(like need for speed shift)
The laser in your XBox 360 is probably going out. When lasers start to fail, the first discs that stop reading are newer, dual layer, discs. Single layer discs will still read. As the laser wears out, single layer DVDs will stop reading but CDs will continue to read. Eventually, everything will stop reading and the laser will die.
You can find lasers for the XBox 360 all over the internet. Installing them isn't easy though.
Oct 03, 2009 | Microsoft Xbox 360 Console
Ps2 disk read error
THE LASER LENS AND OR HUB SURFACE is dirty
Dec 05, 2008 | Sony PlayStation 2 (PS2) Console
TURNTABLE
my audiobox, RS2663 displays "read" in the window and the cd won't come on,,,,,,,it continues to flash read......what am I doing wrong, or how do I fix this...A.Hahn
Apr 12, 2008 | Audio Players & Recorders
Microsoft Xbox 360 Console Logo
83 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
