Question about Acer Aspire™ T180 PC Desktop
Hello & Thanks for the help trying to restore Acer Aspire T180
I wiped out my Acer Aspire T180 , bought the system and recovery disc from Acer but after loading them it starts to load windows vista little bar goes across with the green in it then the vista backround then a box will pop up saying , there was an unexplained error and windows restarted unexpectedly so you need to restart windows now but then get the same box all over again. HELP !!!!!!!!!!!!
  • 2 more comments
  • dj07 Nov 30, 2008
    The exact box " the computer restarted unexpectedly or encountered an unexplained error Windows installation cannot proceed . To install Windows , click "OK" to restart the computer. And then restart thr Installation. " this is the same box every time even with the Acer System and Acer recovery disc's at work
  • dj07 Nov 30, 2008
    posted by dj07 on Nov 30, 2008
    Comment posted on Nov 30, 2008
  • dj07 Nov 30, 2008
    running a hard drive surface scan
  • dj07 Nov 30, 2008
    Coolguy2008 did you read the post at all ?
    Novelist:
  • 167 Answers
It sounds like there is something wrong with your disc or your DVD drive.
  • Clean the Disc and check for scatches
  • Run a DVD lens cleaner in the drive
I have seen a DVD drive stop functioning in a similar case... Replaced the drive and continued with no problems.
Posted on Nov 30, 2008
    Sergeant:
  • 237 Answers
You also need to format your hard drive.
This part is important: do NOT run the Windows installation from Windows itself. Shut down first, and then boot up the machine from CD. My Dell has a little message as it's booting up that says "Press F12 to boot from CD," so that's what I did. If you're not sure how to boot from CD, check your PC's user guide for more info.
The reason why booting from CD is important is because we're going to delete the C: drive partition where Windows is installed and re-format it. You can't do this if Windows booted from C:, because it can't delete the partition from which it is running.
  • Acer Master
  • 4,806 Answers
How many times has this happened?
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Nov 30, 2008
    its not the hard drive because you would have got a blue screen, telling you there is a harware issue.
    I am a PC technician and every time i come accross this message it is usually the install disk itself which is corrupt and unreadable..
    Try cleaning the disk and look at the reflective side for "spots"
    also clean thye lens of the optical drive
    kind regards
  • Lee Hodgson
    its obvious that sybabe didn't read the post properly either because you know how to boot from CD and you are performing a surface scan, lol
  • Lee Hodgson
    If you have anymore problems dj07 please post back
    regards
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it would be suggested to remove the hard disk from the Acer Aspire T180, connect it to another PC with the use of a SATA/IDE to USB adapter. you can then re-partition, format and run disk utilities on it. This would then determine if the HD is fully functional and would be usable in installing Vista. If the HD also fails while hooked to the 2nd PC, then perhaps a replacement is in order.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Scholar:
  • 126 Answers
It sounds like your hard drive has bad sectors and is not allowing the installation of the OS. I recommend replacing the hard drive. If you want the PC back up this is the quickest solution.
  • 734 Answers
There is sum partition error in your HDD.
  • futureloginn
    futureloginn Nov 30, 2008
    recreate the partion of yor HDD that will sure Fix your problem.
    i have same problem with Compaq PC.....
    Thanks
  • futureloginn
    yes, as i say that please recreate your partion of HDD and Fix your problem....
    Genius:
  • 3,422 Answers
HI,
Your windows has crashed and you will have to reinstall windows.
  • Priya darshan Nov 30, 2008
    To install windows.Insert the disc and then restart your PC.IT should then say "Press any key to boot from CD or DVD"
    Just hit any key say Enter.Then follow the onscreen instructions to install the win Vista.
Acer aspire t180 restore to factory settings on start up
You will need to use the recovery discs that came with the computer and boot from the disc and it will give you the option to restore to factory defaults. If you dont have the discs you will need to contact Acer to get a copy.
Jun 11, 2012 | Acer Aspire™ T180 PC Desktop
I tried to restore my Acer T180 and installed my restore disk. Unfortunately, they were the wrong disks. They were from my eMachine. They worked but now I can't register my Windows operating system. If...
Yes, when you use the actual discs that came with the computer you computer will be restored to normal. These Operating systems are called BIOS locked CDs, if they detect the right brand BIOS / motherboard they will install the OEM edition of the OS, hence you need not activate it or it will get activated properly.
Dec 22, 2010 | Acer Aspire™ T180 PC Desktop
Acer aspire T180 UB72... looking to bring data D disc into use as data is almost full..need help to do so!
Acer Aspire computer has a recovery partition so called D drive. I am sorry to say that you will not be able to access this drive.
But you can try this, open D drive and go to My Documents or Documents and then try to save any file. Hope this should take care of the issue
Thanks and regards,
Jitha
Nov 23, 2010 | Acer Aspire T180 PC Desktop
Need to reset my acer computer to factory settings.
Hi! Try system restore first and check if that will remove the virus but if not then you can reset the machine to factory defaults by pressing ALT+F10 during start up or when the acer logo appears on your screen.Follow the prompts and you should be able to reset the computer to factory image.Make sure you back up important files because it will wipe the system clean.hope this helps...
May 29, 2010 | Acer Aspire™ T180 PC Desktop
Need 2 restore
http://en.kioskea.net/faq/2040-acer-pc-restore-to-factory-settings
May 14, 2010 | Acer Aspire™ T180 PC Desktop
WILL not resetting to factory settings
You will need to burn a Recovery CD / DVD set from the icon located on the desktop/ In your Acer Home Start utility (The window loading at startup) or from the Start Menu.
Using this disk you will be able to do a System Restore back to original factory setup.
Apr 14, 2009 | Acer Aspire T180 PC Desktop
Acer t180 restore
A restore- from start to finish- should take 1 1/2 to 2 hours as a general rule of thumb. However, you should be seeing some activity in that time frame. If it is sitting on the same screen for even a half hour, restart the process.
Just as a question, what are you trying to fix that you think you should wipe out the whole thing and start over? Maybe we can help.
Feb 15, 2009 | Acer Aspire™ T180 PC Desktop
How do i fix my acer windows vista computer
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire T180 PC Desktop fails to boot
You can use ERD commander to boot the system, backup your files to any other partition except first partition.
I am sure you have software related problem.
May 08, 2008 | Acer Aspire™ T180 PC Desktop
How do you reset Acer Aspire T180-GB7Z PC
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
recover.
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Dec 30, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
