Question about Whirlpool Washing Machines
Whirlpool mod#LLR6144AQO electrical issue
While checking for a leak with the front of my top load LLR6144AQO whirlpool washer I intentionaly stoped the machine during the cycle to check for leaks and it never would start again. I have replaced the capacitor but continues to give nothing. What would an electrical trouble shooting sequence be? Is there a reset on this unit?
Thanks for your help
Russ
  • 1 more comment
  • idaho777 Nov 30, 2008
    No, nothing at all happens when pulling out the start knob.
    Cheers, Russ
    Yes, I have power to the circuit board/timer and with it in the on position I checked the switch at the motor and did not get anything. Is there a specific way to check the timer before spending the $ ?
    Thank you again for all the help
    Russ
  • JEFF SIEGEL May 11, 2010
    No reset. Does machine even fill?
    Sergeant:
    Champion:
  • 311 Answers
If you have power at the console where the power cord connector connects to the harness then make sure all wire harness connections to the timer are tight. If so, then something must have happened to the timer as nothing else will keep the machine dead in fill and spin.
Posted on Nov 30, 2008
Water is leaking onto the floor underneath my Whirlpool Cabrio (top-loading).
If its a small intermittent leak from the front left corner its the tub ring, whirlpool has redesigned the tub ring to fix this concern..
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Wash macahine keeps stoping in the middle of a cyle with an F1 code & I don't have the manual
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 fault is flashing and machine is stoping
Code F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed
Widespread problem, lots of machines have had this issue. I think there is a recall on this machine. Check it out-
Whirlpool Cust Svc. 1-866-698-2538 Have the model & serial off the back handy
Dec 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer spinning irregular.
your counter balance spring has broken off..onthjob
Jan 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Grinding noise when washer starts some spin cycles, washer stoped and game my wife a f-33 reading. whirlpool told me to unplug(reset) the washer for 30 mins. i did this and the washer still has the...
hi there,
the grinding noise may be coming from either the pump or you have something caught between the drums.
the f-33 error is the pump drive system error. it indicates that you have lost communication between the CCU board and the pump. the CCU board is the main control board that you see in the front of your washer.
i would recommend that you call a technician to check it out, as you will have to do some checks that require technical knowledge.
Oct 11, 2008 | Whirlpool Washing Machines
WhirlPool Front Load Washer Leaking
to richhardh..
did u try holding the "End of Cycle Signal" button for 3 ?
May 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine
If this is a front loading machine, take the plug off the wall. Remove the screws of the panel behind take off the panel; check to see whether any hoses hav come loose, tighten, refit.
Sep 11, 2007 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
132 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
