Question about Philips Magnavox MS2530C 25" TV
Magnavox 27MS4504 clicks, then dies
Hello--
I'm hoping someone can help me out.
I have a 27" Magnavox TV. The TV powers on--green light is on, but I see a snowy picture and vertical lines, followed by three clicks and the image folding in and disappearing then nothing. The green light does stay on though, but the TV does not show an image. I just had cable installed today--it was hooked in directly to the TV and when attempting to change it to hook it in through the DVD player this happened. I disconnected the TV from the cable box and put it directly to the electrical outlet to no avail.
Any ideas on what the problem might be?? I called Magnavox tech support and they weren't much help. I can't access the menu while it does turn.
Any ideas on how to fix this? Is it worthwhile fixing. It was about $200. I bought this TV about 3 years ago.
Thanks!
Cecilia
  • 121 Answers
As always ck for bad connections. slap side lift sid drop  otherwise not worth repair.
Posted on Nov 30, 2008
My magnavox tv model num 50mf231d137 will not turn on it turns on then turns off with red light blinking
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information google.com/+GopakumarGopalan
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
Tv works fine until you turn it off, when you turn it back on the green light shuts off and the tv totally dies, the red light thats on when its turned off is not working either. Now if you unplug it for...
check all caps in the power supply especially the 10mf 22vols cap.the caps are not filtering the voltage properly when the the current i off the caps drain the voltage and does not keep charging.until when current is applied to the set.good luck.
Feb 21, 2010 | Philips Magnavox 27MS343S 27" TV
Does a magnavox model 27ms4504/17 have a digital tuner? Manufactured September 2005
Hi, Sorry it does not. It has an NTSC tuner which is analog. It will work after the change if you have cable or satellite. Hope this helps!
Feb 05, 2009 | Philips Magnavox 27MS343S 27" TV
Tv will not turn on
A: Is there a humming sound coming from the TV set?
Check the brightness/contrast. If nothing still, remove power to the set for 24 hrs. and reconnect and retry. If it's not coming back up, the PCB ("motherboard") for the set has most likely died. Check for warranty information in your user's manual for further instructions.
B: Is the TV sharing an electrical line with a wall switch?
Remove the set from that circuit and try another outlet. If not, follow the Steps for "A".
C: Was it during a power storm, when it went blank?
Check the outlet with another appliance - if that device works, try the Steps in "A".
Nov 28, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
May 23, 2008 | Proton MM2701VT 27" TV
Magnavox MS3252S431
Replace:
Q7461 33725
Q7463 32725
C2455 47uF@50V
May 22, 2008 | Proton MM2701VT 27" TV
Power problems with philips magnavox 25TR19C1
aparece codigos en la pantalla MSD luego 55 sy
Dec 18, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox MS2530C 25" TV Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
