Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA Rear Projection TV goes black after a few minutes.
RCA D52W20 52 in. Rear Projection HDTV goes greenish and fades to black after watching for a few minutes. Once unit cools for awhile and then is turned back on it will work again but only for a few minutes and then does the same thing.
  • Anonymous Mar 31, 2014
    TV sounds stays but the picture blinks on and off
  • 3 Answers
Check the lamp to see if it needs replaced.
Posted on Dec 02, 2008
HELP! 50 inch projection RCA HDTV. Turn it on sometimes minutes later, sometimes hours later the picture will go black with sound on once or twice and then it will power itself off entirely. None o
I got all the components you need for your tv I'm parting out mine it was oar king break when I turned it off we bought a wall hanger if you need parts call 270 589 8074
Oct 27, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
I have a 52 rca rear projection was watching tv and went black after a few minutes it turned back on from the power button and i have color lines on the screen and pic is ditorded almost like in a bubble....
Go to Menu ,then Setup look and see if you have Convergence on the Menu ? If you do not see convergence in the Menu then you have a Blowed Fuse FL231 on the Deflection Board.
Let me know what you have listed in the Menu.Problem is not in the Tubes R/G/B.
Feb 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA D52W20 in. Rear Projection HDTV. Just a few minutes ago there was a loud pop while watching tv and then the picture when black. I immediately turned off the television, checked behind it, and...
This TV if the model # is D52W20 ,`Then it is Projection and has 3 Tubes Red / Green / Blue
these tubes Cost over $450.00 each problem will be in the Deflection Board/ it will be the bottom left hand side board that has the FBT flyback Transfomer on it.
Most common repair is 3 capaciotrs on the deflection board CP150 2200uf 16v use 25v, CP114,CP120 220uf 35v replace all 3 caps.
Dec 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 in RCA projection hdtv picture keeps going in and out has soun
If you can solder yes you can fix it your self Ck 3 capacitors cp110 cp114 cp150 --- If cp 150 is puffed up on top it is bad 2200uf 16v other 2 are 220uf 35v replace all3. also resolder all pinns on FBT flyback transfomer and make sure both ribbon connectors are in good.
Jul 20, 2009 | RCA HD52W151 52" Rear Projection HDTV
RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have sound but no picture?
i setup a remote code on the remote so the tv goes on /off and the volume but no picture on screen how when i put the dvd player i can see the movie but noy regular tv please help
May 08, 2008 | RCA D52130 52" Rear Projection Television
RCA R52WH74 rear proj 52inch...gets dark and then fades to black
Yes ,your set like so many others is one of RCAs biggest mess i would say if under warranty get to service center fast!!!! other wise you might be one of the lucky ones that only needs power supply broad solder start with Flyback transfomer solder all pins.
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green lines? Greenish tint to black colors on tv
ohh noooo call a good repair man...
tap on the green crt and check for liquid on the board
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
151 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
