Question about LG WD-14124RD Front Load Washer / Dryer
Lg wd-14123rd Dryer Problem!
As usual the product has decided to pack in as if by majic a couple of weeks after the warenty ran out. The problem is the dryer reports the code DHE after a couple of min into the drying cycle. I have clean the lint out of the drying ducts and installed a new thermistor, but the problem continues to persist. Does anyone have anymore suggestions? Many Thanks
The DHE error in my case was due to blocked condensing duct and bellows with lint. I found I got an odor in the clothes when drying, and the unit would start drying at first, then show the error approx 5 mins into drying. It was missed twice by registered dealer repairers, I paid a fortune to get it flushed out, to have it recurr. I bought the online manual for $30 to show me how to get into the unit and now do it myself. If you are handy, take off the top and front covers, the condensor duct is on the right side of the unit and is plastic zig zaggy unit, and leads down to the bellow. I flush it out with water and detergent, then reassemble. The odor returns over time, and I know I have to repeat the process.
Posted on Jul 30, 2008
    Champion:
  • 210 Answers
DHE is a door switch problem. Make sure it is connected and or it is engaged when the door is closed.
Sgt 48
Posted on Jun 02, 2008
  • 489 Answers
The problem is in the heater assembly.  You will need to get a volt/ohm meter and find out where the problem is in the heater assembly.
Posted on Apr 28, 2008
SOURCE:
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
Obnoxious smell from washer
I use "Affresh" every couple of weeks to keep the washer smelling good. Here is the product to order.
Nov 23, 2012 | Equator EZ 3600 CEE Front Load Washer /...
Hi, hope you can help, I have a 4 kg LG Washer / Dyer (model WD - 1433RD). It is displaying "CL" on the readout. Have lost the manual so wondering if this is a simple fix or not?
CL means that the child lock feature is active and the control panel buttons will not respond. For the LG WD1433RD, press and hold the Rinse+ and Pre-Wash buttons together for about 3 seconds to toggle the lock off. For the LG WD14311RD, press and hold Option and Rinse for about 3 seconds. On both washers, there is a small icon between the two buttons needed to toggle the child lock feature on and off. (It's a small face above a padlock.)
The manual as a Djvu file for the LG WD14311RD is available here: http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=WD-14311RD&initialTab=warranty&targetPage=support-product-profile .
The manual for the WD1433RD is available as a PDF here: http://www.manualsonline.com/ex/thread/view/idThread/80183 .
I hope this helps.
Apr 06, 2011 | LG WD14311RD Front Load Washer / Dryer
My aged invalid mother has a front loading LG washer dryer combo and has washed the same garment 3 times and after wash cycle or drying cycle can't seem to get the door to open to remove the clothes. What...
Hi I hope you solved this by now but I thought an answer might be useful if anyone else has the same question. I am not an expert just an owner of a LG WD-1412RD. It sounds like your mum is not aware this is just the normal safety cool down period following drying (as the stainless steel interior gets very hot during drying). The Door lock sign (small red light) is on, and the display shows Cd during this time, then it beeps and the door unlocks by itself. If you need to remove your laundry earlier than this, you can press the START/PAUSE button to end the cycle (it still takes a couple of minutes). This is covered on p 21 - 22 of the owners manual. which can be downloaded from the LG site. http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Nov 28, 2010 | LG WD-14124RD Front Load Washer / Dryer
Need the largest refrigerator for fixed 32" width Current refr. is Maytag double door that is 31-7/8". Don't want another Maytag. Prefer GE, LG, Samsung etc. Can be double door, three door, top or bottom...
newer frigs are deeper and the with can be the same . but i do like the 3 door maytag and there s a model that fits . this 3 door is mfg under kenmore / amana / whirlpool / majic chef / . the lg 3 door is not a maytag product . . whirlpool builds the maytag so you may find it under many brand names . . also the g e is not a maytag .. what ever you decide to purchase make sure you can get parts in your area for it .. hope this helped mm Majic **** ...
Oct 23, 2010 | Refrigerators
I have a LG DLE0332W Electric Dryer. I push the
Yes, the motor is bad.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are LG certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide. The motor itself should be under $100.
Best, G
Aug 03, 2010 | LG DLE2532W Electric Dryer
. I have a LG WD12126RD front load washer dryer
This is a heater error. The heater element is open and not working. This is usually the problem but it could be other things also. You need a service call from an LG tech.
Jan 11, 2010 | LG WD-12126RD Front Load Washer / Dryer
Not turning on, on switch flickering, just changed drain pump.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
8uy
Jun 02, 2009 | LG WD 14311 RD Monitor
LG WD-14124RD Front Load Washer / Dryer Logo
468 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
