Question about Niko SV3206 32 in. LCD Television
Will not turn on
I have a NIKO SV-3206 that I have never had any problems with. this morning my wife tried to turn it on. She said there was a loud POP and then nothing. The red/green light in the lower right hand corner that would indicate power on or off is not lit. is there a reset button or something?
  • 1 more comment
  • maxxam3 Jan 17, 2009
    exact same problem
  • richardlyons Jan 30, 2009
    What fuse? Where?
  • richardlyons Feb 05, 2009
    While this was not exactly a Fix the information provided was extremely useful and pretty much matched what I had been told by the technician at Viewtek who apparently is the distributor and service center for Niko TV's. They are located in Walnut CA and can be found by doing a search on the web. I have and can provide the address and phone # if anyone needs it.
    Thanks
    Richard
I had exact same Issue, Was able to resolve the no power issue by replacing Diode zd4 (15v) and Q7 (15v Transister) on the back of the power board, and now i have sound but no picture, but while troubleshooting i replace caps so i think i installed a bad one somewere.
Try replacing zd4 and q7 and i bet your in luck...
-ClicK
Posted on Dec 16, 2010
    Genius:
  • Niko Master
  • 1,689 Answers
I have not worked on your model of set. I can tell you generically my opinion from experience of servicing many TV sets.
Once a fuse or any failure to operate properly occures in solid state devices there is an actual fault. These systems have very well designed protection circuits and are computer controlled.
The pop you heard is most probably a direct failure of a component that is most likely feed from one of the main power rails on the circuit board where it operates. The first area of fault may be in the main power supply. In these sets there are several levels of power supplies. Because the pilot light on the set is not lit, I would assume that the main power supply has failed.
It is also possible that a power drive circuit has failed, and the main power supply is in the protection mode, or has also failed. Normally, if there is a failure and the power supply can still function enough to operate the uPC, the uPC will issue a warning. This results in flash codes from the pilot light.
If the fault is not complicated an experienced TV tech may be able to troubleshoot and fix the power supply at the component level.
Normally these sets are serviced by swapping out boards. The tech will try the suspect boards and leave in the boards that make the set work. The next step is to follow the service manual using the calibration instruments to confirm and adjust the factory level setups.
TV sets are not simple devices. There are many power drive circuits that operate various areas. Flat panel sets have some basic principles that follow that of the CRT sets, but for the most part they are very different and very complex in many areas.
I tried to find for you any direct authorized support contact information for your TV. I was not able to find any.
These sets can be fairly expensive to service. You could try a local service center. Ask for an estimate before servicing the set.
When buying a new set I would suggest for you to stay with a big brand name type set. Whatever set you choose find out if there is direct factory level service in your area for the set.
I hope this helps you out to understand more about the problem.
Jerry G.
Posted on Feb 04, 2009
  • 50 Answers
Did u check the fuse
Posted on Jan 26, 2009
  • ClicKK Dec 16, 2010
    -ClicK
Noise and burning smell from heater
Yeah.
Pine needles get into the heater box and clog the heater fan motor's "fan".
You also may have rodents in there,making nests.
The wife was smart to turn off the heater fan B-4 the fuse blew.
Feb 21, 2013 | 2006 Toyota 4Runner
Niko sv3706 tv menu locked
Try this, press Vol- and Vol+ buttons at the same time to unlock osd menu and do the same to lock it.
Sep 16, 2012 | Niko SV-3706 37 in. LCD Television
Niko Sv3706 - When plugged in the Red idle power light is on but when turned on the light goes green then completely shuts off with no light nothing on screen when turned on
Just fixed mine, when plugged in red light comes and goes, sometimes it ststays on but when I turn it on the green light comes on then off. Opened up tv, there is a heat shield of some sort,take off, there is a board where plug goes into the wall,it also has three more plugs plus a ground that is screwed to the tv.I looked at the board and there were two capacitors that were bulged and had brown stuff about to come out the top. They were 1500uf 16v 105c, I changed them only I made them 25v instead of 16. And boom life was good. Good luck and sorry for my spelling.
May 24, 2011 | Niko SV-3706 37 in. LCD Television
TV will not turn on
Check the power supply fuse, DC filter caps and output voltages frist.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 09, 2010 | Niko SV-3706 37 in. LCD Television
Turned it off on the set...can't turn it back on...power button keeps blinkling red
The electrolytic capacitors in the power supply become damaged by heat.The top of the caps will swell up lookinglike a bubble instead of being flat they will needreplacement.the caps should be replaced with high temp caps.This is a commen problem with these sets
Feb 18, 2010 | Niko SV-3706 37 in. LCD Television
NIKO SV-3206
Here's their website:
http://www.viewtekcorp.com/
You can contact them at:
Viewtek Corp.
20957 E. Currier RD, Unit# G
Walnut, CA 91789
Tel: 909-598-6608
Fax: 909-598-6008
E-mail: service@viewtekcorp.com
Hope that helps! Please don't forget to rate this as Fixya!
Cheers!
ID
Oct 25, 2008 | Niko SV3206 32 in. LCD Television
Niko OTP-3211W 32' Mainboard Needed
We don't do email on Fixya and no idea who Jerry is. Keep all replies in the same post by clicking COMMENT under the name of the person you are replying to. Fixya gets 7 million questions a year, so the likelyhood of 'Jerry' seeing are impossible.
Here are your mainboards, 50 bucks.
Niko OTP-3211W TV Parts - ShopJimmy
www.shopjimmy.com/niko/otp-3211w
Niko 21VT3MB0224 (DA0VT3MB6F2) Main Board for OTP-3211W. $46.95. Part number is found on sticker. Set In-Stock Alert · Niko 24VV3EB0003 (DA0VV3TH2B2) PC Board. Out of Stock. Black Friday Deal. Cyber Monday Deal ...
Niko 21VT3MB0127 (DA0VT3MB6F2) Main Board for OTP-3211W
www.shopjimmy.com/niko-21vt3mb0127-main-board.htm This Niko 21VT3MB0127 (DA0VT3MB6F2) Main Board for OTP-3211W (21VT3MB0127) works for these TV models: Niko OTP-3211W.
NIKO 21VT3MB0224 Main Board for Otp-3211w ' eBay
https://www.ebay.com > ... > TV Boards, Parts & Components Find great deals for NIKO 21VT3MB0224 Main Board for Otp-3211w. Shop with confidence on eBay!
Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit ...
www.ebay.com/itm/Niko...OTP-3211W...Main-Board-MotherBoard...-/28218366183... US$49.99 - ‎In stock
This main board was pulled from a working TV with a broken screen, please refer to the pictures. The last 2 pictures are of the TV this was removed from. This sale is for the Main Board and cables shown. I only accept Paypal. Paypal payment must be made within 2 days of end of sale. I will ship within 3 business days of ...
NIKO MAIN BOARD 21VT3MB0224 REV:F FOR MODEL OTP-3211W ...
www.ebay.com/itm/NIKO-MAIN-BOARD...REV-F...OTP-3211W-/172511137409 US$39.95 - ‎In stock
WE TEST ALL OUR PARTS AND GUARANTEE THEM NOT TO BE DOA (DEAD ON ARRIVAL). IF YOU EXPERIENCE A PROBLEM WITH THE PART YOU RECEIVED PLEASE CONTACT US WITHIN THREE (3) DAYS OF RECEIPT AND WE WILL WORK WITH YOU TO CORRECT THE PROBLEM EITHER BY EXCHANGE ...
Amazon.com : Niko - Niko OTP-3211W Audio Board DA0VV3AB2C9 ...
https://www.amazon.com/Niko-OTP-3211W-Audio.../dp/B00SVM5OR8 TV Brand: Niko TV Model: OTP-3211W Part Type: MAIN BOARD Board Numbers: DA0VV3AB2C9, 23VV3AB0004 Part Number: 23VV3AB0004 Specifications: Look for 23VV3AB0004 in your part to verify part number and compatibility. Other Specifications: Part number can be found on the sticker. This board has been ...
Main Board Otp ' TV Repair Components For Sale
https://tvrepaircomponents.pw/niko/sale-main-board-otp__samsung_power.html
6 days ago - Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit. $45.99. Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit. Niko 32" OTP-3211W. Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit. $49.99. NIKO MAIN BOARD 21VT3MB0224 REV:F FOR ...
Otp Niko Main ' TV Repair Components For Sale
https://tvrepaircomponents.pw/niko/sale-otp-niko-main__samsung_power.html
6 days ago - Up to 90% off brand name Tv Part only from your leader in online shopping including discounts on niko, niko main, board niko main, niko main otp, board otp ... Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit ... Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit.
Niko OTP-3211W Main Board DA0VT3MB6E4 21VT3MB0224
www.myshoptvs.com/.../7058-niko-otp-3211w-main-board-da0vt3mb6e4-m9204.ht... Find the best TV part Niko OTP-3211W Main Board DA0VT3MB6E4 21VT3MB0224 at the lowest price online.
22VV3IB0018 Niko TV Module, signal, DAVV3PI12C4, OTP-3211W
www.tvpartstoday.com/22VV3IB0018-Niko-TV-Module...board.../22vv3ib0018.htm Part Number: 22VV3IB0018. Board Numbers: DAVV3PI12C4. TV Models: OTP-3211W. Type: Signal board. ... 22VV3IB0018 Niko TV Module, signal board, DAVV3PI12C4, OTP-3211W Email A Friend ... MODEL NUMBERS: OTP-3211W PART TYPE: Main Board TV TYPE AND SIZE: LCD, 32" MFR PART NUMBER: Niko ...
Niko OTP 3211W main board Google Search
Dec 30, 2017 | Niko OTP-3211W 32 in. LCD Television
This morning the screen is black...
The black screen with audio working ok is the inverter card.
Just replaced mine. It is CMO part number VIT70002.00
The inverter provides the high voltage necessary to drive the cold cathode lighting.
A new card is about $180 but shud save having to dump the set.
Card is located on left side of the display (as viewed from the back).
Howard
May 24, 2008 | Niko OTP-3211W 32 in. LCD Television
Niko SV3206 32 in. LCD Television Logo
640 people viewed this question
Top Niko Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Andrew Taylor
Andrew Taylor
Are you a Niko Televison and Video Expert? Answer questions, earn points and help others
