Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
No water making to my ice tray on an 10 yr old frigidaire
I found the hose fell of the back of the fridge at the top..I reinserted it and found that now i get no water to the ice tray...however the water dispenser still puts out water...I know they are diffrent hoses..
Any ideas would be greatly appreciated
    Sergeant:
    Champion:
  • 291 Answers
Where you inserted the tube is frozen up / inside your freezer the tube that suppys water into your icemaker is frozen and just need to be opened up and this can be done by using hot water to shoot into it and you will be up and going again / larry
Posted on Nov 30, 2008
Superba 10 yr old fridge is blowing condensation from the bottom back vent onto wall. how do I fix so that we can still make ice and water?
Probably not condensation but run-off water generated by the auto-defrost.
This water should drain through a tube into a tray attached to the motor where heat from the motor operation causes it to evaporate.
Sometimes the drain tube or the tray becomes detached.
If condensation is forming on the outside of your fridge it indicates the internal insulation jacket is failing and repair is impractical and replacement of the fridge is desirable.
Nov 03, 2015 | KitchenAid Refrigerators
Why is aSide by side fridge leaking brown liquid from below ice maker?
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
Sep 03, 2014 | Frigidaire Refrigerators
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
Leaky fridge
This is defrost condensate.  You have a hose going to a tray below the box that is blocked.  Rod it out with soft wire or similar.  Clean the condenser while you're in there!
Nov 23, 2008 | Refrigerators
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Filtered water
what kind of supply line is going to the dispenser,, if you have well water you might want to think about even another filter in the line before the frige, change the supply line to copper if it is copper change it to another copper line,,, there is no reason for it to only happen to the ice maker,, what about the ice bucket and ice tray:{where the water fills to make the ice} try cleaning these also
Aug 04, 2008 | Maytag MFD2561HE Bottom Freezer French...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
60 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
