Question about Philips 27PT9007D 27" TV
Unit shuts off after turning it on
This television shuts off immediately after turning it on unless you simultaneously press and hold both the channel up and down buttons for a minute or two. I have sent every board (essentially everything but the picture tube) into PTS for diagnosis and repair. They could find no problem with the boards or button assemblies and sent instructions to adjust the VG2. Adjusting the VG2 has helped only in that the television will now stay tuned in to a channel after releasing the channel up and down buttons. Prior to adjusting the VG2, releasing the buttons would result in the unit immediately shutting down.
  • 217 Answers
It is the problem with the faulty control panel board which is short tracking and gets ok by pressing some wrong mode buttons
Posted on Nov 30, 2008
My kenmore 417 94082500 dryer keeps pausing and shutting off with no errors between 5 and 10 min from starting.
Rotate the cycle selector knob three clicks clockwise (3 o'clock position) from the Normal cycle option then press and hold the Select and Pause Cancel buttons simultaneously for six seconds.Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds. Rotate the cycle selector knob one click counterclockwise (2 o'clock position) and the error code will appear in the digital display as an "E" followed by two numbers, a number and a letter or two letters. Post back the error code for further advice.
Feb 23, 2011 | Dryers
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Admiral code for JSJ12800 Vchip is activated don't know the code?
Usually you need to go to menu option and then then parental control. When display asks for secret number,Press and hold volume up and channel down simultaneously until message is cleared.This turns off parental control and clears the password.
Note - You must press the volume up and channel down buttons on the TV, not on the remote.
If the problem persists, revert and i would be able to search exclusively for this model.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 25, 2010 | RCA F27664 27" TV
What does error code e68 mean
One of the buttons is stuck closed or shorted. Enter the function test mode and perform the button test to determine which button is stuck or shorted. When determined which button, try to free or unstuck the button then perform the test again. Replace the user interface board when the button is freed but the code still exists.
Press and hold the SELECT and CANCEL buttons simultaneously for 6 seconds to reset the control. When resetting is successful, the buzzer will sound and "rES" will be shown briefly in the display, and then immediately rotate the cycle selector knob 5 turns in the counterclockwise direction to the second position from the bottom.
Press and hold the OPTIONS and CANCEL buttons simultaneously for 2 seconds to enter test mode; the buzzer will sound 3 times and all of the LEDs will flash rapidly.
Rotate the cycle selector knob 4 times in the clockwise direction to enter button test. Press the buttons one at a time and observe the LEDs corresponding to that button light up. The LEDs should light up; otherwise the button is stuck.
Press and hold the SELECT and CANCEL buttons simultaneously for 6 seconds to exit test mode.
Apr 04, 2010 | Frigidaire Electric Dryer
I cannot turn off the TV,with the insignia remote control
Read the first time start up instructions .. This is what worked for me.
Hold the power-on/off button down while simultaneously pressing channel up , repeatedly for up to 45 times. when the TV shuts off stop, release the on off button.
you should be able to turn it on and off, if you went too far (pressed up arrow too many times), go the other way (holding down the on off and pressing channed down) until it turns on again.
Nov 30, 2009 | Insignia Digital-to-Analog Converter for...
Sanyo TV I need a code for my optimum cable remote control to turn on and off the TV with their remote control.
Here's the instructions and codes plus an alternative method if one of the codes below do not work.
Three-Digit Code Programming Method:
  1. Turn on the TV.
  2. Press and hold the TV and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. With the iO button lit, point the remote at the TV and enter the TV's three-digit code (see code table below). The TV will shut off when the correct code is entered.
  4. Verify by pressing the SEL button. This should turn the TV on and off.
  5. Press the TV button to store the three-digit code. The iO button will blink twice to confirm that the code is stored.
Codes: 007, 053, 057, 082, 020, 239
Auto Search Programming Method Use this method if the three-digit code method does not successfully program your remote control:
  1. Turn on the TV.
  2. Press the CBL and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. Hold down CH+ and release it as soon as the TV powers off.
  4. Press CH- five times (the television may or may not turn on again as you do this). If the television does not power, turn it on manually before proceeding.
  5. Press CH+ one at a time until the television shuts off.
  6. Press TV to save the code.
To save time, the Auto-Scan function is trying codes as fast as possible while CH+ is being held down. It scans so fast that you may pass the desired code while holding down the CH+ button. Steps 4-5 allow you fine tune the auto-scan so you reach the correct code.
Nov 26, 2009 | Sanyo Televison & Video
Blocks all channels even Public channels
I'm not sure for that particular model, but here are the unlock sequences for a few RCA sets, hopefully one will work.
Go to the parental control under preferences on your menu and select it. When you see 'enter password', press VOL+ on the remote and the CHANNEL + on the front of the TV at the same time. Enter New Pwd. will appear on the screen. Press the number buttons to enter a four-digit code.
Make sure the TV is off. Simultaneously press and hold VOL- on the TV's front panel and CLEAR on the remote for approximately 5 seconds.
press and hold TV on the remote and the
MENU button on the television simultaneously for 3 seconds.
Aug 17, 2009 | RCA TruFlat 27F520T 27" TV
The Miehle built in coffee maker - I want to stop the cleaning process but it won't clear
1. turn unit off 2. open door, turn power off for 5 secs. ( switch upper left corner )  3. turn power back on, close door. 4. press and hold clear, press on/off. release both simultaneously. 5. immediately , press clear 5 times holding it down the fifth press until the display changes. 6. with menu available, press more until option to reset cleaning appears, select reset cleaning. 7. finished
Nov 02, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Television difficulties
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence
Dec 07, 2007 | Mitsubishi WS-55819 55" Rear Projection...
DVD will not eject
The disk cannot be taken out by setting the Tray Lock, please follow the steps below.
Turn Unit ON.
Set the DVD to the Stop Mode.
Press and hold the ‘STOP’ key on the front panel.
Simultaneously press and hold the ‘9’ key on the remote control unit.
Hold both keys for more than 2 seconds.
Press the OPEN/CLOSE key on the front panel to check the Tray Lock setting.
To unlock the Tray Lock, please follow the steps below.
Turn Unit ON.
The Tray Lock has now been cleared.
Nov 09, 2007 | Toshiba 20HLV15 TV
Philips 27PT9007D 27" TV Logo
74 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
