Question about Honeywell Heating & Cooling
Just installed the RTH 7600 and set it to Auto. Also set the temparature to 72 degrees and hit HOLD. The manual states this should permanently override the pre-programmed schedule settings, but we woke up freezing this morning. Why does the "Permanent Hold" setting not override the pre-programmed ones? Thanks David
  • 958 Answers
SOURCE: contour comfort control
normally, if you have a hold option, there should be a hold button which when you press again should un hold the setting. have you tried pressing the run button. this would eliminate all hold function and just run the programmed temperatures.
Posted on Feb 17, 2008
  • 17 Answers
SOURCE: Configuration settings do not save in 'Permanent' mode
Q1# do you have printer driver? what kind of driver ur using? is your driver from www.zebra.com? Q2#what software u are using to print? Q3#ask the programmer of the software if there is a command that control the settings of the printer Q4# is the software DOS or windows program
Posted on Mar 20, 2009
  • 19 Answers
SOURCE: permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
Posted on May 17, 2009
  • 12 Answers
SOURCE: Honeywell TH8320U1008
simply push cancel. That clears the hold feature.
Pushing hold once gets - permanent hold.
Pushing hold twice gets - days of permanent hold. So you can set it if you are going away on a temp and at the end of the days it goes back to normal operation.
Posted on Jul 23, 2009
  • 117 Answers
SOURCE: I have my thermostat set to 75 degrees however my
How old is your system?
If your system is a heat pump and is failing to keep up overnight during the colder weather. Or if it struggles to keep up at all, a few issues come to mind.
Obviously, the first and most common cause would be due to an undercharge of refrigerant. With an undercharge, your heat pump has lost efficiency and cannot properly remove heat from outside.
Other possible issues that come to mind are failed defrost cycle. If your unit is not defrosting properly and it continues to run non-stop, a freeze-up could occur on the outdoor coil. And the worse it gets, the worse your system will perform.
Another possibility is auxiliary heat or heat strips are not coming on at all. Depending on your thermostat, you would be able to tell if the thermostat is calling for auxiliary heat. If you are not getting any additional heat, then the heat pump may not be adequate for the space intended.
Other smaller factors may come into play such as incorrect defrost cycles. Possibly a mechanical component taking a break or overheating or maybe a mechanical failure such as failed compressor leaving the only heat you have as emergency.
Posted on Jan 09, 2010
Thermostat set at 72 degrees on auto cool setting
Check the tstat's for a relative humidity setting. If it has that option set it to 60 percent. If not, make sure to check all programs if it's programmable. If not those 2 options, it may need to be replaced.
Oct 21, 2017 | Heating & Cooling
My thermostate will not shut off when the room temperature drops to 72 degrees in which my thermostat was set at on the auto cool setting. It even continues to run and drop below 72 to 68 degrees and never...
What brand and installed in what? If a thermostat is installed on a wall that is heated by the sun it will give false temps. If it's mounted too low or high it will not be right either.
Oct 08, 2014 | Heating & Cooling
Honewell RTH 7500 Temp Sensor Problem?
Check your installer configuration. If you have it set up, in the configuration, to match your system, and you can turn it up by 5 degrees with no heat, it may be a fault at the tstat. If and when it fails to cycle on, you can jump R to W, by touching those 2 terminal/wires together, and it should begin the heat process. If it don't, then it's not your tstat. Hope this helps!
Mar 12, 2017 | Heating & Cooling
The temperature on my honeywell thermostat is set to 89 degrees and does not want to change no matter what. The model is RTH2300. Please help because the heat is really unbearable.
Just google RTH 2300 for the manual, check that the hold is not on, if it is push it to turn it off, if not read thru the manual. On most stats if the unoccupied set point are blocking the occupied set points run the unnocc. temp down and then set the occ. set points down. Good luck
Jun 30, 2011 | Heating & Cooling
My Trane ModelTCONT402AN32DAA thermostat set for 75 degrees overshoots to above 81 degrees (as measured by a reliable thermometer). The thermostat temperature indicates 75 degrees and the heatpump will...
I would remove front cover and see if your thermostat has a mercury switch.this will be a small vial connected to a bimetallic coil. The vial wiil be about 1/3 full of mercury. It will have a brite silverey appearence.There shoul be two leveling peg on inside of thermostat. Check the level with a torpedo level. it should be very close to level. If not loosen mounting screws that hold stat to wall and gently move base till you have it level. Hold base steady and tighten mounting screws. This should help thermostat setting and actual temperture to be closer. It's not unusual for setting to be off by several degrees.
Nov 15, 2010 | Heating & Cooling
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Thermostat will not let us program the cooling past 72 we have tried to move the temporary setting also useing the hold temp button and pushing the decrease key, it seem to be locked at 72
you need to get into the installer settings to lower the minimum setpoint. look up your model online and try that. Otherwise you may have an older style auto changeover type t sat in which case you should still look up the manual and reprogram from the installer configs. or try buying a new one
Sep 13, 2009 | Honeywell Programmable Thermostat Heater
How to hook up Honeywell rth 7600. have an extra wire
From what I'm seeing the 7600 is not compatible with a heat pump. Where are you landing the orange wire?
May 12, 2017 | Honeywell Heating & Cooling
Honeywell FocusPRO TH6110D auto-changeover unavailable
Do you still have your setup manual go through the setup functions
Nov 25, 2008 | Heating & Cooling
Heating & Cooling Logo
54 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
