The pilot will not stay lit - Heating & Cooling
  • mz47 Jan 09, 2009
    Pilot Lights stays on only when button is held in. As soon as it is released it goes out. No exterior drafts noted.
    A diagnosis is appreciated.
  • 34 Answers
Probably need a new thermocouple, check to see if the flame is dancing around.  you may be getting a backdraft from the flu or if you have a crack in the heat exchanger the supply air could be blowing it out.
Posted on Dec 02, 2008
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Jan 14, 2015 | Heating & Cooling
I changed my thermocouple on my fireplace,it still wont stay lit
Thermocouple keeps the pilot lit.
Thermopile keeps the burner lit.
Please specify what won't stay lit...
If it's the burner, you may need to change the thermopile as well.
If the pilot still won't stay lit, you will want to make sure that the pilot flame is large enough to completely engulf the thermocouple and keep it hot. If it's too small, you may need to take some compressed air and blow out the pilot hood to remove any blockage.
Dec 18, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a readyheater model 65-85 the flame will not stay lit im thinking thermal couple is there a way to test this part? or could it be another problem?
If your pilot light will not stay lit when you release pilot light button then chances are that your thermocouple is bad. Make sure that the tip of thermocouple is directly in line with pilot light. Tip of thermocouple should be cherry red if it is properly placed. If pilot will not stay lit then replace it. If you aren't sure about placement of thermocouple you can heat thermocouple with a seperate heat source. If you do this and pilot light stays lit then reposition thermocouple in pilot flame. If it still won't keep pilot burning then replace thermocouple. Hope this helps. Thanks.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
Im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there...
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Water heater will not stay lit even after replacing thermal coupl
The pilot must encompass the thermocouple "bulb" in order for the thermocouple to generate enough current to keep the pilot valve on. You must also hold the red button down for a long enough period to get the thermocouple hot. If the pilot is not large enough, it could be due to a clog in the pilot orifice at the pilot itself. Sometimes a couple of passes over the end of it with fine steel wool is all it takes to clear it.
Hope this helps. Feel free to share what you found. Thanks.
Jul 16, 2009 | Kenmore Dryers
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Pilot flickers replkaced ther-cup now pilot wont lite/stay lit.
Blow out the dust from the pilot and reposition the pilot where the flame hits the tip. more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 26, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
218 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
