Question about Refrigerators
Maytag PBF 2255 HEW refrigerator defrost timer location?
This dual door upper/bottom drawer freezer type of refrigerator has a totally frozen up evaporator coil. I'm trying to find where the defrost timer is located, assuming it has one. I have no schematic. Help locating that part would be much appreciated.
  • gotmoldohio Dec 27, 2008
    The parts diagram shows there is no stand alone defrost timer, unfortunately. The frozen evaporator coil is either due to a bad JAZZ board or defective evaporator fan motor, I think.
    People with "the codes" can push the fridge and freezer temp buttons to diagnose the JAZZ board and do other things, but...no codes, no can do.
    Helpful to see the diagrams, however. Thanks.
Items in deli drawer keep freezing
is the freezer freezing too? to much ice build up? if not check ur damper vent, make sure its not stuck closed or open to far, check the thermistors, the tempeture control thermostat, defrost timer and defrost terminator
Feb 19, 2015 | Kenmore Refrigerators
Maytag MBF 2256 HEW how to turn off freezer without turning off refrigerator on top
it cannot be done the freezer cools the refrigerator thru a damper vent door from the freezer to the refrigerator
Apr 16, 2010 | Maytag MBF 2256 Bottom Freezer...
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
Nov 25, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Frozen evap coil
In the upper food section in the middle of the light/temp control panel.
Jan 10, 2009 | Maytag MBB2256GES Bottom Freezer...
Maytag PBF 2255 HEW refrigerator JAZZ board replacement issue
thats different I was thinking of something else the board you are talking about just controls the temp. controls this may be your problem call1-800-688-9900 maytag or 1-800-253-1301 whirlpool they can give you a better idea on the part number issue this may be the problem
Jan 10, 2009 | Maytag Refrigerators
Maytag PBF 2255 HEW refrigerator Freezes up, won't defrost
To rule out the evap fan.
The evap fan should run all the time except when in the defrost mode.
Dec 27, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
Aug 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
871 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
