Question about Pioneer Televison & Video
Remote sensor on tv not responding to remotes. pioneer PDP-42A3HD
Have been using universal remote from cable co. to run digital cable box and tv for 2 years. Remote function on tv has been periodically not working last month. Cable guy came out and reprogrammed a different remote 3 weeks ago. Worked for a day-didn't work for 3 days-worked again for a few days and now doesn't. Cable guy came back and couldn't get digital cable remote or original tv remote to work. Says he thinks it's a sensor issue in tv. Have changed batteries in all remotes. Have had 3 different remotes in last month. All operate cable box fine but not tv. Can't get menu window or turn tv on/off or volume. Is this something that can be fixed on site? Anything I can try before calling service?
SOURCE: too many remote controls
Cox / Comcast Remote Control Code 0178
Posted on Jan 13, 2008
rey jr
  • 149 Answers
SOURCE: Remote Not working
hi there, check up the sensor, do some cleaning, check up for some cold solder, do some test and check up. ty
Posted on Feb 18, 2008
Shmoopy
  • 53 Answers
SOURCE: remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Posted on Mar 25, 2008
SOURCE: Remote control does not work for my plasma tv
I also had this same problem. Both the original remote and my universal remote failed to give any response on the TV. Normally the green light flashes when it receives a command from the remote. Called LG Support and they made me an appointment with a local repair company for 3 days later. This seemed pretty quick compared to other companies repair times I'd read about. However next day the repair company called to say it would be 5 more days before they could get a Tech to my location (downtown ATL). 8 days was a long time to wait but once tech arrived he diagnosed it to a bad board and simply went to his truck and swapped it out with mine under factory warranty. Everything has been fine since.
Posted on Jun 04, 2008
SOURCE: Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
I just realized that there is no usb port on this tv. Called tech support at vizio since I'm still under warranty. They're sending a new remote. I know it's not the remote because neither the verizon nor the vizio remote works, although the vizio remote will intermittently work if I'm one foot away from the sensor on the tv and holding the remote on a downward angle. Tech support says they will send a new remote to rule that out before they send a tech over. I'll check the posts to see if you find a solution when I finally get the tech guy out here. If not, I'll let you know what he does.
Good luck.
Posted on Aug 13, 2008
Pioneer PDP-42A3HD - TV turns itself off...is
Here is the link for the manual - c ould be a remote set up issue or this could be puffed caps in the power supply - have a qualified tech check that out
http://tv.manualsonline.com/search.html?q=PDP-42A3HD&submit.x=49&submit.y=15
Jul 03, 2010 | Pioneer PDP-42A3HD 42 in. Plasma...
RCA universal nor cable remote will program RCA L40FHD41 TV
might be able to use the cable co remote and autosearch thru the codes, but its too hard to explain, the cable tech should have ran that procedure. unfortunately, rca has 50 million models. it is common to have a tv and yes rca for sure, to not take the codes. sometimes the tv is too new for the cable company remotes to work. i am leaning toward the tv too new theory. give it six months and i bet there will be a new remote version.
Dec 08, 2009 | RCA L40HD36 40 in. LCD HDTV
Pioneer 428xd tv remote control code wanted
if you have gone through all of the codes in the manual for pioneer, and they dont work, then your last option with that remote is to use the "code search" feature.
otherwise you're going to have to find a remote that will work for that unit, because its not exactly new :(
Sep 24, 2009 | Televison & Video
Have a new Phillips 42" lcd tv. my cable box remote has been working intermittently. However the white light near the remote sensor on the TV blinks whenever I use the cable remote. after changing bat
your TV and, your cable box both "see" a series of invisible (infared) flashes of light like morse code these flases tell them what to do.one answer is to: buy a universal remote so that you can program a button for each device then when you want to control the cable box just push the "cable" button and, then volume etc. to turn your tv off push "tv" then "off" the service man was right but he should have explained this to you
also your cable remote may be programable to work with your tv like a universal remote check with your cable co.
May 22, 2009 | Televison & Video
Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
Dec 06, 2008 | Pioneer SX-315
Codes for universal remote
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 25, 2008 | RCA Universal Remote Control
Pioneer media receiver pdp-r04u
try testing dvd player direct to tv dont use uvsal remote go to tv turn it on and change inpput to dvd see it works
Feb 06, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Televison & Video Logo
141 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
