Question about Sony STR-DA50ES Receiver
Protector fan my protector fan on my Sony str-da50es is always on . I get no sound from it. Can someone help me. Thanks
    Scholar:
  • 135 Answers
Hi there. Check for Dry solder joints around IC902,IC955,etc on Main board. This should sort your problem. IC902 supplies the Digital Board which in turn runs the fan circuit. This is why you won't have sound either. Be sure to unplug from mains and don't attempt if you do not have some experience in electronics. Hope this helps. Regards
Posted on Jul 23, 2013
Jump fuze f953. Resets receiver.
Posted on Nov 12, 2011
I have the same problem , help me umbertknot@hotmail.it
Posted on Jun 28, 2008
    Novelist:
    Champion:
  • 219 Answers
Sounds fried. Time for a trip to the shop. Good luck.
Posted on Jan 23, 2007
Protector flashes everytime the unit is turned on.
Please see the link below for a generic explanation about protect mode. Please post any additional questions that you may have here and I'll respond.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Sep 10, 2010 | Sony STR-DA50ES Receiver
I need a motherboard for a sony STR-DA50ES audio receiver and no shop was able to find one.
These boards are no longer available from Sony. What is the problem you are trying to solve? I have never needed to replace the entire board. One other option is to locate a "broken" unit from shop or Ebay and use the board from there.
If you can describe the problems, perhaps we can help to repair the existing board.
Dan
Apr 21, 2010 | Sony STR-DA50ES Receiver
Sony DA50ES makes loud and scary clicking noise after its been on for about ten minutes, its loud enough to be distracting and annoying while watching movies. I'm wondering if I need to buy a new receiver...
Is the noise audible through the speakers or is it a physical clicking directly from inside the receiver?
If the former, what source(s) do it and are they digital or analog?
It doesn't appear there is a fan so NO physical noises should emanate from the receiver. I'd suspect an arcing component or something electrical. THAT might be dangerous to the receiver or even a fire hazard. Get it looked at.
Feb 24, 2010 | Sony STR-DA50ES Receiver
Sony str-da50es. Does not power when power button is pushed.
This problem is very common in this model the solution is to replace the fuse with improved one 10A 125V of type CES710A having part No.1-576-695-11. Remember that this fuse would be larger in size of earlier one so that you have to drill it first in the holder and adjust the fuse to a proper space of 1.4 drill bit.
Do the changes and your product work fine.
Thanks.
Nov 24, 2009 | Sony STR-DA50ES Receiver
The word protector puts on when power to stereo is turned on...
This is not a fuse problem. The rotect mesage indicates that the unit detected a problem and shutdonw the unit to prevent further damage. Disconnect the speaker wires and try turning on the system. If protect still occurs, there is an internal problem *usually shuorted output transistors) that will require service. If you can solder and wish to attempt the repair yourself, update this and I'll provide additional details and instructions.
Dan
Jan 22, 2009 | Sony STR-DA50ES Receiver
Sony da333es : protector (fan) ;how do I fix this
It's warning you that the fan is dead or clogged. Look at it and possibly clean out the dust bunnies.
Dec 26, 2008 | Sony STR-DE898 Receiver
Sony STR-DE525 Protector mode
Download service manual of STR-DE525 here and fix your receiver.
Must download all 4 files at web site.
Need further help, let me know.
Sep 24, 2008 | Sony STR-DE525
It blinks PROTECTOR
This means that the unit detected a problem and shut itself down to prevent further damage. The normal cuase of this is a defective transistor in the final amplifier stage. Figure on $15-$35 for parts plus the local labor rate for the total repair.
Dan
Aug 19, 2008 | Sony STR-DE705 Receiver
Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Mar 07, 2008 | Sony STR-DB930 Receiver
1,028 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
