Question about JVC AV-48WP30 48" Rear Projection Television
JVC AV-48WP74 48 in.
The top half of the screen has a double picture that is mostly purple and green. The picture drapes down in the middle. The bottom half of the screen is working fine. Thanks.
The convergence circuit needs repaired. I did the same job yesterday on this model. I not only replaced the convergence ICs, but, I had to replace a couple of resistors and a coil. The convergence alignment was minor after that.
Posted on Jan 28, 2007
JVC AV-65WP74the picture projectscuved in the middle of the scren
This kind of picture problem is due to failure of convergence out ICs, please replace convergence out ICs in tv to get it fixed.
If you are handy with electronics stuff repair and can replace parts in circuit board with proper tools then can replace above said ICs by yourself or ask local tv tech to repair your tv.
Thanks.
Mar 15, 2010 | JVC AV-65WP74 Rear Projection Television
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
I have a JVC AV-56WP74 that all of the sudden has a bow screen on top and bottom with green and purple tint with double picture. I have tried to fix the problem working with the convergence troubble...
You need to replace both convergence ICs they are STK392-110 you may want to get the resistor kit as your model will usually have a couple open resistors. You can get replacement ICs and resistors at the following link and they provide free instructions with pictures so you can easially do the repair your self.
Heres the link.
http://servicemanuals.vstore.ca/
Aug 13, 2008 | JVC Televison & Video
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
Screen is bowed (top and bottom) Color has a green and purple tint?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example video
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Jan 15, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-65WP74 65 in. Rear Projection... Problem:
I'm having a problem with my JVC 65WP74 the screen shows double pictures at the top and in the middle.
Oct 10, 2007 | JVC AV-65WP55 65" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
89 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
