Question about Bose Lifestyle 30 System
Damages in ls 30 2series music center
My system is damaged there is problem in 12 valt power amp circuet bord no.1788343-2 can iget that pert easily oterwise can i connect accostimass 5.1 toother make av reciver
  • 2 more comments
  • flavourforev Nov 30, 2008
    wat solution about my accostimass 5.1 speaker wich is non use
  • flavourforev Dec 28, 2008
    iwant to connect my accostimass30 to yamaha make recever, after any solution about connection come outthan i will deside to purchase yamaha revever or other make but surlly i cant want to purchase bose music center thats is final.
    i kno that part is costly & further if any problem which is not solve and ihave allredy deside a new latest recever.
    please give me asollution to connect my accoustimass30 to connect yamaha recever only
  • 365 Answers
The wiring system may be different if you use the separate circuit board and it may or may not work properly.it is not sure.it is recommended to use the same board itself.the board is available in any leading electronic stores and they will recommend another perfect one if the asked one is not available .thank you
Posted on Dec 28, 2008
  • JITHIN ANTONY Jan 05, 2009
    does the problem solved
    Genius:
  • 2,035 Answers
Well if want connect a Yamaha make receiver then there many changes in the wiring in the system and sound quality may vary incase other company amp and its complicated process , and I commend you need to contact the Bose service and get it fixed you can use this number 1-800-367-4008 for the amp board or then service center near you and as its not easily available on line and you can use on the home there amp if the unit is not servicable ...
Good luck..
  • Anand Kumar
    Anand Kumar Dec 28, 2008
    Sorry that for US : For India :
    ph: 011-23073825 / 26/ 27/29..
  • Anand Kumar
    You can connect the accousti mass 30speaker to Yamaha receiver by connecting the speaker of the it and only problem could be the sub woofer as it its consealed in the unit you remove the wires of the sub woofer and connected with long wires and connect it Yamaha receiver
    Make sure the speakers impedance is recommenced level or speaker could damaged if there is a mismatch in the impedance..Independence is printed behind the speakers ...
    Good luck..
    Guru:
  • 829 Answers
If only the Power section is damaged then it is easily repairable . If you know the problem and require the spare then let me know.
    Genius:
  • 1,011 Answers
Sir,
First of all replace the board and reinstall(format the system) the OS it will be Ok
  • Asfiya Ahamed
    Asfiya Ahamed Dec 28, 2008
    check this link for information...Your Yamaha receiver model no.?
    http://www.intellexual.net/bose.html
    Sergeant:
    Novelist:
  • 327 Answers
U can get that to the near by electronic parts store.or at service center.
  • 2,427 Answers
Why just not order an the model board from the manufacturer and save your self the hassle of having to convert and modify?>??
  • 1 more comment
  • Rishi Roshan Ali Dec 28, 2008
    Just in case,, find the out that goes into the amp board,,m and use an external amplifier for the system..
    Bose is the beast,,, Personally I would have gone with the bose,, professionally I'm compelled to help you save money.
    Well unfortunately you will need some type of amplifier for this. If you wish to try without one,, Find the output /// The input for the amp board,, the wires should be labeled in.. and connect this to the input of the reciver..
    basically accoustimass30 output to yamaha input.. you said the amp board was damaged ,, there should be a connector to the ampboard thats where you will find the output or the input to the ampboard.. The purpose of the amp is to increase the sound and make it audiable.. I dont think you will get anythng without the amp.. sadly.
Wat is the power supply for dg31pr?
  • Supports the following power supply specifications: ATX12V version 2.0, SFX12V version 3.0, and TFX12V version 2.0.
  • Failure to use an appropriate power supply and/or not connecting the 12V power connector to the desktop board may result in damage to the board or the system may not function properly.
  • The 2 x 12 pin main power connector is backwards compatible with ATX12V power supplies with 2 x 10 connectors.
  • Serial ATA (SATA) connectors are required to support SATA hard drives
Welcome to my website
Nov 03, 2014 | Computers & Internet
LG 37LG300-ZA,LCD,stand by no picture &sound,power led twinkling but it dosnt work.
Replace the main power regulator board. It cannot be repaired.
Dec 09, 2012 | Televison & Video
I mis placed the power amp ic for my sharp model number cd-m10000 what is the ic pert numbery
You can get the IC specifications if you can refer to the Sharp service center with the model specified as the OE part will also be available with them.
Mar 11, 2012 | Sharp Multi-System Mini Component System...
My kodak easy share cd14 is showing "lens problem
This problem happens because oflong time no using/ Dust or Lens guide pin damaged. If the lens guide pindamage then there is no chance for repairing . Only solution is replacing thelens. For the solution you need to follow the steps.1. Turn off the camera and remove the memory card and clean theexternal body of the camera and make sure in place of the lens there is no dustor damaged sign.2. Now turn on the camera without memory card & make sure thebattery are fully charged.3. If the lens not moving then give a little shake or thrust by hand( carefully very slow) and then wait for a moment. If no changes then turn onthe camera and give a little twist an anti clock side and leave for few second.It is risky ( Do it slowly at your own risk)4. If nothing change then reset the camera setting from the menuoption.After following all steps, if thecamera does not start working then you need to visit service center forreplacing the Lens or Repairing. But before repairing ask service center theapprox cost. if they told you to replacing the lens then do not do that.Because a new lens & service charge cost you near about a new camera price.So best is buy a new camera. If you have any more questions ask me I fell happyto answer your question. Thank you.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html - - - Doit your self lens fix
Oct 26, 2011 | Kodak EasyShare CD14 Digital Camera
Hi. I have a M-Audio FW2626 and it was by mistake pluged in a higher V tension, and now it doesn't work anymore. Perhaps I found the problem, but I need its Diagram Block. If you can help, I...
The external power supply is probably damaged and will need to be replaced. It appears to be a 12 volt DC, 3.5 amp, center positive unit. I would replace with a new one from the M-Audio parts supply as the ratings of this are far above standard universal units.
Sep 19, 2011 | M-Audio Maudio Profire 2626 Profire2626 In...
Behringer Europower PMP2000 Fuse keeps blowing when the amp is switched on.
For goodness sakes do NOT replace the fuse... doing so causes more damage inside. Likely one of the power amps has shorted and may have damaged the power supply as well. Also please read my tip on Fixya regarding a HAZARD with channel A if you use 1/4 inch plugs with the speaker cables. Essentially the sleeve of the channel A plug is the hot, and not the tip. Ground the sleeve of the plug and you can blow the channel A amp. YOU WILL NEED TO TAKE THE UNIT IN FOR REPAIR... THIS IS NOT A DIY REPAIR!!!!
Aug 23, 2011 | Behringer Rx 1202fx 12 Channel Line and...
I have a bx4500h and a ultra bass 115 cabinet. the head is fine, but the crossover? is bad in the cabinet. what can i do? can i just by pass the crossover and just use a 1/4" jack straight to the...
does the cab have a horn like the one in the photo if it does then you must think again.
you must try to get a replacement crossover or get a speaker geek to fix it for you its not so hard you can get the burnt out components fro radio shack / maplin so on. most of the blown components will show damage or smell like they are burnt because thats what they are.
the cross over plays a very important job in the fact that it filters of the top frequencies so you only get subs on the bottom 12's bass / mid on the top 12's and hi frequencies on the horn.
you will loose all the quality if you go direct and could easily blow things up especially the horn.
this speaker cab looks like a Kenny i had and when working then they are fantastic. i blow one of the sub 12's and the cross over survived so unplug the speakers and test them 1 by one with a little power from an amp and a small amp that does not matter if it gets damaged
Apr 11, 2011 | Behringer Ultrabass BB410 1200W Bass...
I need to know the polarity diagram for the ypt-220 so I can use a replacement power tip
The YPT220 is similar to many of the PSR keyboards and will use the same adapter. MOST, like your YPT220, use an adapter with the center pin positive AND are protected by a series diode in the keyboard such that damage will NOT occur if wrong polarity is used. You should use an adapter that provides 10 to 12 volts with positive on the pin and negative on the shell capable of 1 amp (1000ma).
Dec 18, 2010 | Yamaha YPT220 PAK 61 Key Keyboard wAC...
Usb not reconnigation
if usb is not recoginize click on my computer then hardwere then click device manager. look usb softwere is stall or not ? if stall . keep a other usb card in pci slot in computre(mother borD) iblemt means your bord usb system may be damage. in our jeneral practis we face 945 gcr bord are damage many .time. so i like to say if driver not shown your bord usb hardwere system may be damage.
Jul 14, 2009 | Intel D945GCCR Motherboard
Bose Lifestyle 12 Porblems
sorry mate, looks like cd 5 is damaged goods...... wheter you damaged it or not, can't say....
however, make sure. when you try to play cd, that the cd button, nearest display was pressed as just putting in a cd isn't automatically taking control of the cd function like in other cd players. ( that is to say you have to diliberately select CD mode to play cd's)
if you fancy a load of electronic messing and visits to radio shack i am sure you can repair it if broken,
or a second hand cd unit could be obtained elsewhere on line.
Jan 02, 2008 | Bose Lifestyle 12 System
Bose Lifestyle 30 System Logo
67 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
