Question about Sony KP-65WV700 65" Rear Projection HDTV
Sony kp-65wv700 65 in rear projection hdtv
While turning on tv start flashing red light and turns itself off and on
  • Anonymous Jan 30, 2009
    i have same problem
  • Sonny Berry
    Sonny Berry May 11, 2010
    does the led blink a certain number of blinks, pause briefly then blink again? Or does the set just randomly keep turning on and off? Let me know and I will try to assist you.
    Problem Solver:
  • 8 Answers
You need a new power supply board
Posted on Dec 31, 2008
Tv will not turn on, red flashing light comes then turns off
tv will not turn on, red flashing light comes then turns off.
light flashes six times.
Aug 15, 2012 | Sony KP-53HS30 53" Rear Projection...
My Sony KP-46WT500 TV does not turn on. Red standby light blinks and goes out.
possible bad convergence chips and the two fusses in the power suply or bad tube I need to know how many times does the stand red led flashes after it powers down
Aug 29, 2010 | Sony KP-46WT500 46" Rear Projection...
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
When i turn the TV on, a red light on the front of the set just flashes (standby light)
Let me know model and brand of TV if its other then Sony KP-46WT510 and also count red standby light flashes as there would be long pause between blinks.
These info will help me to find out possible solution.
Jul 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The tv doesnot turn on
either the lamp needs to be replace which eventually happen in all rear projection tvs. Do you have colored lights, flashing lights on tv? It is also very possible that the power supply may need to be replaced. If you have colored or flashing lights, please let me know which ones they are and if they are a solid light or flashing and how many times it flashes.
If the tv has sound no picture, than it is your lamp. If you have nothing what so ever, than your power supply may have to be replaced.
Mar 30, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony 5 projection tv kp-51ws510 no pic, light flashs 8 times
I have the same model TV and have had that same problem (*8 flashes) The FLYBACK TRANSFORMER on the D circut board is the most likely cause and will need replaced) the part is around $70.00 USD!
Please rate my response
THANK YOU!
Jan 22, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-65WV700 65" Rear Projection HDTV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
