Question about Microsoft Windows Vista Ultimate Edition
Flickering LCD TV monitor
Whenever I tried to connect the VGA cable to the external TV (a 37"LCD), the notebook screen blanked out and the external TV in PC mode will start to flicker.
This is despite the settings on the Control Panel/ Personalisation/ Display Setting. I was not able to "extend desktop to this monitor", no matter how I "Apply" or "OK".
Any advice out there?
Thanks very much in advance.
  • wai68 Nov 30, 2008
    BTW Mine is the MS Windows Vista Business.
  • wai68 Dec 21, 2008
    Thank you for replying, juremeh.
    The refresh rate is set on default and so I'm unable to change.
    It seems that this happened after I installed the MPlayer and changed the settings to make the LCD Monitor as primary.
    Now whenever I plug-in the VGA cable to the external monitor, the external monitor takes over from my laptop, regardless of the fact that what the settings are set.
    I do not have any problems when I extend the monitor to my 19" LCD though.
    What do you think?
  • 49 Answers
Hello. you have to set refresh rates differntly on tv and on monitor. the flickering appears usually if the frequency is too low. hope i helped you.
Posted on Nov 30, 2008
MY acer ZD1 screen has gone black how do i connect it to a pc screen blind
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the Right/Rear of the laptop.
Example of a VGA connector (Port), and a VGA Cable,
Scroll down a little for an example of a VGA Cable.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Yes. You can also connect an HDMI cable to it, and HDTV with this capability.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings the display should show on the external VGA monitor.
If not;
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY
Press, and hold down on the Fn key. At the SAME time tap once on the F5 key. The F5 key is the Display Toggle-Over key.
Feb 19, 2013 | Acer Aspire 5920-6423 Notebook
How do i fix a flickering screen problem of my HP Compaq 6735s laptop
The flickering could be a sign that your lcd screen is going bad and needs to be replaced. It could also be the video card inside the computer. Isolate the problem by connecting another monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok without flickering, then your video card inside the computer is good, but your lcd screen is bad. If the Borrowed monitor flickers like your lcd screen did, then your video card inside the computer is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Try tapping the back of the lcd screen's lid to see if the flickering stops, increases or decreases. It might be that the lcd cable located at the top on the back of the lcd screen is loose.Isolate the problem by connecting another monitor to the computer. You'll have to take the lcd apart to get to the video cable on the back of it.
May 31, 2012 | HP Compaq 6735s Notebook
Screen blank with white dot
Problem with;
1) Video cable:
A) Video cable connection on motherboard side is loose, and/or on back of LCD screen.
B) Video cable is damaged.
2) screen Inverter:
screen Inverter is bad.
3) LCD screen:
LCD screen is bad.
4) Graphics chipset:
Graphics chipset is bad.
Suggest you connect a VGA monitor to the VGA port (Connector) on your laptop.
See if the problem is the graphics chipset, Or video cable, Or display assembly.
You didn't state what manufacturer and Model Number of laptop this is.
All I can do is state generic information.
This is an example of a VGA Cable, and VGA connector,
The VGA connector will be on the side, or back of your laptop.
For the VGA monitor you can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
Laptop OFF, monitor OFF, connect the external VGA monitor to the laptop.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
There are at least 3 display options.
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
Press, and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(For an example HP's usually use the F4 key for a Display Toggle-Over key)
Display shows the same on the external VGA monitor?
You have a bad graphics chipset.
[ Some laptops have been erroneously stated as having a graphics card, when in fact they do not.
The GPU (Graphics Processing Unit) is soldered directly to the motherboard.
This is Integrated Graphics.
There is no changeable, replaceable graphics card. Therefore the solution is motherboard replacement ]
IF, the display is good on the external monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
After diagnosing with an external VGA monitor, post back in a Comment.
Also post the manufacturer name, and model number of the laptop.
Apr 22, 2012 | Computers & Internet
Keyboard lights up screen stays black....after inserting recovery disk screen still remains black...
Would like you to attach an external monitor for a diagnoses.
A VGA monitor.
Can be a CRT monitor that resembles a small TV, or a flat LCD screen monitor, that has a VGA cable attached,
1) Laptop OFF, monitor OFF, attach the VGA cable of the monitor to the laptop's VGA connector.
[For the HP Pavilion dv6000z Notebook PC, the VGA connector is on the Left side at the Rear. Second port from the rear. 15 pins.
3 rows of 5]
2) Turn the monitor on. If a CRT style allow it to warm up.
3) Turn the laptop on.
If not, press, and hold down on the FN key,
(Second key from the left, on the Bottom row on the Keyboard),
and tap on the F4 key.
(Top of Keyboard towards the left)
Still no? Hold the Fn key down again, and at the same time tap on the F4 key.
There are 3 display options;
IF, the display shows up on the external monitor, and if it is OK, the problem lies in the Display Assembly, and/or the Video Cable.
More on that in a moment.
IF, the display does Not show up on the external monitor, or if it is garbled, the graphics chipset is bad.
HOWEVER, there is a problem with the graphics chipset, for the dv6000 series of HP Pavilion Notebook PC's.
More specifically it isn't actually the graphics chipset itself, but the mounting of the graphics chipset to the motherboard.
More on this in a moment.
External VGA monitor shows a good display;
Video Cable:
The video cable is checked for apparent damage first, and at the same time, see if it's connectors are tightly plugged in.
On one end, the video cable is plugged into the motherboard.
(ALL power removed, AC adapter { Charger} and Battery, the Switch Cover is removed, and the Keyboard, far enough to lay it back out of the way. Keyboard Cable still attached to motherboard. The Display Cable is the one to the Far left, right under the left side of the LCD screen. The cable next to it, to the immediate right, is the Microphone Cable )
The video cable routed from the connection on the motherboard, up under the left Hinge Cover, and into the Display Assembly, where it then attaches to the Back of the LCD screen.
THIS connection must be checked also.
{ Just gave advice similar to this earlier. The asker's problem turned out to be a loose video cable connection, on the back of the LCD screen }
Examine the sheath of the video cable. See if there are signs of damage. If so the tiny wires inside the cable could be damaged.
Apparent damage or not, you may want to remove the video cable, and perform a continuity check with a multimeter. (Ohm's. Check each wire in the cable)
Video Cable connections prove to be tight, video cable continuity check proves video cable is OK, move on to the screen Inverter.
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED lights.
The Backlight is a CCFL for an HP Pavilion dv6000z Notebook PC.
[It is 2mm Wide, and 334mm Long. Or a little thicker than 1/16th inch Wide, and a little over 13 inches Long ]
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert power (Electricity) from the laptop, FOR the Backlight, and LCD screen.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Example of a screen Inverter for a Pavilion dv6000z Notebook PC,
The thin plastic frame that surrounds the LCD screen, and is in front of the LCD screen, (Resembles a picture frame), is the Display Bezel.
The screen Inverter is located behind the Display Bezel, and at the bottom of the LCD screen area.
External VGA monitor does NOT show a good display, it is a graphics chipset mounting issue, more to follow.
Jan 15, 2012 | HP Pavilion dv6000z Notebook
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
Broken screen, external monitor via VGA won't
Press "Fn+F7" once, wait a few seconds, and press it again, to "cycle" through all the possibilities (LCD-only, VGA-only, both).
Try the monitor with some other computer (desktop or laptop) to see if the monitor works at all.
Restart your computer -- does the initial "splash" screen (showing CPU speed and RAM-test) show? Does the "Windows" screen (with the crawling worm) show on the external monitor?
Nov 16, 2009 | Lenovo 3000 N500 Notebook
Blank screen
If your LCD is on but blank then it means its not compatible with the picture being send from the CPU VGA unless its faulty itself.
  1. Try reducing your Computer display setting to those specified as native or default setting of your monitor. Offcoz to do this you ned another monitor preferably external. Boot up your machine with an external monitor connected if it lights up the external monitor then go to your desktop (if using windows) right click select properties and goto settings and reduce the VGA card setting to those of your LCD or just lower settings. and then restart your computer without the extrernal monitor.
  2. If it does lughts up your External monitor but does not light up your LCD on rebooting then its possibly that your video cable to the LCD is broken and needs replacement or that your assuming you saying that it powers up
  3. If it fails to light up the external monitor as well then if means your VGA card is not working (assuming you used modern CRT monitor to test it). If its up to the third option you need to replace your VGA card assuming its not onboard for a laptop. If its onboard please check if your machine is working or running properly when your machine is not diplaying like making windows welcome sounds etc cause it might be just your RAM that needs replacement
P.S. Try to give more details when you ask to make your questions easier to answer and answers more helpful
Mar 24, 2008 | Acer TravelMate 4072WLMi Notebook
Flickering monitor attached to notebook.
doe syour lcd screen have pc input or dvi > also in your nvidia control panel u nee dto tell it add 720 p tv outto display manger always 60 hertz try differt resultion 1024x 768
Jan 10, 2008 | SPARKLE Computer GeForce 6600GT, (128 MB)...
Microsoft Windows Vista Ultimate Edition Logo
201 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
