Question about Dell Dimension 4700 PC Desktop
At Start up, beeps several times, won't boot.
PC beeps several times, Fan gets louder and faster and PC never boots. The monitor would stay black (not even blue). Its intermittent, and occasionally starts like there was never a problem. Other times, just beeps and beeps until I turn it off (with the fan screaming along).
  • 3 more comments
  • MsTiki Dec 01, 2007
    I have kinda the same issue. I have a Dell Dimension 4700. It boots, but the monitor doesnt. I get 6 beeps like 1234pause56. Then the AC lights are green and the BD lights are yellow. Can anyone help me figure this out. I have tried cleaning and reseating the memory and I have replaced the video card, and still the issue persist.
    Thanks for the help in advance
  • Anonymous Mar 25, 2009
    mt electricity went off and when i started my dell i had three bips and an error
  • sanjosetiu Apr 01, 2009
    PC beeps several times, Fan gets louder and faster and PC never boots. The monitor would stay black (not even blue). Its intermittent, and occasionally starts like there was never a problem. Other times, just beeps and beeps until I turn it off (with the fan screaming along). Whats causing this problem. Is this a virus issue or hardware issue?
  • Anonymous Mar 21, 2014
    Fan will sometimes spin for a second. No sounds, beeps, etc. Simply no start. Was very slow booting previously. Have checked all cables,ram tabs, etc. Everything seems in order. Someone mentioned "port quiet" was pressed hard and problem was fixed on their pc. What is "port quiet"?
  • Anonymous Mar 30, 2014
    My Gateway SX2870-UR10P beeps 11 times and will not boot up. Any thoughts
    President:
  • 2,961 Answers
This could be an overheating processor problem,dependant on the motherboard and what the beeps mean. The fan speeds up to cool it down, there may be dust collected in the heatsink on top of the processor, check it and gently brush off dust. Check that the vents on the side are atleast 6 inches clear of anything for good circulation. To see if it is an overheating thing, remove both sides of pc and run it in an open space to see if the same thing happens. While you have the side off just check your memory and other peripheral cards are all seated correctly and not loose.
Posted on Jan 22, 2007
I had the exact same problem with my wife's computer. I used my air compressor to blow it out and it works good as new. I must say I am surprised at what a low tolerance this Dell computer has to dust.
At first I did not think it would work for me because there was so little dust in the machine and hardly any on the heat sink, just a light coating. But after I blew it out it solved the problem.
Posted on Nov 23, 2008
I had this problem with an Optiplex 755, 6 beeps when I tried to turn the machine on and no image was shown on the screen.
I first thought it could be the video card, but I replaced and the problem continued to happen. Then I recalled that this problem started after we upgraded the memory for a 4GB RAM.
I noticed that after I removed one of the memory cards, the noise stopped. As posted on Dec 01, 2007, it might be a faulty memory.
Thanks,
Vesmeraldo
Posted on Feb 03, 2010
Blow the dust off the heat sinks and remove one memory card then give it a try .. replace and romove the other one.. It is likely a faulty memory card.
Posted on Dec 01, 2007
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
I have a used HP/Compaq dc5800. I reinstalled win xp pro to clean out HD. When finished I noticed the computer did not recognized the ethernet card, sound card and graphics which are all integrated. i...
You would need to look at the BIOS manufacturers site for the beep code and it's meaning. You can also pull all the hardware out, memory HDD, CD/DVD and boot if you no longer get the error, power down and add one component back and boot. Repeat until you get the beep code again and you will know what the problem part is.
Oct 08, 2012 | HP Compaq DC5800 Small Form Factor PC...
Alienware Area-51 Desktop won't boot up long beep
The fan to the left of your RAM slots needs to spin, it may be the reason for your problem. If this is the CPU fan then you may have a dead CPU.
Contact a computer technician for repair or claim warranty support.
Take care!
damnor01
Sep 21, 2012 | Alienware PC Systems Alienware Area-51®...
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
Compaq presario beeps 3 times, won't boot
3 Beeps is usually a RAM issue. Try re-seating your RAM in their slots and rebooting.
Feb 05, 2012 | HP Compaq Presario SR5262NX Desktop PC
Acer aspire sa80-9b7z won't start up. Fan starts
Firstly check the monitor, if you get 8 beeps as it is starting up, this points to graphics problems. Trying another monitor. If the problem remains, swap the graphics card or use the onboard graphics card.
If this fails and, more importantly, you are not getting any beeps (single beep would indicate your CPU is ok), the problem is likely to lie with the motherboard.
To help you further, please repost with the number of beeps if any, you get as it tries to boot up
Jun 16, 2011 | Acer Computers & Internet
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
PC won't boot (no signal and no beeps)
check the board for blown capacitors. I have found many boards from power circuits to motherboard with popped capacitors over the past 5 or so years. replace them and tada, it lives again. I've been successful several times with this operation. Please see the picture below for a guide to finding bad caps.
Jan 02, 2010 | Intel Motherboard
Monitor won't stay up
was anything else installed like memory
does your screen just go black or actually shut off
try and click f8 continuosly while restarting see if that will get you into safe mode
If not you may need to reinstall recovery again
Jan 16, 2009 | Computers & Internet
Black Monitor
Try taking out your battery and leaving it out for 5 minutes.  During boot press F2 to access BIOS to check your default video out source is LCD.  Also try Fn+F5 to change the modes of video after you think windows is all the way booted up.  Does it POST?  When booting does the drives make noise then hear a beep.  If it beeps it passed Power On Self Test.
James Mac
Sep 09, 2008 | Toshiba Satellite A105 Notebook
Dell Dimension 4700 PC Desktop Logo
1,882 people viewed this question
Clive
Clive
Alun Cox
