Question about Home
Heater unit kicks out GFI
COLEMAN hotub california cooperage pump unit runs fine on high & low circulation soon as heater is turned on runs for a minute approx.and kicks out GFI
  • 21 Answers
Most require a seperate circuit for the heater. depending on HP on the circulation pump and wattage on heater.
Posted on Dec 01, 2008
Ge 50amp gfci trips, worked great before I bought it
Hi hondo,
When an electric motor kicks on there is an in rush current called FLA(full load amps), it is usually about 125% of rated circuit amperage. Try a 2 pole 60 amp gfci circuit breaker and see if that solves your issue. Going up to this amp breaker will not be a fire hazard or cause any anomalies.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 19, 2008 | Spa Parts Plus GFCI, Circuit Breaker, 40...
Was having problems with my circulate pump for an Aurora 2 D1 tub (2005) . The tub was not heating well and the circulation was very weak. I ordered and replaced the circulate pump and got the...
commonly its the heat element that trips the breaker. find the heater connection and remove both sides. make sure to tape ends and then try the breaker...if it holds replace the element
Sep 05, 2013 | Pool & Spa
Coleman evcon presidential heater won't kick blower on.
Sounds like the automatic fan control is not working it cuts in on temp rise . It may be dirty on the back of it as you said you had a smell of dust burn
Jun 17, 2017 | Coleman Heating & Cooling
I have an older camper with an coleman mach 3 unit. it runs and cools fine at night. but it the heat of the day the compressor kicks out. after 15 mins. it starts back cooling for 15 mins or so. if i keep...
Have you checked the high and low pressure switches on the unit? If you are cycling on and off, look at your pressure switches to see if they are opening during operation. Also, when was the last time you cleaned out the condensing unit coils with soap/degreaser and clean water?
Jan 21, 2018 | Coleman Mach 15 Air Conditioner
Breaker kicks off as soon as switch is turned on
the gfci is defective from moisture even after they dry they can be defective,access the cord inside the machine and try a different cord and see if this is your problem,otherwise the pump motor could be bad,the bypass valve on the pump could be bad,if you could run it you could check current draw with an amprobe,but not if it wont start
Apr 06, 2010 | Karcher K2.26 Electric Power Washer
Jacuzzi hot tub, aero select. pops circuit breaker as soon as switch is thrown. I disconected both motors and panel. still blows. Unit is about 8 Years old. Is there anywhere I can get a schmatic or any...
Your Jacuzzi should be connected to a large GFI breaker. If it pops as soon as you turn something on, there is an imbalance between the legs supplying the power to your device. When my (small "J") jacuzzi (at about age 15) did this, I discovered a small leak that had dripped onto the circuit board and had left a deposit causing a "short". I was able to clean the deposit off of the board physically, I fixed the leak and return my tub to service.
The GFI is very sensitive and for good reason. It protects you from dangerous electric voltages, even though the danger is low.
Oct 04, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Coleman evcon dgat090bdd. New ignitor won't heat up.
Looks like 4 flashes might be high limit fault on this furnace. (I don't have a manual for this furnace, just searched online for the code meaning) Is the unit running flame at all? Is the unit running flame for a while then shutting flame off before desired temp is reached? Does the main air fan turn on to circulate air through your diffusers? Does it feel like the unit has much air flow out of the diffusers if the fan is running? Is your air filter clean? If it is infact your high limit switch, it is usually caused by not having enough airflow through the furnace and overheating occurs.
Hope this helped, let me know if I can assist you further :)
Jan 16, 2009 | Coleman Propane Forced Air Heater...
I have a coleman/evcon heat pump. When the thermostat kicks on the contacts kick in and hum but the compressor nor the fan run. Is this probably my capacitor has gone bad?
I would check the hig voltage power supply to the unit. Check the main breaker and make sure it is on. Check the disconnect and make sure there is power at that point to the condensing unit. The contactor will kick in from the low voltage in the control circuit.
Jul 11, 2008 | Coleman Heating & Cooling
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
