Question about Euro-Pro 473
Shuttle driver The first time I tried to use my new sewing machine, the thread jammed under the feed plate. I managed to remove it but the machine has not worked at all since. The problem appears to be that when I try to pull the bobbin thread up with the needle thread, it is not picking it up at all. My daughter has the same sewing machine and when I looked at it, I see that the shuttle driver is not in the same place on both machines. Help!
  • DeEtte Nov 02, 2007
    I have the same problem with my almost new Necchi. I was having some problems with the zigzag stitch missing stitches severly. Then I was sewing using a straight stitch and had a thread jam under the feed plate. I pulled it out while holding and moving the wheel to get it loose and I felt something slip. I have not been able to sew since. Help!
    I have changed the needle, replaced the bobbin, oiled the machine, taken out the shuttle and examined it (it was fine), turned the wheel again to try to reposition the shuttle...nothing worked.
  • Anonymous Jan 21, 2009
    I have a computerised elna 9000 sewing machine. the timing is off. Can someone please help me?
    Jes
Hi i have a Janome 350E thread got court undert the needle plate so i cut the thread from under the hoop and got it all out the bobbin shuttle but the machine wont sew now it seams to be out of timining as the needle is coming up to soon for the shuttle to pick up the thread can you please tell me how i can fix it as i dont have a sewing machine mechanic in town and i will have to travel up to 2 hours to get it looked at and they are really slow to get things back to thier clients.
Regards Sandim.
Posted on Aug 17, 2008
I want spre parts
Posted on Jul 02, 2009
Be very sure you have the presser foot up when you thread the machine so the thread goes between the discs, make sure the needle is in the correct way round and make sure you have not bent or damaged the needle, this will cause the hook not to pick up the thread. Ken drivewithken@blueyonder.co.uk
Posted on Sep 18, 2007
  • 202 Answers
I was going to say maybe you are putting the bobbin in the bobbincase upside down. When you put the bobbin in the case correctly and pull the thread the bobbin should turn clockwise. Otherwise since its not picking up the thread the hook point isn't meeting up with the loop as the needle rises past the hook point and its out of time. This is an adjustment for a tech unless I wrote two pages explaining it. Good luck. Rick
Posted on Aug 27, 2007
  • 3 Answers
Try "Schmetz" needles -- they are longer than other needles and the salesman told us they were required for this machine. When I used Singer needles the top thread hardly ever picked up the bobbin thread and it skipped inches of stitches. Changing to Schmetz solved the problem.
Posted on Aug 16, 2007
I had this problem and I just fixed it, your machine is threaded wrong, or the tension is wrong. Mine turned out to be a little of both. I was threading the tension wrong. I was threading it (when facing the machine) going in left to right, so it kept falling out. YOU MUST THREAD GOING IN RIGHT TO LEFT, then finish the threading process until you end at threading the neadle. NOW IT WORKS. I HOPE THIS WORKS FOR YOU ALSO.
Posted on Aug 04, 2007
If your daughters sewing machine works fine then put your shuttle driver in the same place as hers in your machine. If that dosn't work then i can't help
Posted on Jul 18, 2007
I have a janome 6600. The stitches started jamming up and breaking.What might be causing the challenge with the stitches?
Difficult to say without really seeing what's happening and which thread is breaking. If the top thread is breaking, check to make sure the thread is not wrapped around the spool pin or a thread guide.
Just some things to try:
Install a brand new needle.
Be sure to clean and remove all the thread pieces, lint, etc from under the needle plate, around the shuttle, etc. Oil as instructed in the owner's manual.
Remove all the thread from the machine. ALWAYS RAISE the presser foot when threading the top and rethread the machine from the beginning. Check that the thread path is correct and the bobbin is loaded and threaded correctly.
Be sure to use good quality thread--no Old or bargain bin threads!
Solve Most Sewing Machine Problems With These Simple Tips
Why Does My Sewing Machine Keep Jamming Sewing Made Simple
Feb 11, 2018 | Janome Sewing Machines
My machine is not catching the thread around the bobbin holder
It sounds like you have a thread jam. Depending on the machine there may be lever that will release the bobbin shuttle, and another 2 levers to release the cover plate. Pay attention to positioning so you can put it back together. Remove the shuttle, then the bobbin cover and see if there are any knots of thread getting in the way.
Oct 05, 2014 | Sewing Machines
My sewing machine does not move at all
Is the bobbin winder on? If so, turn it off.
Otherwise, is there power to the machine?
And this happened while you were sewing? Cut the thread above the needle eye. Rock the handwheel back and forth firmly to try to cut the thread jam below the needle plate with the sewing hook. If that doesn't work, open the bobbin case area of the machine and try to pull the bobbin case out, cutting any threads you can see with a seam ripper. Still won't come? Take the needle out of the needle clamp and throw it away (it's bent!), and take the screws out of the needle plate (=throat plate) and take the needle plate off after cutting any threads you can reach under the fabric. Keep cutting and pulling out any thread you find, and eventually, you'll be able to turn the handwheel. Clean all the thread bits, lint, and junk out of the area under the needle plate, the bobbin and bobbin case, and the shuttle area... there will be directions in your manual on how to clean the machine, including the shuttle area. Reassemble. Put in a brand new needle, right way around and fully up in the needle clamp. Rethread from scratch.
Always hold the thread ends behind the presser foot for the first couple of stitches of each seam.
See also: http://www.picturetrail.com/sfx/album/view/22521551
Feb 05, 2014 | Brother LS-2125 Mechanical Sewing Machine
My sewing machine is jammed the needle will not go up or down nor does the wheel
Stop! Get your camera/cell phone or whatever. Take pictures at each of these steps (to refer to later)
Remove the needle and presser foot (use scissors to cut threads if necessary)
Remove the plates under the presser foot that cover the bobbin and needle through area. Clean any thread/lint, etc from under there.
Get magnifying glass and inspect for additional bits of thread or needle ends that have broken off.
If necessary remove the shuttle race and inspect for burrs, cracks, etc.
replace everything and try moving the handwheel. If it works, it's good to go. If it doesn't take it in.
Now... when you begin sewing any seam. ALWAYS grasp both threads as you begin sewing. This will keep jams from happening and it is a good sewing habit.
Oct 28, 2013 | Singer 2263 Mechanical Sewing Machine
Out of nowhere, after working fine for weeks, the bobbin thread started breaking, and then stopped "wrapping" properly around the outside of the bobbin while I sewed. It keeps jamming to where I...
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
Check tension 3 or 4 is usually good
after you try all this & it keeps jamming then it may need to be serviced
Nov 24, 2010 | Husqvarna Huskystar 215 Sewing Machine
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
Needle will not pick up bobbin threat
Try flipping the bobbin spool so the thread comes off in the other direction.
Forcing means that the needle has been jammed against the sewing plate ant the needle is now out of timing with the bobbin pickup.
May 31, 2009 | Euro-Pro 473
Sewing machine repaired but still bunches up
Either no tension on the top thread or damaged needle plate or possibly a broken hook driver spring
Aug 26, 2008 | Sewing Machines
Fabric not feeding and jamming occurs
When this happens it is because the thread tension was not right so it gets stuck under the bobbin case and the feed dogs. Use a bigger lint brush and take out the bobbin casing and clean out the shuttle. When you rethread pull slightly on the thread before you feed it through the needle. This will make sure the thread is properly in the tension discs.
Jun 13, 2006 | Kenmore 19233 Computerized Sewing Machine
Euro-Pro 473 Logo
2,095 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
