Question about Frigidaire FRT18G4A Top Freezer Refrigerator
FREEZER NOT FREEZING REFRIGERATOR NOT COOLING
COMPRESSOR IS ON BUT THERE AINT NO COLD AIR BLOWING
    President:
  • Frigidaire Master
  • 2,651 Answers
Can you feel the compresor??? is it hot??? if this is hte case, your compressor is hot and hte fan the freezer section is still circulating warm air sounds as ifyou have a sealed system issue, 5yr manufactue warr.. (should be anyway check your manual)
Posted on Nov 30, 2008
Freezer cool but not freezing; refer cool but not cold
When the compressor is running all the time and the freezer is not cold enough, it could be the hot side can't lose the heat, see if something is blocking the radiator on the back, but most likely you lost the cooling fluid through a leak in the cooling system. When the temperature is rising slowly through the days (or hours) while the agregate is running, that will be the problem. You won't be able to fill it up yourself. The system is filled and sealed.
Apr 16, 2015 | Refrigerators
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
Water forming in freezer/not freezing correctly. Fridge bottom is not cooling. turned off fridger and turned back on, fan started back blowing in freezer but not cold air then it would stop running again
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 14, 2011 | Refrigerators
The freeezer has stopped freezing and the refrigerator it just keeping the top cool. Pushed it out and cleaned the back coils, not very dusty at all. the fan was blowing across the coils. The freezer...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Jan 05, 2011 | LG LBC22518 Bottom Freezer Refrigerator
FREEZER AND FRIDGE BLOW COLD AIR BUT FREEZER IS NOT FREEZING EVERYTHING. SOMETIMES IT BLOWS THAT SMOKEY COLD AIR OHE TIMES NOT AND THE ICE CUBES SEEM WET AND AIR INSIDE FRIDGE IS MEDIUM COLD. CLEANED THE...
heatman101
Oct 19, 2010 | Frigidaire FRT15B3A Top Freezer...
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Not getting cold enough to freeze, How to check Freon
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jun 05, 2010 | Kenmore 53082 / 53084 Side by Side...
Freezer willnot longer get cold only cool air
Do you hear the compressor humming? If the compressor does not run then your freezer will not get cold.
Aug 30, 2009 | Kenmore 54263 Stainless Steel Side by Side...
Frigidaire FRT18G4A Top Freezer Refrigerator Logo
218 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
