Question about SanDisk Sansa e250 MP3 Player
Refreshing Data each time it is powered on
I just got my Sansa and each time I power it on, it displays the "Refreshing Data" screen for almost a full minute before I can access the music. Is this normal? If not, does anyone know how to fix it? The player functions beautifully, so this is really more of an annoyance than anything, but I'd like know if there is anything I can do to bypass the "Refreshing Data" that shows up each time. Thanks million! --KelleyA
  • Tinker402 Nov 03, 2007
    i keep trying to charge my sansa mp3 player but when i connect it to my computer it turns off. This repeats over and over again. i don't know what to do?
  • Anonymous Nov 04, 2007
    mine does the same thing except i kept it pluged in for the whole day and it still hadnt loaded anymore it just get displaying refresh database. what should i do?
There is probably a gb card in the side.
And the reason it takes awhile is because its reading the card
just look in the little slot on the right side and if you see anything in there just simply push it down with your nail and put the little car somewhere safe
Posted on Nov 02, 2007
That is wierd, try formatting the player
Posted on Oct 29, 2007
It is getting stuck while refreshing the database.
Depending on the amount of the data or music files you have on your device, "Refreshing Database" may take a while to finish. But if you feel it's frozen you may try the following steps:
Reset the device 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Delete recently loaded files 1. Connect the device to the PC in MSC mode using force MSC. 2. Locate and delete recently added files. 3. Disconnect the device from the PC.
If this resolves the issue, proceed to STEP 3. Otherwise, format the device, update to the latest firmware, and reload the songs to the device.
Update to the latest firmware You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware Sansa c200 series firmware update Sansa Clip firmware update Sansa e200 series firmware update Sansa Fuze firmware update Sansa View firmware update
Click on any of the links you need more info on.
Oct 16, 2010 | SanDisk Sansa e250 MP3 Player
My sansa is always freezing up. its stuck on the "refreshing your media" screen. how do i unfreez it?
Push the power button up and hold it there for 20 seconds, this will reset the player.
If this does not work just post back for a few options.
Feb 15, 2010 | SanDisk Sansa Fuze MP3 Player
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
How do i fix the sansa clip it keeps sayin refreshing data base plz help
press and hold the power button to on position for half a minute and then trying turning it on.
Sep 05, 2009 | SanDisk Sansa e260 MP3 Player
MY SANSA HAS BEEN STUCK IN THE REFRESH DATABASE MODE AND WILL NOT TURN ON NOR OFF . IT WONT EVEN CHARGE EVEN THOUGH IT IS SHOWING A FULL BATTERY HELPPPPPPPPPPPPPP THANK YOU MRS.C.L.C.
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e260 firmware
Mine was a bit more FUBAR I guess. I have a Sansa e260. I had rockbox on it, went to switch back to the firmware. Uninstalled rockbox and on reboot... the e260 was refreshing the database and then came to a frozen green screen.
My e260 was already in MSC mode. I did the steps above but was still stuck.
The solution that worked was one posted by "Slaughter" on anythingbutipod.
The ultimate fix for all e2xx v1 problems - Format, enter recovery mode, downgrade firmware Link (you'll need to format the drive), reinstall newest firmware via newest Sansa Updater, reload tunes.
Dec 01, 2008 | SanDisk Sansa e260 MP3 Player
No picture on screen
Hi . This can probably solve your problem:
Follow the steps
01. Sansa player freezes on the “Refreshing Database” screen STEP 1 – Reset the device
  1. Slide the Power switch up and hold it for approximately 20 seconds.
  2. Release the Power switch once the device is powered down.
STEP 2 – Download and Install the Sansa Firmware Updater.
If this article did not resolve your issue, please contact us at support@sansa.com.
Oct 30, 2008 | SanDisk Sansa e260 MP3 Player
Sreen froze on refreshing data
direct us to the drivers needed to install unit on pc thanks sansa e260
Feb 13, 2008 | SanDisk Sansa e260 MP3 Player
Stuck on refreshing database...
Sounds like it's froze and needs to be reset. -
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for20 seconds.
If that don't work let me know so i can try something Else?
P.S...Please rate accordingly
Thank You
Computerrep
Feb 06, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
