Question about Dell W3201C 32 in. LCD Television
Hi, I have a 3201C LCD TV and just last night I'm experiencing the infamous "crackling and popping and no audio" issue a lot of people on fixya.com have gone through. I have 1 year left on my extended warranty. What will Dell do to resolve this issue for me?
    Problem Solver:
  • 7 Answers
Sell it in parts and buy a new tv. Cost for repair will be more than buying a new TV. I will buy the scrap for parts.
Posted on Dec 05, 2008
My father has a Dynex LCD TV, Model DX-37L130A11 Rev A, sticker says 10H07-Rev A. Manufactured August 2010, Lot #: 205204 XHT 100453. A few days ago he said the audio started emitting a loud, cracking...
It sounds like you've done quite a bit of troubleshooting, which I applaud you for doing. Have you tried power cycling the TV? Simply turn off the TV, unplug it (and any components connected to it), then plug it back in and turn it on after a minute. See if this corrects the issue. If it doesn't, then I would recommend calling our Product Support team to schedule repairs at:
U.S., Canada, & Puerto Rico - 1-800-305-2204
Mexico - 1-888-882-7326
daily from 7 am - 12 am CT.
Sep 04, 2013 | Dynex Televison & Video
Can a loss of audio through a HDTV HDMI connector be fixed?
The repair shop will have to replace the main board since not likely that they will spend a lot of time to troubleshoot down to component level and they must also have proper tools to work on the circuit board that uses surface mounted components.
If you can live without having HDMI 6, then you will be better off, you can expect $150 and up plus parts to repair your TV.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 20, 2011 | Memorex MLT3221 32 in. LCD TV
I am getting no audio from a set we purchased in Dec 2010. We have Direct TV Satelite and I truobleshooted with them and they believe it is a television issue rather than satelite. There is no sound at...
If the symptoms remain the same in all inputs like in the DVD player, then this is an indication that the fault is on the TV itself. It is caused by faulty audio/sound output circuitry in the main board. Since your unit is only 9 months old, it is still under warranty period. Avail it because the manufacturer will fix it for free. Don't attempt to open the back cover because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 24, 2011 | Vizio M260VA 26 in. HD-Ready LCD TV
Audio fades then stops after a few minutes of power
I had this problem on a sharp flatscreen lcd. the audio output i.c. was a surface mount chip-had to change complete signal board assembly,
Mar 09, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Crackling when recording with saffire
Without much info to go on I would first make sure that your input levels are not set too high when recording causing clipping and digital distortion on playback. Usually this is the thing that causes crackling sounds. Rather hard to fix after the fact and you may have to rerecord those tracks to get a cleaner sound you are happy with.
Jan 03, 2008 | Focusrite Saffire LE FireWire Audio...
Akai PT5598HD 55 in. Rear Projection
Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
Nov 06, 2007 | Akai PT5598HD 55" Rear Projection...
Dell W3201C 32 in. LCD Television Logo
188 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
