Question about Hotpoint Dryers
The drier spins but no heat
Is there an overheat reset switch on this model
  • good wrench May 11, 2010
    do you have a model #
  • 24 Answers
There is typically not a reset for heat.
Some MAY have a t-stat that has a small red button in the center that can be reset, but doubtful. If so, you need to find why it over-heated.
That said, there are many causes for not heating when it still runs.
1) Power. Motor runs on 115 V, heat on 230 V. If you have partial voltage to the dryer, this will cause your problem.
2) Heating system has many components in series, any one of which will cause the problem.
  • Motor start switch
  • Thermostats, high temp, run temp, etc.
  • Timer
  • Heating element, (most likely)
  • Wiring to all compontents
These are a few ideas.
Gary
Posted on Nov 30, 2008
Won't heat
There could be a number of different reasons for your drier not to be heating. You could start off with making sure your getting 240v to your drier. Then you could check the lint trap outside your house to make sure its not clogged. If all is good you will now have to take apart the drier and with a ohm meter check several parts. Heating element, burnt wire, limit switches, and a few others depending on the model. If your familiar with troubleshooting you can find a schematic on your drier and go from there. If not I would recommend you having a technician to come and check it.
Oct 26, 2012 | Kenmore Dryers
The dryer is blowing cold air, no heat.
Find your thermal protection switch. It looks like a big round button with two screws holding it on either side. (Make sure your drier is unplugged!) There will be a wire going from it to the heating element. It is what regulates the temperature, so it doesn't overheat. Unplug the wires off it and check across the terminals with an ohm meter. It should have full continuity. If not, it's your problem. Replace it. Easy repair.
Feb 18, 2011 | Hotpoint Aquarius WD63 Front Load...
Bosch washing machine WFT 8010 drier function not working. Machine rotates when you select drying programme but no heat??????
Some dryers have a "fluff" or "no heat" setting that spins the dryer with the heaters turned off. Check to make sure your cat didn't step on this button : ).
The most common failure modes include the main temperature regulating thermostat, overheat thermostat or thermal fuse, and heater elements. If you have a blown thermal fuse, check to make sure you don't have a lint buildup in the vent ductwork, especially right at the blower outlet. I've also seen problems with broken heater wiring and burned-out contacts in the heater control selector switch. The bottom line is that if gets to this point, you'll need to find the wiring diagram hidden inside the control panel, get an ohmmeter or continuity tester and start tracing the heater wiring.
Nov 18, 2010 | Washing Machines
Heating problem with Dryer Ariston ASL 70C
hi.
in top of the heater box there is a thermoswits back of this swicth there is a tiny little hole use a paperclip or similar an put it to the hole and press not to much until you hear a little click and the thermoswicth is reset. and your dryer can heat again:-) and DONT forget unplug the power to the dryer first.....
best regards
ls danemark.
Jan 30, 2010 | Hotpoint Dryers
I have a MAYTAG MDE5500AYW drier that spins but doesn't heat up. Any recomendations?
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My tumble drier dont heat up. It works but its
there will be a red overheat switch on the rear on most models, simply pull the machine out and press reset, the most cpmmon cause is running when empty or a build up of lint. if the doesnt work then it will be an open circuit element.
Apr 13, 2009 | Dryers
Dryer guide wheel was noisy and I opened the dryer up and found the wheel and stud badly scored. Fixed that and put machine back together and now the motor is very noisy and the machine shuts off...
you need to check the blower fan. the motor has a "D" shaped shaft. over time the blower wears, the motor will spin but the blower does not. the air flow stops and the drier over heats. replace the blower and it should be fine.
Nov 08, 2008 | Dryers
Dryers Logo
124 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
