Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
Water and shampoo run out with the trigger in the off position
In our Hoover Steam Vac Dual V widepath the shampoo and clean water run continually regardless if the trigger is pulled or not. It's unclear how the switch activates the release of shampoo and water from the tank.
  • spicyqgirl Mar 01, 2009
    SAME ISSUE HERE...BUT I THINK ITS JUST WATER....AND IT ONLY LEAKS IN THE BACK OF THE MACHINE....DOES NOT COME OUT UP FRONT WHERE IT SHOULD. AND IT ONLY LEAKS WHEN THE MACHINE IS TURNED ON.
  • 294 Answers
From your description, you have a problem with your one of the solenoids that may be stuck open. this would require a shop repair.
Posted on Mar 01, 2009
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Tom
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Water and cleaning solution will not dispense unless I hold it for a while
check the belt on the pump it should be a cover on the side pull the belt to the pump if its glazed replace if not then clean the shaft old soap may be on there.
Oct 03, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac with Rinse
The bottom tank is for the dirty water, the top tank, it has a small tank attached to it for the shampoo, clear hot water goes in the bigger tank. Then turn it on, squeeze the trigger as you pull it backwards. It will spray and vacuum up at about the same time.
Mar 05, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover steam-vac model #F7458-900 "All-Terrain"
Check the valves at the bottom of the tank(43513026)also check for cracks in the tank(42272104). Another thing to check is the handle asm. is a rod that pushs on the resevoir asm(tanks sits on) to make sure that it is stuck in the on position. Depressing the trigger and watching, you should be able to see if it is moving up and down ok.
Feb 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
644 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
