Question about Hawking HWBA11 802.11b
Default user name/password.
I lost the settings of my Hawking H-WR258 wireless router. I need the default user name and password for it, to can log in. Thanks, corzo
    President:
  • 2,961 Answers
Try username as admin and password 1234
Posted on Jan 22, 2007
    New Friend:
How to change a passward and name of wifi
Posted on Mar 17, 2013
How do i delete a bt broadband account,??
Here is how to reset your Linksys wireless router to the factory default settings in order to clear any existing properties.
  • Note: All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router user name and password will revert to the default of admin as the user name and no password.
To reset your Linksys BEFW11S4 router to the factory default settings:
  1. Hold the reset button on the back panel of the Linksys router for 30 seconds. All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router password will revert to the default of Admin and all user name information will be removed.
flioqsktle4l2on3s2rwrurpaery4ednch7fnrcft2qykek7dl9puwp12tebm2epxiv1cic0cgjbtccmwjiymzmxbli0zgzkwq5ytgrmzmeowlrkzmtdjf24rlu2laabtaaaaaelftksuqmcc
  1. When you access the router utility to change the router settings from the default values, be sure to leave the User name field blank and enter admin in the Password field.
Aug 18, 2014 | Linksys Wireless-G Broadband Router
I lost my security key, how do i recover it?
You have to enter the router's configuration page by typing 192.168.1.1 and you will get a log in page.
Default user name:admin
Default password:
As soon as you are logged in, please go to the wireless tab. You're suppose to see the security key if not you may change it to a new one.
If default user name and password rejected and you don't remember setting up your login name and password, you have to reset the router. Get a paperclip or pin and press the reset pinhole on the back of the router. It's in red color. Press and hold it down for 5 seconds. After that back to the login page by typing 192.168.1.1 on the address. This time for sure the default username and password will work. Now since you reset the router you have to run the wizard to setup the router.
Here's the link for the manual of your router.
http://www.wtrt.net/manuals/Linksys_WRT120N.pdf
Thank you!
Jul 13, 2011 | Linksys WRT120N Router
Hello, What do I have to do so that not everyonecan use the WLAN, but has to login first.
You have to setup password protection for the router.
To do this, open up your internet browser and type into the navigation bar 192.168.1.254 and hit enter.
If presented with a user authentication (login) screen, try the following:
Default Username - Hawking Wireless Router: admin (lowercase)
Default Password - Hawking Wireless Router : none (none, leave blank)
To add password protection you will have to activate WEP (a standard encryption protocol used in most routers to protect from unauthorised access).
To access the WEP information, run the Setup Wizard and then go to the Wireless region. Hint: While troubleshooting, try a 64-bit (instead of using a 128 bit WEP key or WPA) WEP key first. To avoid WEP Key mismatch (typing errors, etc.), use a simple/short (i.e. a 10 digit Hex Key such as 0123456789, 5555555555, 6666666666, etc.) WEP Key.
Write down your WEP Key so that you don't forget it.
May 04, 2011 | Hawking H-WR258 Wireless Router
I need to change the network name and password
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings. From the center screen, select your encryption type from under the Security Options heading If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Hope this helps don
Feb 21, 2011 | NetGear Computers & Internet
Is there any way to setup the Hawking Repeater without the Setup Wizard Installation disk?
Yes you can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 14, 2010 | Hawking Wireless-G HWUR54G Repeater
I want to change password for wifi network
Open up an Internet browser window on your computer system. To gain access to the default settings, type in the default IP address of the wireless router in your Internet browser's address bar and press enter. You must refer to the wireless router's documentation or navigate to the manufacturer's website for the correct IP address.
Type the default user name and password in the security dialog box that appears, then press Enter on your keyboard. Because different router manufacturers use different default user names and passwords, refer back to your router's documentation or support webpage for the correct information.
Navigate through the router administration pages to find the wireless router's administrator password settings. Change the default user name and password to a unique set so that possible unauthorized access to your router settings will not take place. Make sure to hit "Save Settings" to complete the change.
Set up your wireless security settings by navigating to the proper administration settings page. By default, wireless routers do not come with a password for connectivity access. Choose the appropriate wireless security level you need and type in a unique user name and password. Save these new settings and log out of the router's administration setup.
5
Write down the user names and passwords for both network access and the administration setup page. Keep these user names and passwords in a safe place.
Thanks.
Have a great day.
Oct 14, 2010 | Computers & Internet
I want to change the settings of my Hawking router WR-258. I don't have a user name and password so I pushed the reset button. But the user 'admin' with no password is not correct. What is the default??
When the Login pop-up for the Router
appears, please enter “admin” for the
username to access the configuration screen.
(Note: By default, there is no password. If
you cannot get in, please reset the router by
pressing the button next to the antenna on the
back of the router and try logging in again.)
Copy pasted from the manual.
Jul 29, 2010 | Hawking Computers & Internet
About a year ago a friend set up our wireless router the problem is they didnt know they were doing it and now we dont know the Password to log in on other wireless machines laptops etc i simply need to...
Log in to your router's configuration page using your internet browser by typing "http://192.168.1.1" in the address bar.
Type in “admin” for both username and password which is the default user name and password.
Click on “Setup” at the top
Scroll down to “Network Setup”
If you have forgotten the router's user name and password, and the default user name and password aren't working, try resetting the router back to factory defaults:
With the router powered on, hold the reset button (located on the back of the router) for 25 seconds. Then disconnect the power from the router and wait 10 seconds before plugging it back in.
After the reset, you should be able to login to the router with the default user name and password.
Jul 24, 2010 | Airlink AR430W Wireless Router
How do i set the password for my router
log in to the router from a web browser by typing its IP address into the browsers address bar (default IP address should be 192.168.1.1) this will prompt you for a username and password (default usernames may be admin, user, or no user name i.e. blank, default passwords may be admin or password) once logged in you can change the routers password from the 'security' tab.
May 24, 2010 | Linksys Wireless-G Broadband Router
Hawking wireless router to reset password
If you press the reset button you only make a reboot.
To reset all the value to the factory setting you have to:
- Power off the device
- Hold the reset button pressed
- While you press the reset button put the power back on
Now your gateway address is again 192.168.1.254, login is admin and password is not present (leave it blank).
Mar 01, 2008 | Hawking Wireless-G HWR54G (603992506064)...
Hawking HWBA11 802.11b Logo
314 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
