Question about RCA RT2500 System
Check Speaker banner keeps coming on
I had installed a new Samsung 47" HD flat screen TV on the wall that required me to take apart the Home thearater unit and move to another place. When I hooked everything up I would loose power when the volume got to high. I was told to check all my positive and negative connections which I dd. There were a couple of them wrong. Now what is happening the power will not come on at all. A banner comes across the screen "Check Speakers". I rechecked everything and pulled the wires out to the TV. Still nothing. I even disconnected all the wires and let it sit for an hour hoping it would reboot and still no power and still the "chk speakers" banners come on. I am hoping there is a reset button of some kind. I took the cover off and I do not see one.
Have I blown the reciever?
My wife is really upset!!!
  • 1 more comment
  • tube tech Dec 10, 2008
    Check speakers comes on and set shuts down
  • Anonymous Feb 14, 2009
    same thing happend to mine. how do we fix this
  • Lee Schoenhofen
    Lee Schoenhofen Apr 17, 2009
    Same issue. Press power and chk spkr comes up on dosplay and unit powers off.
  • 3 Answers
If you have a ohm meter plug it into the back of the speaker it should read about 5.5 ohms
Posted on Mar 26, 2009
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
Dec 29, 2015 | Samsung Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Get rid of banners on Samsung HD TV
if its burn in,try the white feature,or record a white background buen to dvd and play for 30 min with brite and contrast turn up 3/4 up
Oct 10, 2014 | Samsung Televison & Video
Philips tv smokes
Do this only if you are a qualified service technician:
This problem can come if any moisture has entered or is formed inside the TV.
Switch of the power outlet, and remove the plug. Open the back cover and check what are the parts burnt visibly. If it is in the SMPS area, you may require a thorough check on the load and replace all the burnt parts by looking through a Service Manual. Anyhow, this might require attention by a qualified service technician.
Jul 11, 2012 | Philips 47PFL5603D/27 Flat Widescreen TV...
The tv is showing a double image and I cannot get the color right! Model number 50v500
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to upgrade to the high definition cable box---but first try this. Hook the cable from the wall directly to the tv and autoprogram it. If Comcast is anything like charter they transmit the local Hd channels in a format that digital tuner will pick them up. Just channel up/down and check out the channels with -1 and -2's behind them. Depending on where you are----your local channels will usually show up wherever they normally do but with a -1 behind it.
EX: local Fox channel on 47---autoprogram and check 47-1
If this is enough HD for you then get a two way spitter and hook your box back up and keep using the RCA (composite) cables for the best it can produce.
hope this will help..
May 21, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Can u take the bit off that attatches the stand because i want to hang mine on the wall?
Yes allmost all flat screens are wall mounteable. It will require find the screws or bolts holding the table mount to tv and removing. If your tv has extra threaded holes on back then it is mountable.
Dec 31, 2009 | Samsung LN-R268W 26 in. HD-Ready LCD...
RCA RT2500 System Logo
129 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
