Question about American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen...
Spray lock button does not lock in position
New 6310 faucet. Button on handle to switch between stream or spray mode does not lock in position. When button is twisted, it seems to be forced out and does not engage with locking feature.
  • marcshaber Jan 05, 2009
    same issue doesnt lock in spraying position. worked fine until i cleaned filter
  • James Feragola
    James Feragola May 11, 2010
    How is the water pressure?
    Make sure the shutoff's are both open all the way.
  • 68 Answers
Sadly not much to be done there but replace the head
Posted on Feb 07, 2009
Stream suddenly switches to spray function without pushing the button
Have you checked to make sure the switch is fully in one position or another? It maybe be closer to the middle of switch?? It could be old and worn out?
May 19, 2014 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Hansgrohe talis s stuck in spray mode
Some disassembly may be required to determine the cause of the stuck button and fix it. There may be mineral deposits preventing proper operation.
Jan 20, 2014 | Plumbing
Have a Blanco single-handle pull-out faucet with single-stream and spray option. Spray option can be turned on and off with a twist switch on top of the faucet. Our faucet is now stuck on spray option and...
Unscrew the part where the water comes out and remove the enterior parts paying close attention to how and the order in witch the come out so you can clean everything good and put it back together and pay close attention to the twist switch and how it operates. This shought fix the problem your having.
Jun 30, 2011 | Blanco Classic Single Handle Faucet with...
I have a Delta kitchen faucet Palo 467 series. I am having a difficult time switching between spray and stream on the wand assembly. Occasionally it will "lock" into one position or the other and...
Are you using a softener in your home? Sometimes hard water deposits can clog up the cartridges and create the problems you such described. Im not sure about the lock/button issue though since I have never used this particular Delta faucet myself, but with one problem, it can usually cause many others.
Try replacing the cartridge on the Delta faucet first, Here is a link to the replacement one from the Delta site. http://www.deltafaucet.com/repairparts/details/RP50587.html
Here is a link to Delta warranty and lifetime guarantee. http://www.deltafaucet.com/customersupport/warranty.html
Here is a link to the Delta page with lots of useful information on your product. http://www.deltafaucet.com/kitchen/details/467-DST.html
Ex-Plumber
Hope this helps-
J.Sper
Mar 06, 2011 | Delta Faucet Delta 467-SSSD-DST Palo...
My Blanco Torino faucet is leaking under the button when you press the button on top to use the spray.
Check the hose connections at the spray head nozzle it sounds like it is leaking there and running down the hose and ending up under the sink.
Feb 08, 2011 | Blanco Classic Single Handle Faucet with...
Faucet dripping
Call Price Pfister at 1-800-PFAUCET and ask them to send you a new hot and cold stem for free. These faucets are easy to repair. Here is the parts breakdown for your faucet. Turn the water supply of to the faucet. Remove the index button from the top of each handle. Unscrew the handle retaining screw. Pull the handle off. Unscrew the stems with an adjustable wrench; turn them counterclockwise. Install the new stems and reinstall the hanldes; it may take a couple of times to get them set in just the right positions. Slowly turn the water back on and open the faucet.
Sep 05, 2010 | Price Pfister Savannah Two-Handle Kitchen...
Small streams of water spray come out at an angle to the main stream causing water to spray over the sink and wet the operator. In checking the filter I find it to be clean with no obstructions. The errant...
You need to reduce the pressure to the tap, if you look at the isolator valves beneath the tap, using a screwdriver turn the isolator valve screw until it stops spraying.
Ihope this helps
Jul 07, 2009 | American Standard Kitchen Faucet 6310 020...
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen... Logo
234 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
