My car radio asks for the code every time i use it. once the engine is running i can turn the radio on/off without putting in the code. Once the engine has been turned off i need to re-enter the code Can you tell me what the problem is? Thanks
  • garryp Dec 01, 2008
    Thanks very much WolfenHawke i will give this a look
    Problem Solver:
  • 13 Answers
Check your car battery (either at a service station or by checking it's voltage if you have a voltmeter). The radio's anti-theft is triggering. This triggers when the battery has been disconnected; but if the voltage goes down (likely when you start your car), the radio may trigger the power disconnected alarm.
Posted on Dec 01, 2008
  • WolfenHawke
    WolfenHawke Dec 02, 2008
    BTW, Your battery is 12v but really registers 13.8v when good and could go higher when the car is running. If it is reading less than 10v when nothing is on, that's a bad sign. Also, check all the cells for fluid. Fill as necessary with distilled water. Often a battery fails on one bad cell. This cell will discharge faster than the others. It's hard to check this without a hydrometer, but a service station will be able to. A symptom may be low battery voltage right after starting your car.
How do i install a new radio
The process is very simple, just follow these steps and you'll be on your way to listening to your radio again. First of all don't think you need to unscrew anything. The wood panel surrounding your stereo snaps out by pulling on it or using a flat screw driver at the corners. Once you have taken the panel out, you can see that the radio is held in by 2 hooks. Push up and pull forward slightly. You don't have to pull out the entire radio because you can see the serial number on the top surface very easily. Write down the number next to where it reads s/n. Once you have the serial number, call the local dealership and give them your serial number. They will in turn give you a four digit code number that you will enter on your radio. One thing to note is that if you have entered the wrong code number 3 times, your radio would lock up and it would read "OFF". To unlock it, simply park your vehicle in a safe place and leave the radio on for about 1 hour (no engine running just click the ignition switch to operate the radio). After one hour, the radio resets and will ask you again to enter the code. start entering one number at a time using the first 4 buttons. Example, if your code is 4538, you would push button 1 four times to get to the number 4, you would push button 2 five times to get to the number five and so on.. After you have entered the correct code, push the CD button and there you have it.
Feb 22, 2012 | 2002 Mitsubishi Galant
Hi, I have a 1987 Chevy Cavalier. Currently the muffler isn't properly hooked up and the check engine light is on. It starts after multiple attempts and stalls out once you put the car in drive. Once you...
You need to start by getting the code on the check engine light. You can buy a cheap one at Autozone for about 30-40 dollars. This will probably let you know where to look or where to begin. I would do this first. It will save you time and money in the long run.
Feb 23, 2011 | 1987 Chevrolet Cavalier 4 Door
My radio comes up with a error message when I turn it on to put the code in.
Remove the power offf the radio and let it reset becasue an error code would have made it faulty.
Once you reconnect put in the actual codes and see if this works.
If not the radio processor has errrors. power off for more time and reconnect.
Sep 24, 2010 | Car Audio & Video
How to reset brake light after changing pads.
Hi Peters6709,
Sorry to tell you, but you need to replace the pad-wear sensors as well. They are the little trapezoid pieces that hang inside the tops of the inside pads. They should run about $10 each. Once replaced, disconnect the battery completely for about 10 minutes, if you have a stock radio keep the code handy.
Next time check the pads every 10-12K miles. I have been running the SAME pad wear sensors on my Z3 for the past 2 pad changes now after making the same mistake the first time.
Best of luck!
May 02, 2010 | 1999 BMW 323 Series
My s70 1198 volvo's radio says off what do i do??
You have to put the battery on a charger and leave the key turned to the accessory position, meaning the car is not running but the radio still displays off. You will have to wait approximately 50 minutes to 2 hours till the word "code" is displayed.Once that has occured, you can put in your code and it will work. Or you can drive around for that length of time until it says code and you will input the correct code and you radio will work. I did this on a long trip.
Apr 07, 2009 | 1998 Volvo S70
2000 chevrolet s-10 radio inoperable
believe it or not you have to take it to the dealer to unlock it. Plus before you go there you have to leave the truck running for 30 minutes without touching the radio to get it out of inop mode. The radio got put in inop mode from loc mode by putting in the wrong code 3 times in a row. Once its out of inop you can take it to the dealer and they can call gm and get the unlock code for the radio (should cost 30-45 bucks at most dealers)
Mar 30, 2009 | 2000 Chevrolet S-10
Correct radio unlock code not working on 1995 Honda Accord
One of these ways will work. Try this first. Remove the negative battery cable and leave it off for 5 minutes. Hook it back up and then enter the correct code. If that does not work, just turn the radio on, and drive around for one hour. The radio will reset itself and you will then be able to insert the code.
Feb 23, 2009 | Jensen VM9510 Car DVD Player
How do i get the cod to enter the code on my radio
have you got radio code & if its saying code you need to leave on until 4 digits appear once they appear to put code in for example if code was 3313 you would press no 1 on your panel 3 times then you would press no 2 again 3 times no 3 once & no 4 3 times once you have done that press no 5 to enter code if all goes well your radio should work ok if not you might have wrong radio code let me know how you get on.
Feb 02, 2009 | 2001 Ford Focus
Stereo is asking for a code
Here is the answer to the best of my knowledge. This applies to any body that has the need to get the code from the dealership and requires to pull out the radio and look up the serial number. The process is very simple, just follow these steps and you'll be on your way to listening to your radio again. First of all don't think you need to unscrew anything. The wood panel sorounding your stereo snaps out by pulling on it or using a flat screw driver at the corners. Once you have taken the panel out, you can see that the radio is held in by 2 hooks. Push up and pull forward slightly. You don't have to pull out the entire radio because you can see the serial number on the top surface very easyly. Write down the number next to where it reads s/n. Once you have the serial number, call the local dealership and give them your serial number. They will in turn give you a four digit code number that you will enter on your radio. One thing to note is that if you have entered the wrong code number 3 times, your radio would lock up and it would read "OFF". To unlock it, simply park your veichle in a safe place and leave the radio on for about 1 hour (no engine running just click the egnition switch to operate the radio). After one hour, the radio resetes and will aks you again to enter the code. start entering one number at a time using the first 4 buttons. Example, if your code is 4538, you would push button 1 four times to get to the number 4, you would push button 2 five times to get to the number five and so on.. After you have entered the correct code, push the cd button and there you have it. I hope this helps.
Sep 20, 2008 | Mitsubishi Montero Sport Cars & Trucks
Radio unlock code
try taking the unit out. there is a sticker on it with a serial number
call your dealer and tell them that you need a code " service department "
they will ask for the serial number on the radio
once you give the serial number they will look it up and give you the code
do not try to put a " random " code this will lock your radio and you will have to unlock it before putting the code in it.
if the screen shows " code " you are fine, just get the code and voile.
if your screen shows " waiting " the radio is locked up and i will assis you on that matter once you get the code.
May 20, 2008 | 1997 Cadillac Catera
 Grubhead
Grubhead
