Casstee belt broke
Where cani get a belt for the casstee player?
srs
  • 4,234 Answers
The use of rubber bands is at best foolish. Belts are still available for most models. If you can supply the model number, I will cross reference the belt size and post a supplier and cost.
Dan
Posted on Dec 03, 2008
  • ABRsvcs Dec 12, 2008
    Rubber bands are not quality controlled for proper sizing and will not keep a cassette at the proper speed. Quite often you wil hear variations in speed. Belts are still readily available for around $1-$2 depending on the belt. Any repair shop that uses rubber bands for repairs is not a quality shop IMO.
    Dan
  • 905 Answers
Got spare rubber bands? thats what i use for cassette tape players that are to old to get the belt for anymore
  • jason Dec 03, 2008
    I have used rubber bands many of times and there has never been one to come back! and what do you think belts are made of ?
    you could pay alot just to get the belt , if its available , and then if it breaks , you will be paying and waiting again. ( for nothing but a rubber band! )
    my tape cassette has been running with a rubber band for 4 years!
    so using a rubber band is NOT foolish!!! "abrsvcs"
    and a bag of rubber bands are only about a $1 ! minus shipping and handling and a manufacturers cost!!!
    just make sure that the tape players mechanisms and gears are lubricated adequately , and you should not have any problems!
What does the red symbol like a driver with a ball in front of him means on the dashboard
This is a air bag fault light .it comes on when you have a fault in the air bag system.
Feb 19, 2017 | Cars & Trucks
Why does red srs light stas on ? on mercedes c240 19999
The srs light(Supplemental Restraint System) indicates there is a fault some where in the airbag or seat belt system. It could be a matter of one of the seat belt switches is stuck inside where the seatbelt clips into.
Mercedes Class SRS Light Quick Fix
May 20, 2014 | Washing Machines
Toyota Echo 2003 SRS light with ABS light blinking instead of Seat Belt Light
When you sit in the seat and put the seat belt on does everything work ok . If so look to the fact that you are required to wear a seat belt and the fact that you are not might be the problem.
Mar 09, 2014 | Cars & Trucks
Reset srs light after replacing seatbelt
To reset the SRS light on an Acura Integra, pull down the SRS service connector. Unplug this connector so you have access to jump the harness. Start with the ignition OFF. Jump the SRS plug. Turn the ignition ON. The SRS light will come on then off.------------------------------------------------------------------------------
autel maxidas ds708
Jan 14, 2013 | 2007 Ford Explorer Sport Trac
Ac pulley
The pulley can be replaced you can't get another belt, they do not make one. Even cars without AC have the same belt, in the place of the AC compressor is a "AC Delete" pulley.
Jun 12, 2012 | 2000 Dodge Caravan
HI the SRS trouble light is on on the dash,
Hi, this is usually caused by an accident. What happens in such a case is the pre-tensioners in the seat belts are activated when the impact sensors are activated. The SRS control unit is blown when this happens to make sure that the SRS system operates correctly after repairs. You will need to replace the SRS control unit and the seat belts.
Nov 24, 2009 | 2000 Honda Civic
1995 toyota corolla dx ac probelm
Well if the fuse is blown, replace the fuse. Check the belts to see if one broke and replace it.
Mar 30, 2009 | 1995 Toyota Corolla
Srs airbag light is on on my 99 pontiac grand prix
If the seat belt light comes on intermittently with the belt buckled, it may have a bad switch in the buckle or a loose connection @ the switch. This may also set a diagnostic trouble code in the srs control module & keep the srs airbag light on.
Mar 27, 2009 | 1999 Pontiac Grand Prix
Srs light come on
hi,send your car to dealer to scan the problem,maybe erase fault is require ,or you can found the exact defective part,ty
Mar 23, 2009 | 2002 Mercedes-Benz C-Class
Camcorder wont playback
SOUNDS LIKE YOUR CASSTEE COMPARTMENT IS BAD.. TRY CLEANER CASSTEE.. MAYBE THIS WILL PROLONG THE AFFECT. LET ME NO IF THIS HELPS
Feb 28, 2008 | Video Cameras
120 people viewed this question
 Grubhead
Grubhead
