Question about Carousel Airblown Inflatable Christmas Santa Express Train
Airblown Christmas Carousel won't turn inside....
Our little kids are so disappointed that the inflatable carousel won't turn inside.....any body know how to fix this problem???
  • 2 more comments
  • cmojmo Dec 03, 2008
    We have the same Carousel and it no longer rotates. It seems like there would be something we could do.
  • forest_green Dec 18, 2008
    Thank you Mike. I will try it. I hope the weather co-operates, it is below freezing here now. I now realize that these beautiful fun decorations are not meant for our climate here, but I just love it so much.
    Merry Christmas from Montreal, Canada!
  • forest_green Dec 21, 2008
    I tried both suggestion, and even changed the tie rods and it sitll doens't turn....perhaps next year. I will work on it in the summer when it is warmer. We are getting another 30cm of snow today, I now realizet that these were not made for our climate! Merry Christmas Everyone!
  • Melonie Holcomb Dec 17, 2013
    we also have this carousel, we had a day of rain a couple of days ago and there was water inside the outside scallops or blow up ribbon around the top. next day water has drained out but now it won't blow all the way up. it wants to rotate but there has to be some a leak or something. worked fine until it rained. i looked inside and the inside zipper was unzipped, thought that was the problem but it still won't blow up enough on the front to let the reindeer or (doxies) turn so it just clicks, don't think i will ever buy one that is animated or this large again. wish i could fix it
Open the Zipper on the Top. Take out as much of the center piece as possible. At the bottom of the center piece you will find two Cable ties attached to a plastic pipe. Carefully cur the Ties be carefull not to cut the Center Piece material. Remove the Center piece and unfurl. Put two new Ties in the Center piece loosely and put reattach the center piece to the pipe. Then tighten the ties below the Ribs on the Plastic Pipe. Cut off excess Tie, Close zipper and inflate the unit.
Merry Christmas from Ireland
Posted on Dec 18, 2008
  • Mike Mon Dec 18, 2008
    The reason the problem occurs is when you deflate the unit in wet conditions,the center piece becomes saturated and is too heavy to inflate. Merry Christmas
I have the same one and when I went to put it up this year it would not turn either. I had to open the ziper at the top and pull eveything out to untwist it. I also held it (the big white turner in the top) so it didn't move while it was blowing up.
I hope that helps!
Posted on Dec 03, 2008
I used this site it is full of info and is company who made mine. hope it helps. You can email tech support as well.
http://gemmy.com/customer-service/Airblown%20Inflatables/Airblown%20Inflatable%20General%20FAQs
Posted on Sep 14, 2011
Our carousel rotates backwards one time than the next it will go forwards.............Very very strange
Posted on Dec 11, 2009
I had this problem ,ok heres how i got mine to turn again .at the bottom and top of the center piece are plastic tubes that rottate around spray wd40 on both they must be lubricated in order to turn i just fixed it its working perfect....Joe
Posted on Dec 01, 2009
It's not fixable. My husband tried everything.....
Posted on Dec 01, 2008
My Carousel wont blow up all the way
Happened with bounce house and santa just check the motor and it probably doesnt have enough power or it has a small hole in it
Hope I helped ;)
Dec 23, 2010 | Carousel Airblown Inflatable Christmas...
The Carousel doesnt inflate complety, I already check everything and I really dont find the problem
check out this site: http://gemmy.com/customer-service/Airblown%20Inflatables/Airblown%20Inflatable%20General%20FAQs
Dec 19, 2010 | Carousel Airblown Inflatable Christmas...
How do I patch holes. There seem to be a couple causing part of the carousel not inflating
I used gaffer tape, seems to work perfectly. Adheres well and it's stronger than the original material anyway. Hope this helps.
Dec 09, 2010 | Carousel Airblown Inflatable Christmas...
We have a Gemmy airblown carousel with four figures inside. It will only partially inflate. We have unzipped everything and untwisted everything. The bottom inflates and part of the top but nothing in...
mine is doing the same it gets twisted cutting off the air supply. I unwind it and lubed it but it continues to happen. there seems to be some sort of spring on the inside at the based. i'm thinking of cutting the tie straps and seeing whats inside...
Nov 29, 2010 | Carousel Airblown Inflatable Christmas...
Have a airblown carousel and it wont fully inflate please help me
Airblown inflatable will not inflate properly after it is a couple years old.
Nov 29, 2009 | Carousel Airblown Inflatable Christmas...
Airblown inflatable santa train. It will not
I installed my outdoor christmas lights, they lite up fine and about an hour later they stopped working
Nov 24, 2009 | Carousel Airblown Inflatable Christmas...
Need light bulb for Gemmy 6ft inflatable carousel
Go to the website holidayinflatables.com or buyinflatables.com they carry parts for inflatables.
Dec 07, 2008 | Carousel Airblown Inflatable Christmas...
Carousel Airblown Inflatable Christmas Santa Express Train Logo
2,027 people viewed this question
Top Carousel Toys Experts
SteveAlaska
Are you a Carousel Toy Expert? Answer questions, earn points and help others
