Question about Spectra Logic Hello Kitty 13" TV
Our Hello Kitty TV/DVD has never played a DVD properly. It says
"wrong disc" when you try to play the DVD. I took it to a TV repairman and he says he thinks it needs a whole new drive, but he doesn't know what brand it is to replace it. Can anyone help me?
2 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: blue screen-tv doesnt recognize dvd player
Hello crawf and Saffyrre,
I have seen this issue before, and I have good news and bad news. The good news is the problem is caused by an electronic bypass circuit, The circuit is between the AV derived from the RF input connector (for cable TV and off air TV) and the AV derived from the DVD player Audio Video input jacks. Hence the problem of being able to plug the DVD into other TVs and it works. Now my question to each of you is; Does the TV work on off air and or Cable TV.
This might range from a cold solder joint on the circuit board, to a component actually going bad. I would suggest taking the set to a qualified TV repair shop and getting an estimate. If the cost is right have it repaired, if the cost is not right replace the TV with a new one.
If you do decide to replace the TV could you both send the bad TVs, so as I could figure out what is causing this problem, design a fix for it and then provide an actual online solution to this problem because this is happening way to much for it not to be a systemic problem with all of these Hello Kitty TV sets.
Thank you both,
I hope this helps,
Shuttle83
Posted on Nov 25, 2007
My Emerson MO # ld320ems TV/DVD combo will not play DVD
Most likely the laser light is burned out, scrap it.
Jul 15, 2018 | Emerson Televison & Video
I load the disc in my player, and I get audio, but I get no picture. What am I doing wrong?
Hello sir in which player are u trying to play it ??? Whats the video format ???
Mar 13, 2008 | Televison & Video
DVD/VCR WILL NOT PLAY DVD DISCS
* check your warranty and call for service.(But it looks like this is a very old unit if it's a VCR/DVD combo.
* Pull plug and count to 10. Reconnect.
* check power lights. Does it say Ready, blinking time (12:00), any indication that power is on? No lights? Bad unit. Discard.
* If power okay, press open tray. Opens? Remove Disk. Insert "Known" working DVD (use a new store bought DVD that the kids did not play.) Press play.
* Is the disk reading? The DVD display should have changed while searching disk. No? Discard unit.
* Is it playing (the movie time should change as the movie plays). No video? Check cables to TV
* No sound? Check audio cables to TV (Red and White RCA Plugs)
* DVD and VCR plays disks or tapes but nothing on TV? Does the TV have an "Analog" input? Newer 2018 TVs may only accept Digital input like HDMI. A few may have the Video/Audio RCA plug input (usually used by the DVD player) though Digital TV's tend not to have this input.)
* You may need to have your old VCR tapes digitized (especially family tapes) There are "Analog to Digital" cable sets available at your electronics store or online at Amazon.com
https://www.amazon.com/dp/B06XJKSJZ8/ref=sspa_dk_detail_4?psc=1&pd_rd_i=B06XJKSJZ8&pd_rd_wg=gXyiO&pd_rd_r=YRNMX4PQ9FDXJNVGV81H&pd_rd_w=AMvcC
https://www.amazon.com/EAS-Grabber-Capture-Converter-Digital/dp/B077GPNXYJ/ref=sr_1_4?ie=UTF8&qid=1529364181&sr=8-4&keywords=Analog+to+digital+video+cable&dpID=41fex8sIlEL&preST=_SY300_QL70_&dpSrc=srch
* You may still find DVD players at thrift stores for under $20. I'm not sure if you can still find a new player.
* Try WalMart (Humm... no price given.)
https://www.walmart.com/ip/LG-DVD-Player-with-USB-Direct-Recording-DP132/33396346
Aloha, ukeboy57
Jun 18, 2018 | Televison & Video
DVD disc reads that it is playing, but there is no
what tv connection are you using from the dvd make sure connection are fully pushed in, try another dvd player with the same tv and connections.
Aug 25, 2009 | Zenith XBR616
WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
TV says WRONG DISC TYPE
is the dvd a store bought disc or a burnt dvd? If the disc is a store bought disc I unfortunately can't help you. But if the dvd you are trying to play is burned from dvd burner you are most likely using the wrong type of burnable dvd. There are two types of dvd's you can burn, DVD-R and DVD+R. You need to make sure which one you dvd player can play, some play one or the other, some play both. I have also heard of some older ones that can't play any type of burned disc. Hope that helps Peter
Aug 18, 2007 | RCA T09085 9 in. TV/VCR Combo
Spectra Logic Hello Kitty 13" TV Logo
43 people viewed this question
Top Spectra Logic Televison & Video Experts
Marvin
Marvin
Are you a Spectra Logic Televison and Video Expert? Answer questions, earn points and help others
