Question about HP Office Equipment & Supplies
No Instructions for all of the features
I purchased a HP J3640 and the only instruction book was for getting started with the fax, but no info on how to use the copier, printer and scanner. Should there have been instructions for these features? Thank you, Jerry L Hodson
  • 65 Answers
Here is the user manual
and here is the setup guide
They are the same for the 3600 series.
I hope you find this information helpful.
Posted on Nov 30, 2008
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
I would like to disable or remove the fax on my J3640 all-in-one
The Fax option in your printer is inbuilt and is activated or Initiated only when you connect the phone cord to it.
If you do not want to use the Fax feature in the pc, All you need to do is "DO NOT CONNECT THE PHONE CORD TO PRINTER "
Jun 24, 2010 | HP OfficeJet 6210 All-In-One InkJet...
How to scan using hp4550. Need simple instructions. Only FAX info in box.
You need to make sure you load the scan software into your computer, and then when you select scan the software starts allowing you to select the type of image you are scanning and where and how to save it. For better instructions go to www.partsurfer.hp.com and get the manual from the support area for no charge.
Apr 21, 2010 | HP Officejet 5610 All-In-One InkJet...
I have lost my manual for the hp laser jet i need step by step instructions on how to change the speed dial numbers
Here is the Technical Reference Manual for your Printer. As you can see below, your add numers to the Fax Phone Book, within the HP ToolBoxFX.
GOOD LUCK
Fax Phone Book
Figure 2-42 Fax Phone Book screen
Use the Fax Phone Book screen to add and remove individuals or groups on your speed-dial list, import
phone books from a variety of sources, and update and maintain your contact list.
Feb 18, 2010 | HP LaserJet 3050 All-In-One Printer
I cant seem to set up my fax for incoming
Uninstall printer prog restart, then reinstall printer programme. This time sit with computer while prog installs, it will ask you question once whole prog installs, you most likely missed the information to install for the fax part?
Nov 01, 2009 | HP LaserJet M1522n MultiFunction Printer
SETTING UP MY HP ALL IN ONE FAX MACHINE
Fax (HP LaserJet 3050 allin-
one and HP LaserJet
3055 all-in-one only)
● Full-functionality fax capabilities with a V.34 fax; includes a phone book, fax polling, and
delayed-fax features
For more information, see the online user guide.
I Hope this is good info for you.
See www.hp.com for the users guide.
Jan 07, 2009 | HP LaserJet 3050 All-In-One Printer
Need instructions for fax features
Use the manual AR-F151 it seems to use the same functions as the AR-F152
I set up my fax machine using this manual, and all the instructions worked so far.
Good Luck,
Bob
Jan 05, 2009 | Sharp AR-F152 Fax
I have no instructions other than for the fax, nothing on printing,copying or scanning. For my HP J3640
Go to the HP website and select Support and Downloads. Then specify your printer and select the information you need.
Nov 29, 2008 | HP Office Equipment & Supplies
67 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
