Question about Kodak EasyShare CX6445 Digital Camera
Stuck lense on Kodak Eastshare camera.
I dropped my camera the other day and now the lense won't come out and the shutter won't open.When I put it on the dock it makes a sound as if it's trying to work but to no avail.HELP - I need my camera for ebaying!!!
    Genius:
  • 2,985 Answers
The machanisim is broken Arepairs is not likely or will cost nearly as much as a new camera. So go for a new camera
Posted on Jul 19, 2007
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
My father dropped my Kodak camera into the sand and it won't work now
If there's sand in the mechanics of the shutter flap and you can hear more that's stuck inside, there's nothing you can do except take it to a camera technician. It'll need to be disassembled, thoroughly cleaned and reassembled.
You will more than likely do more damage if you try turning it on or shaking it to get the sand out.
Sorry to hear about it!
Aug 02, 2012 | Kodak Md863 Easyshare Digital Camera...
My sons kodak easyshare cx6230 only takes black/blank images. Screen works, but all photos taken are black. Suggestions please?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 06, 2011 | Kodak EasyShare CX6230 Digital Camera
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
Shutter is stuck halfway. when i open the lense the shutter drop. what can i do? please help me. there are no service center in my locality.
shutter is stuck halfway. when i open the lense the shutter drop. what can i do? please help me. there are no service center in my locality.
Dec 19, 2010 | Nikon FM10 35mm SLR Camera
When i turn on my camera the lense extends but you can not see thru neither the lense or the remote screen. please help
Jul 15, 2010 | Canon PowerShot S2 IS Digital Camera
It appears that pictures are being taken with the lens cap on - when that's not the case. In other words all camera indications are that the picture is "taken", but it is a black square. I'm thinking a...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Jan 12, 2010 | Kodak EasyShare DX4530 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
Kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 08, 2009 | Kodak EasyShare V1003 Digital Camera
HELP! dropped camera, lens won't go back in, shutter won't close
Tapp the lense GENTLY in the opposite direction of the misalignment
Nov 25, 2007 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare CX6445 Digital Camera Logo
71 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
