Question about Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite h4 washer fh code
After washer fills and washes 5 minutes into cycle it drains and F/H code is displayed. The washer drains properly with no restrictions, trap is clean and screens at inlet are clear. Water pressure is 80 lbs pressure. This happens every couple of washings then it is fine.
  • rhode99 Nov 30, 2008
    I am not using stainless hoses and they do not have the safety shut off. Water flow is fine as it is the same thru out the house. I watched it cycle and to me it is getting enough water so I dont know...
    President:
  • Whirlpool Master
  • 2,651 Answers
F/H is a no water fault code, so i would recheck your incoming water supply, or look to a problem with the inlet water valve.. if your using stainless steel hoses, form the manufacture lableld FLOOD SAFE, these maybe your issue as well they have a buitl in water shut off, htat may be failing preventing water from entering
Posted on Nov 30, 2008
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
I ordered and bought the control panel part for my kenmore elite front load washer but the washer is still not washing it's flashin FH
fh is a water problem,does it fill with water?....... FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1HSpZo0dW
Mar 23, 2011 | Kenmore Elite 45986 Front Load Washer
How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Nov 28, 2010 | Kenmore Washing Machines
Kenmore Elite HE3 Error FH I forgot to turn the water hoses on when I started a load. The FH error sounded at 33 minutes of a 45 minute cycle. I can't reset the machine now. It is stuck. It is unplugged....
according to kenmore, you should press the "pause/cancel" button twice and it should release it.  it may also have locked up the CCU, central control module and might need to be replaced.
Aug 02, 2010 | Kenmore Elite 45986 Front Load Washer
Error code fh the and the machine would not drain
I know you said you had done all this, bhut these are the commentsstraight from CD manual.
Kenmore Elite 2 front loading washing machine. About every 2 minutes the cycle stops and flashes an "f" then an "h" on the display over and over again. **
That error code can be the result of no water detected entering machine after 30 seconds or pressure switch (water level control) activation not detected after 8 minutes of filling.
If there is no water in the machine at the time, make sure that both water taps are turned on, check for kinked fill hoses or plugged sediment screens in them and verify the water fill valve operation. You can read about the water valves used on appliances at the following link:
LINK > http://www.appliance411.com/links/jump.cgi?ID=801
If there is water in the unit, verify drain pump and water pressure switch are operating properly, the pressure switch hose is in good condition and properly connected to the pressure switch. Also, make sure the water is not siphoning out of the machine prematurely due to an improperly installed drain hose (see the following link).
LINK > http://www.appliance411.com/links/jump.cgi?ID=534
That error might also be caused by too much suds in the wash water like can result from using non-HE detergents.
please rate this help to keep the service online
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 02, 2009 | Washing Machines
Washer won't transition to wash cycle. Flashes FH error code.
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem.
Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 flashing FH
The following link explains the "FH" error:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This can be a rather tough one to figure out, even with the error code explanation. I would recommend unplugging the washer for AT LEAST 30 minutes first. This will reset the Central Control Unit (CCU). In many cases this is all that is required to correct momentary glitches with the unit. If the error code reappears, check your washer installation to rule out the easiest possiblities, first. This means checking to ensure you don't have a siphoning condition, checking your drain lines and checking to ensure your fill hoses aren't kinked or clogged. Read through the link thoroughly and let me know if you have questions. I hope this helps you.
Jan 09, 2009 | Kenmore 46462 Front Load Washer
Kenmore Elite HE4T washer
Get the same code 2 minutes into cicle. F H
Nov 03, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
350 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
