Question about Saeco Vacuums
I have a Saeco Armonia Espresso Machine. The water pump was running when the tank ran out of water and when I refilled the tank, it wouldn't start again. I unpugged it and turned everything off overnight. The pump is very loud and won't pump any water.
Common on Armonia...
There is no water in the system, so the pump is pumping air!!
you have to push on the usual button but make sure the hot water button (for tea for ex) on the right side (same as steam opening valve) of the machine is open. This will allow the water to re-flow through the system. Once water is coming out again, close hose, and stop water button. Once hose is closed, and you repush the water button, it will flow again through the coffee hole.
Voila
Posted on Nov 18, 2009
Cleaning mr coffee ecm3 how
Deliming
SUGGESTED CLEANING SCHEDULE
Type of Water Cleaning Frequency
Soft water every 80 brew cycles, Hard water every 40 brew cycles
Your espresso maker may be delimed using one quart of white household vinegar. Clean the water tank first, following steps l-5:
1. Make sure the steam control knob is in the center off position and that the plug is disconnected from the electrical outlet.
2. If the machine is cool and the pressure has been released, remove the pressure cap and pour 10 ounces of undiluted white household vinegar into the water tank.
3. Screw on the pressure cap and allow machine to sit overnight with the vinegar solution in the water tank.
4. Remove pressure cap and discard vinegar through the top opening of the espresso maker.
5. Rinse the water tank thoroughly with tap water, repeating this step twice.
To wash internal parts:
Make sure you clean the inside of the water tank first. Remove the pressure cap and pour 10 ounces of fresh white household vinegar into the water tank. Screw the pressure cap back on top of the water tank. Make sure the cap is on tight. Insert the filter holder into the brew head and place the glass decanter with lid on the drip tray. Plug the machine into the electrical outlet and turn the power switch on. An indicator light on the power switch will tell you the machine is on. Place a cup with cold water under the steam nozzle. When vinegar begins to flow into the decanter, insert the nozzle into the water and open the steam nozzle slowly by turning the steam control knob downward. After a few seconds, close the steam nozzle by turning the knob back up to center. This will clean any residue left in the nozzle from frothing milk. When all the vinegar has been pumped into the decanter and the flow has stopped, turn the power switch to the center off position and allow the machine to cool. Repeat steps 1-7 twice using only tap water to rinse any remaining traces of vinegar out of the machine.
Decanter cleaning
1. Pour warm white vinegar in the decanter and let soak for 20 minutes.
2. Discard the vinegar, Wash and rinse the decanter thoroughly using a
soft cloth. Do not use harsh abrasive cleaners.
Dec 12, 2010 | Vacuums
I have a Bissell Proheat 2x cleaner which has worked perfectly on every occasion. Today I filled the machine as usual with water and formula and switched on, the motor ran, the lights were on and the...
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If these suggestions do not resolve the issue contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Biseell little green machine wont squirt water out
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
May 22, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
Not putting out water
Here's some trouble shooting tips that will help you figure out what's wrong with your Bissell Little Green Machine, and why the water won't spray out. You didn't mention how old the machine was, but if the machine is brand new, and you've never used this before, then you'll need to prime the machine for the first time.
To prime the Little Green Machine, remove the hose after filling the clean water tank, and press and hold the trigger on the hose for approximately 45 seconds. This will prime the pump, and get the water flowing.
If the machine is older, and you've already been using it, here's some other troubleshooting tips that you can do to try and fix the machine:
Step 1. Fill the clean water solution tank with water, and remove it from the machine. With the tank removed, press the piston at the end of the tank that fits into the machine. The piston is the spring loaded part in the top of the water tank that is pressed upwards when the trigger is squeezed, which in turn releases water into the machine. Press the piston inwards with your finger and see if water comes out.
Step 2. If water is released from the tank when you push the piston inwards, then your piston and cap assembly are fine. Next unscrew the cap to the clean water tank and make sure that the o-ring is present. This is the rubber ring that rests in between the cap and the tank.
Step 3. If your o-ring is not there, you'll need to purchase a new a new o-ring and replace it. If the o-ring is present, screw the cap back onto the tank. Inspect the receiver to make sure there is no debris blocking it. The receiver is the part on the machine that the tank sits on top of. If you see debris here, remove any debris that could be obstructing the tanks piston.
Step 4. After checking these three things, refill the tank with water, reinsert back into the machine and test to see if the water now comes out. If the water does not come out, move on to step 5.
Step 5. Unscrew the two screws on the handle of the hose, and remove the cover that the two screws secure.
Step 6. After removing the hose cover, inspect the hose that connects to the trigger assembly for blockages:
Step 7. If blockages are found, remove the tube from the trigger, and blow through the hose to remove any blockages, and reinstall the tube back onto the trigger.
Step 8. Reinstall the trigger assembly so that the metal spring's curved side is facing down so that it touches the trigger valve:
Step 8. After reassembling the hose, turn the machine on again and try spraying the hose again.
If none of these solutions fixed your machine, this most likely indicates that you need to replace your pump. The pump is the internal part that takes the water from the tank, through the hose, and finally sprays it out. The pump replacement is a moderately difficult repair, but if you'd like me to walk you through it, I'd be more then happy to do so.
Please feel free to ask any follow up questions, or let me know if you'd like for me to show you how to replace the pump. I'm always more then happy to answer any question that you may have.
If you found this helpful, please kindly rate my repair helpful so that other Fixya users with the same problem can easily find this solution. By rating the repair you are also encouraging repair professionals to continue posting free repairs. Thanks in advance,
Chris J.
GoVacuum.com
Apr 09, 2010 | Bissell 1400 Little Green Pro Canister...
Bissell 9200T
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Nov 24, 2009 | Bissell 9200 Upright Vacuum
My Scooba floor cleaner "check tank" light stays on even after it's refilled and everything cleaned but still will not work. It just keeps beeping at me when I try to start it. How do I reset it or get...
Flush out the solution valve with water (aka "prime the pump"). Use water, not just air, because water will clear any obstructions that may be in the lines. Also, rinse your tank through the four ports on the *underside*-- one round, two oval, one large and curved, all four in a row. Rinse them really thoroughly with warm water, then refill the tank and try the Scooba again. If it doesn't work, call us: 1-877-855-8593.
Aug 16, 2009 | iRobot 5800 Scooba Vacuum
It keeps telling me check tank
Prime Scooba's pump, as described here, but use water instead of air to prime the pump. Water is more effective. You'll have a little puddle under the robot if you've been successful.
Then rinse the tank through all four ports on the underside-- one round, two oval, one large and curved. All four are in a row at the bottom of the transparent area. You'll probably dislodge some clots of debris and sediment. Then refill the tank and run the robot. That ought to do it. If it doesn't, call customer support at 1-877-855-8593.
May 28, 2009 | iRobot 5800 Scooba Vacuum
Pump prime lost
After further examination of the pump I re-installed it in the machine and removed the inlet hose from the mixer valve body and placed the end in a shallow pan of water. I turned the machine on and the pimp picked up the water from the pan and pumped without failure for several minutes as I had the pump output refilling the same pan.
If I take the end of the inlet hose out of the pan for only a couple of seconds, the pump loses prime and will not recover until I remove the vacuum hose from the pump. Upon replacing the vacuum hose the pump primes and begins working.
At that point I suspected an air leak at the base of the water tank or somewhere in the mixer valve assembly. I then took the hose off of the tank fitting in the base and placed the end of the hose in the pan of water. Again, the pump performed without any problem. Therefore, I assume I have an air leak at the base of the tank where the tank connects to the machine.
I will explore this further and provide you with additional info as I make progress
Jan 06, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Won't release shampoo
If your floor cleaner doesn't spray, chances are the heater unit is clogged. It is easy to fix if you have a few simple tools and are mechanically inclined.
Steps to fix:
- The heater unit is located inside the body of the machine, behind the power/heater switches. Remove 6 screws and split the case open.
- The silver metal "box" inside is the heater unit. Take note of how the hoses and wires are connected. Better yet, take a digital photo for reference.
- Remove the wires and hoses.
- Take the box to a work bench, and unscrew the 6 or 7 screws that hold on the lid. Don't lose the red washers that are found on the inside of the box that keep water from leaking out of the screw holes
- You'll see a "maze" where the water runs around to get heated up. Clear this of all debris. The inlet and/or outlet ports may also be clogged. I used an appropriate sized drill bit mounted on an electric screwdriver to carefully "drill" out the clogs. Make sure all the debris has been removed. I used an electric screwdriver because my 18v DeWalt hammer drill would have been overkill :)
- Reassemble to box
- Rewire and plumb the box according to your notes or reference photo.
- Put the machine back together.
Doing this saved me a $85 repair and took 30 minutes. My machine now works perfectly.
Sep 04, 2006 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
545 people viewed this question
Top Saeco Vacuums Experts
Are you a Saeco Vacuum Expert? Answer questions, earn points and help others
