Question about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
I have a fairly older model Roper....lately it has been freezing up, then rapidly defrosting in the freezer. Also the Refridgerator section stays like warm....I have been told that the defrost timer is the likely cause. What is your opinion?
  • Angee
    Angee Dec 30, 2008
    Turns Out the defrost terminator was exactly what it was. A friend came over and told me right away what it was. But thanks for the advice....So far you ( an Apprentice) told me correctly on the first try!
  • 242 Answers
It may be the timer and it also may be the defrost terminator they are both common repairs. the terminator is in the freezer section behind the back panel. It is a small 1"round part with 2 or 3 wires going to it and it clips on the evaporator tubing at the top. both are not much money to replace and it would be worth replacing both parts for future problems.
Posted on Dec 30, 2008
Roper refrigerator warms and freezes
More than likely, you have a failed component in the defrost system. Call a good, reputable, service company. You do not need to replace this refrigerator.
Oct 01, 2014 | Whirlpool Refrigerators
Several times now my freezer & refrig. stopped working. Ice buildup on back of freezer wall. Especially if there is content in it. The icemaker I think was spilling water down the back (missing the...
Sounds like one or more of you defrost coils behind the back wall have gone bad...
You have to purchase the correct coil set for that model, remove the back wall, replace them and put the back cover back in place after emptying the entire contents of the freezer...
Most non HVAC people would prefer a repairman to do it.
Mar 09, 2014 | Kenmore Top Freezer Refrigerator
The refridgerator compartment is freezing all the food
What is the complete model number list in the refrigerator section?
Oct 11, 2013 | Samsung RFG299AARS Stainless Steel (285 cu...
Cold air only in freezer. no cold air in refridgerator section. the freezer is cold but not freezing.
This sounds like a classic case of defrost system failure, the coil in the freezer is iced up - freezer will run at 32 fridge around 55. turn off unit, get heat gun, manually defrost unit(be careful!). either your timer or defrost heater assembly has failed, if you de ice coil unit will work until you can get a service person to diagnose bad part and replace
Jun 22, 2011 | KitchenAid Refrigerators
I have an older side by side GE refridgerator model number TFXC222J. The freezer section is working but the fridge side is not cooling. light works.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | GE Refrigerators
Freezer not working but refridgerator section ok. this is a sub zero unit
It is a defrost problem since the ice that freezes on the freezer coils
is not being melted by the defrost system.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
 Its best handled by a Technician butyou could possibly do it by taking your model number to the nearest appliance parts store  and asking for the parts.  They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref  The parts store will have info  Also check evaporator fan in freezer If this was helpful please rate me
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net"
Sep 05, 2010 | Sub-Zero Bottom Freezer Refrigerator
Refridgerator is warm, freezer is freezing
Defrost problem. Most likely the defrost heater or defrost thermostat.
Jul 02, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Refridgerator not staying cold
hi, have you recently moved it? could be that gas is leaking.
Jan 13, 2008 | GE GSS25JEMWW Side by Side
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
93 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
