Question about Dryers
Electric dryer idle 10 yrs can I plug in and use?
Have a White Westinghouse electric dryer that has been standing idle for about 10 years, is there anything I should do to it before plugging in and starting?
I have no manual or diagrams
  • 3,463 Answers
Try turning the drum by hand, if it feels free and turns, then there should not be problem
Good luck.
Please leave feedback.
Posted on Nov 30, 2008
My whitewestinghouse dryer trumble but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 27, 2011 | Westinghouse Industrial Plus White-...
I have a white-westinghouse electric dryer and it stoped heating up. It still tumbles just with no heat.
In the back of the dryer you will find a high limit mounted to the element housing sometimes they can be reset and sometimes they just have to be replaced.They can be tested with a meter.or you can jump them out with a wire to test them .this would happen if you had a plugged vent.
Nov 24, 2010 | Westinghouse Industrial Plus White-...
Dryer has power - we can hear the timer ticking and the light comes on when the door is opened, but when we push the start button nothing happens model # leq9558ko 8 yrs old electric
does the light close when the door is closed??? poosible that the door switch has gone bad. or a bad thermal fuse behind the unit is also a common culprit of this.. its a white thermostat on back of unit behind the panel (-----------------------) approx this long ad white,,
Oct 13, 2010 | Whirlpool LEQ9858P Electric Dryer
Whirlpool ler7646EQI Dryer runs for 5-10 seconds
sounds like u have a bad overheat sensor on the back on the electric strip housing and on fan housing they are round they are very cheap just take them off and replace both of them and that should fix your problem
Feb 25, 2010 | Whirlpool LER4634J Electric Dryer
Grinding noise in drum at rear
if your slides went bad, theres a good chance your drum was out of alignment it probably gotr worn on the back side and is now gringing when in the right position......
the good part here is the tumbler carries a ten year warrenty
Sep 26, 2009 | Maytag MDE308DAYW Electric Dryer
MY 4 year old neptund dryer just quit, element is ok, un-plugged for 5 min, no help, can you help, Thank you
You have a bad thermal fuse (the white piece located on top of the elemant ) After replaceing , check the vent hose for kinks or lint blockage .
Jul 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Elkectric dryer won't start
to put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
LOUD HUM NOISE
check bearings or shock absorber.
Feb 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Kenmore catalyst electric dryer. about 3 yrs old.
You may only be receiving 110 volts, instead of the 240 volts needed to operate. (Thus, only the light coming on)
Did you reset the dryer circuit breakers?
Are you receiving 240v to the plug?
-Chad
Jan 21, 2009 | Kenmore 659 Electric Dryer
New kenmore dryer, set up right from box, wont turn on
call Sears your dryer is guaranteed for 1 year, parts and labor
Jan 18, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
66 people viewed this question
Top Dryers Experts
Marvin
Marvin
