SAMTRON 77V 17" CRT Monitor Logo
Posted on Nov 30, 2008
I want to adjust width of page on screen. I do not have any instructions. My on screen box Control Lock says locked. I will appreciate your help. Irving
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Nov 30, 2008
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
79231
Points
69
Go to your desktop and right click and choose personalize then click display settings and changeit
Whirlpool Sixth Sense American fridge freezer child lock.
This has already been answered on Fixya. There is also a video and a copy of your manual. Press and hold the Lock button for 3 seconds.
Or
Child Lock (Water / ice dispenser lock) To lock/unlock the water/ice dispenser and related buttons, press the "Ice mode" and "Light" buttons at the same time until the symbol is displayed and the acoustic signal sounds.
SOLVED: Whirlpool 6th sense fridge freezer electronic - Fixya
https://www.fixya.com > support > t24825843-whirlpo...
Nov 14, 2019 - Emma: The lock and unlock feature is accomplished by holding the lock button for 3 seconds, and you will see a count down number just above it that ...
SOLVED: Cannot unlock my whirlpool fridge - Fixya
Nov 19, 2019
unlock whirlpool fridge Questions & Answers (with Pictures)
Nov 21, 2019
How do you put child lock on a whirpool aqua 6th sense.. - Fixya
Mar 6, 2011
Whirlpool 6 sense American fridge freezer child lock - Fixya
Mar 13, 2022
More results from www.fixya.com
People also ask
How do I lock my Whirlpool Sixth Sense refrigerator?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> How do you unlock a Whirlpool American fridge freezer?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> How do I turn off Child Lock on my fridge?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> How does Child Lock work on a fridge?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> Feedback
Using the Control Lock Feature - Product Help ' Whirlpool
https://producthelp.whirlpool.com > ... > Tips and Tricks
Jun 15, 2020 - The dispenser can be turned off for easy cleaning or to avoid unintentional dispensing by small children and pets. NOTE: The lock feature does ...
How to use the control lock on your refrigerator - YouTube
https://www.youtube.com > watch
PREVIEW
0:52 How to use the control lock on your refrigerator For additional product tips and troubleshooting please visit ...
YouTube · W Service · Jul 15, 2019
Missing: sense ‎' Must include: sense
QUICK START GUIDE - Whirlpool Docs
https://docs.whirlpool.eu > _doc
PDF
Use this function to chill drinks inside the freezer ... (Sixth Sense Function) ... The "Child Safety", "Key Lock" or "Ice/water dispenser lock".
How do you adjust or center a needle?? Baby lock Quest Plus
ManualsLib has the manual for the BabyLock Quest Plus (BLQ2-PL) here: https://www.manualslib.com/manual/537167/Baby-Lock-Quest-Plus-Blq2-Pl.html#product-Quest%20PLUS%20BLQ2-PL . The needle stop position button is the top button above the reverse button. To adjust the needle position for straight stitches, you press the stitch width button on the sewing machine. Pressing the - button will move the needle to the left; pressing the + button moves it to the right. The machine should start with the needle centered. See page 49 of the manual for the pictures of the machine button and the stitches that allow for needle position changes. To avoid damage, you can't move the needle left or right for most zig-zag stitches. The needle will move to the left and right from the center based on the desired stitch width.
I hope this helps. If your sewing machine needle isn't centering the needle correctly when you turn on the machine, it may need to be serviced.
When i load a website the display doesnt go up to top of screen. 10 cms missed at top and bottom 10cms cut off
hi Andrew.
not sure but have you tried to open the page up by going to the top right hand side of the page,you will see three different marks,one is sign like this,-.the other one is like two very small boxes.the other one is an .x.
the one you need to click on is the two little boxes this should open your page up to fill your screen.
How to Make Web page fit screen? To apply fit to width to the webpage you are viewing, go to the right of the status bar, and click the arrow next to the zoom slider. Select "Fit to Width" and the page will be adjusted accordingly. To return to normal display mode and turn off fit to width, select this option again.
or read up on this link.
http://help.opera.com/Windows/12.10/en/fittowidth.html
or this one.
How do make web page fit the screen It is now too large
2006 GMC Envoy: I tested all of the fuses and all of them check out but my power locks, cabin lighting, dash panel lights, etc. aren't working.
Which fuse box ? Do you know what a DDM -is ? Driver door module . Do you have any idea what all is involved in making these thing's you have listed work ? A lot more then a fuse , there could be DTC'S - diagnostic trouble codes stored in the principal Control module ,the BCM , That could save a tech. valubale time in diagnoising this problem !
Door Lock System Components
The power door lock system consists of the following components:
• Driver Door Module (DDM)
• Passenger Door Module (PDM)
• Liftgate Module (LGM)
• Door lock relay
• Door unlock relay
• Body Control Module (BCM)
• Reversible door lock actuators in each of the doors
• LR/RR LOCKS 10A fuse (relay supply voltage)
• Door lock switches in driver and passenger doors (switches are integral components to the DDM and PDM)
Did you know there is a fuse box in the rear of the vehicle ?
Fuse Block - Rear
Beneath the left rear seat
The inside lights are also controlled by the BCM , and the fuse's are also located in the rear fuse box .
The body control module (BCM) directly sends a 5-volt reference voltage to the instrument panel (I/P) dimmer switch which is then adjusted based on the I/P dimmer switch position and returned as a low reference and a signal to the BCM. The BCM uses this signal to directly control the desired level of instrument panel illumination lamp intensity.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC B2620 Display Dimming Pulse Width Modulation (PWM) Input Circuit. There are several DTC'S that can set !
DTC B3801 Passenger Compartment Lamp Request Circuit
DTC B2610 Passenger Compartment Dimming 1 Circuit plus others for power locks .
Thank You Uncle Sam
How to adjust the needle when using the zig zag mode
All machines are similar.
Push the zigzag control to begin: To control the zigzag appearance the width and length have to be changed.
Width: This is to control the width just as it says; wide.
Length: This is the length of a straight stitch. As it is made longer the length of the zigzag from one tip to the next tip will lengthen. If it is made shorter the tip to tip measurement will shorten.
This is easy to learn. Give it a try on old material.
How do i use the lock on the quiet partnerIV so that my grandchild does not tamper with it?
Here is a direct link to the User's Manual for a Whirlpool GU1500:
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208283509.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 16 of the manual for detailed instructions and illustrations on how to operate the CONTROL LOCK feature.
Basically it reads as follows:
To turn control lock ON, press and hold the AIR DRY button for 4 seconds until the CONTROL LOCK light glows.
To turn control lock OFF, press and hold the AIR DRY button for 4 seconds until the CONTROL LOCK light turns off.
I hope that was helpful to you, good luck and take care.
Joe.
Jun 20, 2011 • Dishwashers
1helpful
2answers
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
14helpful
Kenmore front loader Model 48102 will not start
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
E173FP 17" LCD Monitor Problem
I have the same problem. It seems like a virus to me, but my anti-virus doesn't find anything. I went to the main menu on the moniter and changed the display time to five seconds and locked the OSD display. Now all the appears is a smaller box showing a lock which goes out in five seconds. It is still annoying, but less intrusive then before. Hopefully, some one will determine a permanent fix for this problem.
Top Samtron Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
