Question about GE WJSR2070B Top Load Washer
Belt replacement on GE top loader WJSE4150B2WW
Need to know how to replace the belt on this model.
  • Anonymous Mar 20, 2014
    We got it free. Previous owner said it works but won't spin out all the water. It looks like new,so we figured it just needs the belt replaced. Belt is fine, but doesn't turn on. (Matching dryer works great.)
  • 1,543 Answers
Your post shows a model WJSR2070B and a model WJSE4150B2WW but in this case the procedure is the same. Use a putty knife to push in the clips at the top seam of the front panel, where the front meets the top, about two inches in from each side. Tilt front panel forward and lift off bottom pegs. Loosen the four nuts holding the motor with a 3/8 inch wrench so you can push the motor back a bit. Take old belt off. Install new belt (WH1X2026), putting belt around motor pulley, part way on big pulley, then turning big pulley by hand to ride it onto the big pulley. Use one hand to pull motor toward you to put a little tension on the belt as you tighten the four nuts under the motor.
Posted on Nov 30, 2008
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
My ge top loader does evert hung but spin.I checked and the belt is good and intact but still want spin. Model GTWN5550DWW.
can you hear a ticking when you open the lid ( or get a strong magnet and in the top right corner the is a plaster part put it on there and see if it well spine out.) if it still will not you need to buy this part
Washer lid switch assemblyPart #: WH12X10334 there is a vido on youtub on how to replace it if you need help.
Aug 31, 2015 | GE Washing Machines
Model WJSE4150B2WW ser# AF171808G GE washer agitates but won't spin with front cover off motor turns belt in the right direction for just an instant and then stops interior basket can be turned...
When spinning the motor freezes up and will not spin. I released the motor and took off the belt off and the motor ran fine. However the pulley that the belt is also on will not spin the proper direction, only backwards.
Mar 03, 2011 | GE WJSE4150B Top Load Washer
My washing machine will not spin...
As you don't give the model, I can just give a generic reply.
Most front loaders are belt driven, and some top loaders are.
I think the main thing to look at first is the connection of the drive motor to the tub. If this is a belt - replace it and check the tensioner.
If it is a top loader using a gearbox, then the motor is likely to need either brushes or a new capacitor. Both items should be checked - so -
Belt ok? - Y= go to next question / N = Replace belt
Brushes ok Y= go to next question / N =Replace
Replace Motor Run Capacitor.
Feb 10, 2010 | Washing Machines
Looking for a belt for G.E tumble dryer, model no: TL22PG. cant see code on belt as it is shredded.
take you model number to repair shop they will know
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 09, 2009 | Dryers
GE model # WJSE4150B2WW won't fill
Try washer on warm water. If you get one or the other.You need water valve. If you get none. You may need water level switch or the hose to the switch could be plugged.
Apr 03, 2009 | GE WJSR2070B Top Load Washer
GE washer the middle part is broken model# wjse4150b2ww can you help me with the correct part and how to instal it
YOU CAN GO TO THE GE WEBSITE TO FIND THE PART YOU NEED.IF YOU ARE TALKING THE AGITATOR,YOU MIGHT BE ABLE TO FIX IT YOURSELF WITH THE PROPER TOOLS.GET BACK TO ME ON THIS.
Mar 07, 2009 | GE WJSR2070B Top Load Washer
GE WJSR2070B Top Load Washer Logo
682 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
