Question about Belkin (F5D7230-4) Router (587009)
Unsecured net work
I have a Belkin ADSL 2+ Modem with wireless G router 802.11G
part FSD7632-4, How do I secure the network.
  • 340 Answers
Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT use a wireless connection, use a cable.
Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
Click Security under Wireless menu.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
Remember to set an admin password before you close down, other vice anyone can access you router and change the setup and admin password.
/regards
Teis
Was this solution helpful? Show your Appreciation by rating it:
Posted on Nov 30, 2008
How do I put a password on my Belkin Router ADSL 7B5FOF as it is unsecured ?
To setup a wireless password/security for your Belkin router you need to use a wired computer to do the configuration settings.
1. Open a Web Browser (IE, Firefox etc.) on the wired computer.
2. In the address bar of the browser type http://192.168.2.1 and press Enter.
3. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit. (Enter your password if you have setup any.
4. Click on Security in the left hand column under Wireless.
5. Select WPA-PSK (no server) from the Security Mode section.
6. Enter your Pre-shared Key (this will be your wireless password).
7. 7. Click on Apply Changes.
Your wireless network is now secured.
Feb 11, 2011 | Belkin Basic Wireless Router
I a using cable net and not the dsl line.the net on my pc is working but when i try to connect ps3 wirelessly it show 100% signal from belkin but the internet connection fails.i have tried different...
check the wireless settings of the router .
Make sure that you are typing the correct network key if your network is secured.
May be you will need to open the ports on the router.
Click Here for more information
Jan 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Router Security Light is Blinking
I have the same symptoms. In my opinion, this is done because you turned your Belkin from a router to access point position. I did it also (issues with adsl modem/router). By manual the flashing diod means no secure device. But, without pass you can't access your Belkin. So, probably, some fault in firmaware.
Nice day.
Oct 26, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin 54
You can go to this link for the step by step way in enabling wireless security on your wireless network http://www.belkin.com/ca/support/article/?lid=enc&pid=F5D7231-4&aid=14267&scid=221
Oct 17, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Sep 01, 2008 | Belkin Modem connector (R6G064-R-50)
How do I make my Belkin ADSL Modem with wireless G Router a security enabled wireless network? Rather than unsecured.
Hi-
Reconfigure your router and put in passkeys/WEP keys, here check this link, click HERE
You can as well contact the person who setup your wireless network or call your router manufacturer support line for details on this- thanks for using fixya, pls rate solution if it helps. Thanks!
Jul 04, 2008 | Belkin Computers & Internet
Belkin Wireless Modem Router problem
well, first of all the i also have the N1 belkin wireless modem router, in order for it to connect, there has to be a wireless connection in your area for you to connect to, if any of your neighbors so have wireless you can connect to their network, but if you are not getting a conection that means no one around you has wireless or lan, the belkin wireless is not a internet provider it just extends the distance of your internal wireless. some networks may be secured as well, sometimes you can only connect to unsecured networks unless you have the name and passcode for the secured network.
May 28, 2008 | Computers & Internet
Unsecured network shows up as secure
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
RCF
May 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin (F5D7230-4) Router (587009) Logo
100 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
