Question about Rockford Fosgate 800.2 Car Audio Amplifier
Feedback with aftermarket amp on 09 murano
I istalled a hi low adapter on 09 murano and the car has pushstart no key and the subs emit a howling sound with the key off?
    Problem Solver:
  • 5 Answers
Hello, Quick question..is your amp turning off when the key is in the "off" position...If your amp is not turning off check your amp/remote wire.
Posted on Nov 30, 2008
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
2001 alero start
factory amp? So you have an aftermarket amp, a "factory" amp, an aftermarket head unit and subs? Adapter???
Feb 19, 2018 | Car Audio & Video
Can i hook up aftermarket amp if so how
yes, buy a hi/low converter like this:
http://www.ebay.com/itm/HI-LEVEL-INPUT-ADAPTER-HI-LOW-ADAPTER-AMP-INSTALLATION-/200738024366?pt=Car_Audio_Video&hash=item2ebceb2bae&vxp=mtr
that connects to a speaker you have and gives you RCA connections for you amp. follow the diagram included in your purchase of your hi/lo converter.
Nov 10, 2013 | Car Audio & Video
I have a couple of questions regarding my jl 500/1. the first question: i just transferred my amp/subs (subs are JL W3s) to a new vehicle, and the place i had install it switched the "high/low"...
ok..well theres a lot of question in there, lemme take a shot at it.
the hi/low switch explained: the hi/low switch tells the amp what signal voltage is being delivered to the amp...hi-power (4-15volts) or low-power(micro-volts). Your aftermarket head unit had what are called pre-outs (or preAmp outs) meaning the source signal (your music) is not amplified before being delivered to the amplifier...sooo...your amplifier setting for your aftermarket radio would be 'low' to tell the amp that the music source being sent to it is low-voltage.
Typically a manufacturers radio will not have pre-outs, they will be amplified by the radios internal amp to anywhere from 4volts on up, and you need to tell your jl audio amp that the source music being supplied is 'hi' voltage.
soo...of course...if you are sending 10volts to the amplifier and tell it that your sending micro-volts (low setting) your amp will over-amplify the signal and thus the overwhelming bass you experienced.
May 14, 2011 | Jl Audio 500/1 Car Audio Amplifier
Im tryin to hookup aftermarket subs but the lineout converter isnt working, it sounds like alot of treble comin outt of the subwoofers. is there anyway to find a low frequency wire to tap into for the subs
instead of finding a low frequency line to attach to your LOC (line output convertor) use the built in crossover on yours subwoofer amp or an external crossover to limit the frequency range going to the subs
May 07, 2011 | Car Audio & Video
I just purchased an Alesis QS7 on eBay. Upon receiving
The unit needs to be repaired. Since it is a thermal problem, you can likely find the bad part with circuit cooler. See if the volume control affects the loudness of the howl... If it does, probably an op-amp in the preamp before the volume control is sick. If it doesn't affect it, then the output amps are suspect. Also check the power adapter.
Mar 03, 2010 | Alesis Music
Howling noise from subwoofers
THIS MAYBE CAUSED BY HAVING THE WRONG FREQUENCY SELECTED
May 07, 2009 | Kicker CVR10 Car Subwoofer
Sub hits backwards, hi low level converter?
I ran into a similar problem installing a sustem in a Mazda RX8. He had BOSE speakers which operate at a different range. We had to purchase the Rockford 3sixty.
Apr 20, 2009 | Scosche Industries Scosche Slc4 Speaker...
Subs not as loud as they should be plz help
RCA output level and speaker level output have different voltages and currents. The problem you are describing is common to folks trying to connect an OEM dash unit to an aftermarket amp. If your amp has speaker level inputs, try wiring to those......best bet..buy a new head unit, it'll sound better...louder and cleaner.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 11, 2009 | Kicker IX404 Car Audio Amplifier
Rockford Fosgate 800.2 Car Audio Amplifier Logo
82 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
