Question about Ovens
Oven giving me a f-10 message
When trying to bake,i could turn on the oven and try to preheat it,it will heat for a lil while then it will just start beeping giving me a f-10 message. when i open the oven it is extremely hot
  • khound31 Nov 30, 2008
    it is a kenmore model number is 970.96113407
  • Barry Coates
    Barry Coates May 11, 2010
    What make and model is your oven?
  • Ovens Master
  • 3,463 Answers
Hi.
Although I am not familiar with this model, it sounds like an overheating problem to me, could be a faulty thermostat, and the error code could be a warning of this.
Sorry I can't help you further. Please leave feeedback
Posted on Nov 30, 2008
I hit the bake button on my oven and after 10 secs it says preheat and thats all that happens nothing else no heat at all
Your oven will continue to indicate that it is preheat mode until the thermostat senses the proper set temperature. If you are getting no heat then you will need to address that issue. This could be many things but the most notorious would be the heating element. Could be the control panel as well. Some ovens have a knob for preheat, bake and clean with a separate knob to adjust the temperature. Make sure both are set properly.
Regards, Tony
Apr 07, 2011 | Kenmore Ovens
When I turn my oven on to bake it goes on and starts to heat up during the preheat process. As soon as it's done with the preheat & goes to bake a #3 comes on my display and the button pas does not...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 23, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
I have a whirlpool range. During preheating the
sounds like you may have a bad bake element. try to see if the unit will get hot when set to broil. if it does then try the bake again. if you get no red hot heat from the bake element then you may need to replace it.
when an element is working properly it will heat to a red hot glow.
Jan 12, 2010 | Ovens
Preheat takes too long
does the oven bake properly when it does reach temps?
if this is a newer oven, with a hidden bake element, they do take longer to preheat so may not have any problems, just give it about 15 minutes to preheat.
if it is older and doesnt bake right, then you may have a bad bake element.
the unit will heat but wont bake right.
unplug the oven and take the bake element to your local parts house, they can check it and sell you a new one if needed.
Jan 10, 2010 | Frigidaire Ovens
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Viking oven broil keeps on
it is designed to preheat this way. after the unit cycles the red indicator light off the first time than both elements turn off. when it calls for heat again only the bake elements comes on. makes the preheating work faster.
May 05, 2008 | Viking 30" Professional Select Built-in...
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Ovens Logo
69 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
