Question about Whirlpool Dishwashers
Whirlpool dishwasher ADP 5406 start light flashes 4 times and machine doesn't start cycle. Had this fixed 6 months ago but can't remember what the technician did although I know it was very simple.
  • rigidchops Nov 30, 2008
    tried that didn't work. sure it's something to do with the water. Does anyone know what the code means?
    Genius:
  • 1,550 Answers
You need to clean the drain hose .
4 blinks indicate you have problem in drainage .
Drain lines will be clogged with dirts . So cleaning will solve your problem .
Posted on Nov 30, 2008
    Sergeant:
  • 276 Answers
Unplug the machine from the wall socket or turn the power off to the sockets. At the very bottom front of the machine is a cover held on by 4 torx screws, take this off. You'll see the white sump of the machine and the ntc sticking out of it. It has two thin blue wires going to it. It twist and pulls out. Replacement is push in and twist.
To get a replacement take the first of the two 12 digit numbers printed on the label, right hand side of the door.
or
Few things cause this, it's basically a water problem.
Take the left hand panel off, at the bottom of the plastic tank is two wire connector, pull it off, push it back on and try the machine.
If the problem persists the next thing to check is the pressure switch, take out the filter screen and you'll see the black grid in the sump of the machine, clean it out carefully, if you burst the membrane it's useless.
Try it again. If it still doesn't work, check the water hose isn't kinked.
    Sergeant:
  • 217 Answers
Unplug the machine from main power outlet then after few minutes just press the ON button and connect the wire to the outlet and check out.
  • Whirlpool Master
  • 19,396 Answers
Start unplugging the appliance for ten minutes to see if this clear the error.
  • 1 more comment
  • Ginko
    Ginko Nov 30, 2008
    4 blinks is a drainage problem.
    Clean the drain hose, and the drain lines while the appliance is unplugged, this usually solve the problem.
    If you still get the problem, the drain pump may be clogged with dirt, and must be accessed and cleaned.
    For this fault it is better to call a technician.
    Usually cleaning the drain hose fixes the 4 blinks.
  • Ginko
    Ginko Nov 30, 2008
    There is also a reset procedure to clear the blinking light in case this is a jammed control panel, in that case follow instructions here: Blinking Clean Light on Kenmore & Whirlpool Dishwashers
    Clean drain hose first.
  • Ginko
    Ginko Nov 30, 2008
    There
Start light flash 2 times on a Whirlpool ADP 6940.
Whirlpool dishwasher start light flashes 7 times repeatedly and wont start
May 24, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
My Whirlpool ADP 5406 runs for about a minute and then the light flashes four times, repeatedly. What can I do to fix this? (I can still get the machine to run its cycle by holding down the start button,...
Hi and welcome to FixYa. I am Kelly.
Usually this symptom also shows an F7 error code. You will need to remove the lower wash arm (NOTE INSTALLED POSITION) Also you will need to remove the metal grate under the wash arm tower. Inside there is a glass tube that senses debris. Clean out the sump area and wipe the glass tube clean. Reinstall everything exactly as your removed it. The installation of the lower wash arm can be fussy.
While your cleaning things also check the entire drain hose from the sump to the sink connection for kinks or obstructions. If you have an Air-Gap remove the cover, (Note again the installed position of the air gap upper plastic cap that has an internal U shaped water passage) unscrew the plastic nut in the top and check for debris inside the air gap water passage. At the sink connection be it a plumbing connection or a garbage disposal connection make sure the drain port is clear. This should stop the repeated start button routine.
Thanks for choosing FixYa,
Kelly
Nov 20, 2010 | Dishwashers
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to...
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to keep restarting it. can anyone let us know what the problem may be. Thank you
Jul 17, 2008 | Whirlpool Dishwashers
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool adp 8540 - 7 flashes
replace the control board in the console
Apr 10, 2008 | Dishwashers
Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Mar 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
135 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
