Question about Sony DAV-IS10 System
No sound when viewing normal TV broadcasts
Just got the system and when switched to TV or Cable mode, watching TV broadcasts, no sound is herd. I have HDMI cable between stytem and HD TV.
  • mikebolt Dec 24, 2008
    My problem is very similar I think. I'm trying to use the "TV in" rca jacks with the "TV" function setting to connect a cd changer unit to our DAV-IS10 system.
    I know that the audio output from cd changer is good, but get no sound output thru the DAV-IS10 system. The manual implies that this should work. Any ideas???
    mikeb at
  • 124 Answers
You need to have either the red/white audio cable connected from TV out to cinema system in or a optical or coaxial cable tv out to cinema in.
Posted on Dec 12, 2008
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more:
Jul 25, 2013 | Seagate 1TB GoFlex Cinema Multimedia Drive...
I installed a HDMI cable and an Optical cable to whatch movies and shows from my LG HD LCD TV, but nothing seems to work. The stereo is also a LG LHB336 system. Which is compatible with the TV. We were...
Hi,Even though you have done some cabling already,for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 24, 2011 | LG 42LC2D 42 in. LCD HDTV
Cant get hd sound through home theatre system
Hi,here is my simple solution...
to listen your TV on your
Panasonic Home Theater System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
Panasonic Home Theater System RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
Panasonic Home Theater System Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
Jun 26, 2011 | Panasonic Home Theater System System
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
How to Hook Up a Receiver to an HDTV
Things You'll Need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Audio Players & Recorders
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
First you have to activate the HDMI audio option in your Sony suround system options so as to activate it. Please try this and then tell me what happens.
Nov 25, 2008 | Microsoft Xbox 360 Elite Console
Rookie to Sound System
are u runing tv throw system and video ? with hdmi then back up to tv hdmi best to run hdmi cable from dvdplaye rto tv direct ok then dish box ect cable hdmi out direct also to tv then use optical out put digital on tv outto sterio digital in on back ok for tru 5.1 best way to do this is this way
Jan 30, 2008 | LG LHT734 System
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Sony DAV-IS10 System Logo
182 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
