Question about Dell Inspiron E1505 Notebook
Value creation failure
Pls, after installing the incredibles theme in my computer, i tried hibernating it and what i saw was - value creation failure 'line 165' and later i foun out i cant turn my laptop off normally again as i now have to physically press the emergency turn off button on the computer b4 it goes offf. then when i put it on again it shows the same message, b4 locking wtndows off, i would now have to unlock ,b4 it finally comes on. when its finally on, it acts very normal . till i try shutin down again. i ve tried restoring it to an earlier date, but no way. pls help
    President:
  • 2,961 Answers
Firstly, check that the Theme was'nt a virus or a peice of malware. If you have done a system restore and it's not worked the system32 files may be corrupt,so start the system in safemode (F8 on startup)turn off System restore, run a virus and spyware scan and run a search for files with 'Incredibles' in it. Restart pc in normal mode then go to control panel>power options and look in all tabs to ensure your hibernation/off settings are correct.
Posted on Jan 22, 2007
SOURCE:
"parser error: value creation failed
To get rid of this error you can switch back to a Microsoft Theme or go to /WINDOWS/Resources/Themes/ and rename the shell folder to the name of the visual style shown in the appearance tab.
If that doesn't help and it should, more info here: http://www.jsifaq.com/subo/tip7400/rh7458.htm
This is problem with C:\WINDOWS\System32\Shellstyle.dll
Copy the shellstyle.dll file from a working machine of same service pack level to your System32 folder..
Feb 05, 2011 | Microsoft Computers & Internet
Whenever i click the add/remove icon,value creation failed at line 451displays
try downloading a program called CCleaner at http://www.piriform.com/. This program is great for cleaning your computer and includes an Uninstall Tool to remove programs that you no longer use or want.
Sep 05, 2010 | Microsoft Windows XP Professional
Where can i find free themes for nokia 3110c .. can you pls. give me some sites where can i download themes.
Go to this Link and select "Wallpapers". Select the theme you want to install in your mobile.
You get two options to download that wallpaper. You can either download it to your computer and later can transfer it to your Nokia 3110 mobile via USB cable, or you can choose Mobile Web by which you will have to go to a link from your mobile and will have to enter a code and the respective wallpaper will be installed in your mobile.
Later you can apply it to your mobile phone.
Thanks for using Fixya.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 01, 2010 | Nokia 3110 Cellular Phone
Hello i have problem to install my new mouse i just only buy it yesterday but i have an error during installation. My driver installation file for this device is misssing a necessary entry because the inf...
What OS are you running? What type of mouse (USB or PS2)? The last time I saw this error, it said the file was for Win95 release B (95 OSR2.1) or later and the mouse was a USB mouse with a USB to PS2 adapter. Since that computer was running Win95a, the mouse didn't work with the computer since OS had no USB support.
If you have Win95, check your OS version number. If it is the later version, you need to enable the USB support. The patch is called usbsupp.exe and should be on the setup disc in the Other folder (<CD-drive>:\Other\USB Folder). Load the disc and double click on the exe. It may be posted on line somewhere but I am not sure of any valid versions (no malware payload).
If you have an earlier version of Win95, only a PS2 mouse will work.
I hope this helps.
Jun 28, 2010 | Computers & Internet
How I can enable Hibernate and Stand By button? I have windows XP SP3
You can enable hibernation in Windows XP by following the steps below.
1. Type powercfg.cpl in the Run window. To get the Run window press Win key + R. Or, you can go to the control panel and click on Power Options.
2. Find the Hibernate tab and click on it. Check the Enable Hibernation check box. In case its necessary, free up some space on you C: drive by running disk cleanup or your favorite system cleanup utility.
3. Now you can hibernate your system by clicking on the Start button and then on the Turn Off Computer (or Turn Off ). You'll see three standard options, Standby, Turn Off And Restart.
Hold Shift key and you'll see the Standby button turns into Hibernate button. Click to hibernate (Still holding the Shift key).
4. Optionally you can do this: Create a batch file for hibernating, and put it on you desktop. Every time you need to hibernate your system, just double click this file from your desktop. To do this, First Open up Notepad, type the following line in it.
%windir%\system32\rundll32.exe powrprof.dll,SetSuspendState Hibernate
Then save the file as, something.bat onto your desktop. Run this batch file to hib
Or you can
manually put your computer into hibernation:
1)Open Power Options in Control Panel.
2)Click the Hibernate tab, and then select the Enable hibernate support check box.
If the Hibernate tab is not available, your computer does not support this feature.
3)Click OK to close the Power Options dialog box.
4)Click Start, and then click Shut Down. In the What do you want the computer to do drop-down list, click Hibernate.
To automatically put your computer into hibernation:
2)Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply.
If the Hibernate tab is unavailable, your computer does not support this feature.
3)Click the APM tab, click Enable Advanced Power Management support, and then click Apply.
4)Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Thanks
Sep 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Click to dvd theme creation
email me at dswenk@live.com and tell what program you are useing for DVD creation, and what Graphic programs you have on your machine....
I have done many Computer Graphics along with making Themes for Websites, DVDs, CDs, Skins for Programs, ect.....
Mar 21, 2009 | Sony VAIO Digital Studio PCV-RZ22G PC...
How to install themes on moto razr z3 mobile ?pls
hi,
click this site and it will connect you to manual installation of our favorite themes in your mobile.
http://www.66mobile.com/how-to-install-themes-skins-on-motorola-phones.html
thanks.
please rate our answer.
Feb 19, 2009 | Cell Phones
Video preview failure
i already install the driver of my a4 625 but when i open it there is a message that there is no capture hardware.pls help me it my problem
Dec 12, 2008 | A4tech PK5
Value creation failed at line 521
Hello there.
This error is usually the effect of a custom theme having problems. To verify this please do the following:
1. Open Control Panel.
2. Open the Display applet.
3. Select the Themes tab.
4. In the Theme drop-down box, select Windows XP.
5. Press Apply and OK.
Hope this helps.
Apr 13, 2008 | Microsoft Windows XP Home Edition
Dell Inspiron E1505 Notebook Logo
77 people viewed this question
Clive
Clive
Alun Cox
