Question about Sony CDX-M8815X CD/Receiver/MP3 System
I have a CDX-M8815X unit only works with remote commander
Buttons do nothing and there is no display on the operation side of the unit. Tried resetting everything....nothing. Tried actions in troubleshooting guide "The display disappears from/does not appear in the display window.......nothing. Also cannot eject my CD. Main display side buttons work...ie. can open unit to the operation side but from there....nothing
Any info would be appreciated....Thanks
  • 111 Answers
The problem is the ribbon cable,the one connects the face to the main board,if you live in USA you can order it from pacparts.com or sony.com.
For replace it you will need to open the unit and open the face by moving manually the gears,then remove the side screws of the face and remove face,then remove the cd mech. you will see the ribbon connector.Just replaced and put everthing back togheter.
Good luck
Posted on Dec 01, 2008
The display on this unit went out. I cant see any text or numbers at all when it is on, or off. how can this be fixed?
does the unit still function as in does it make any noises if so the ribbon between the face and unit is broken you will have to order it from sony there about $40 depends on the model
Apr 26, 2010 | Sony CDX-M8815X CD Player
Sony CDX-M800 inside face (buttons and display) do not work
you more than likely have a bad flexible cable(s).
Dec 23, 2009 | Sony CDX-M800 CD Player
Operation buttons and sub display are failing
go to ebay and type in the model number of the unit and it will bring up some part that can fix the problem. i had the same problem and i just ordered the part. its actually a ribbon connector. im sure you just open up the radio and take the old one out and connect the new one up. this seems to be a common problem with this unit. the ribbon just starts to tear, and as it tears, you will start to lose functions on the stereo. i happen to like this stereo, so i decided to repair it. good luck with yours.
david
May 31, 2009 | Sony CDX-M630 CD Player
Sony CDX M730 won't operate manually. Remote operates unit fine.
if it has a fold down face the ribbon cable that sends power to the led facesheild may be broken or just malfunctioning
Jan 02, 2009 | Sony CDX-M730 CD Player
Sony cd changer cdx-646...no card remote commander to release security code
Hi the CDX-646 is not coded. it must be your head unit thats coded.what model is the head unit?
you can get your code @ www.carradiocode.co.uk
for 33.50 if its one of the models listed you will nedd the remote comander tho.
Mark
www.blueice-electronics.co.uk
Feb 24, 2008 | Sony CDX-646 10-Disc CD Changer
Front Display Panel Not Responding
the cable is torn that connects the lcd to the headunit.
Jul 01, 2007 | Sony CDX-M8800 CD Player
Illumination not working when faceplate is open.
Wire braid out to the faceplate has got a parcially broken wire on it. Sony referes to it as a flexible circuit board. Part can be purchased from sony directly, an on a one to 10 scale to replace about a five.But it does involve taking your radio apart. So if you are handy at electronics. you can look it over. If you have doubts let a professional do it.
Jan 05, 2007 | Sony CDX-M8815X CD Player
Sony CDX M8800 Front Panel Problem
u need 2 replace the ribbon that goes to the panel to the unit.i had the same problem with mine then i went on to ebay and found the ribbon there (cdx-m8800 repair kit)hope this helps
Dec 17, 2006 | Sony CDX-M8800 CD Player
My source button will close my face plate
Hi, can't find man for m8815x, but got for m8805x. First I'll gamble that your close button is within 3/4 of an inch of the voldn, it's possible that when you press the close button you're also making the voldn button. could be due to impact Check that the close and voldn buttons 'feel' right. If the unit is very new, it could be a manufacturing fault. Bit of cruft inside, or a bad silkscreen on buttons, causing a bridge in the button matrix. Try rolling your finger left-right or up-down over the close button to see if it doesn't do the voldn every time.
Dec 15, 2006 | Sony CDX-M8815X CD/Receiver/MP3 System
Sony CDX-M8815X CD/Receiver/MP3 System Logo
177 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
