Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
I have a double door GE refrigerator,I painted it black but the panal where the ice and water come out is still white,how can I replace it
  • sharonlbrune Dec 31, 2008
    I would like to change the color of my white refrigerator. I don't know if the panels can be changed or if it can be painted. If I paint it I will have the same problem as mcalvin161.
    Sergeant:
    Champion:
  • 324 Answers
Go to sears.com parts use your model # with a b at the end not a w
part # should be 67006288 and 67006291
Posted on Nov 30, 2008
I have a Hotpoint HSS25GFPH white side by side refrigerator. We're buying a new house with black appliances. I don't want to buy a new refrigerator so I'm contemplating painting the whit
Paint? unless you have a spray booth, and are good at such things, I would avoid that...
I would go with a vinyl or similar adhesive sticker. There are companies that do whole fridge front stickers with artwork/nature pictures etc. Google "refrigerator stickers" and you might find one that will do, just plain black.
Apr 24, 2012 | Hotpoint HSS25GFP Side by Side...
Icing up where ice cubes drop from door
door to ice shute not closing tight replace with door kit . for your model the newer model uses a better seal and a stronger spring . .. mm
Aug 11, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
I have a GE Profile refrigerator Model # PSC23MGTC it has an Artica Water & Ice dispenser on the freezer door, the ice will not come out, and noew the water works only when it wants to, I think I need...
Cut and paste this Factory Service manual for your refrigerator.
The troubleshooting guide will help locate the bad part.
http://appliancejunk.com/ge/refrigerator/31-9072.pdf
Aug 08, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Have a GE hot point HSS25GFTABB, removed doors to put inside house after a move and the ice maker works, but when you fill with water, it runs down the line dripping at the bottom of left door
Inspect the line crefully at the bottom of the door where it connects to the cabinet supply. The line may have been damaged when and if the doors were removed.
HOPEFULLY it is a small nick in the tubing casuing the water leak, and not the line inside the freezer door as the water line is foamed into the door and the entire door would have to be replaced to resolve an internal leak.
The coupler at the door connection is a push-lock syle coupler and to seperate the line you need to press the white collar into the blue barrel connector to relese the tension.
Jun 14, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
Have GE side-by-side and am replacing white door panels and would like to replace white ice/water dispenserwith black one. GE no longer makes the parts. Can you locate? Refrigerator model is ZISW42EMD. ...
I've replaced this part in 5 minutes on my side by side without removing the door or unplugging electrical wires.
1- Pull off the vent grille at the bottom of the fridge.
2- At the lower left, disconnect the tube that is coming from the freezer door.
3- Push the LOCK button to prevent water from comming on to your face. Remove the screw at the water spout.
4- Pull the water spout and the connected black hose out of the door.
5- Thread the new hose and spout through the door, then reconnect at top and bottom.
Project DONE!
Provided i am talking about an older version ,, ?
Fame !
May 18, 2009 | Refrigerators
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE no water through door
I would look for a clogged strainer on the incoming water line, or a chunk of mineral buildup somewhere in the door water circuit.
This assuming of course, that water came through the line when you replaced the water valve.
Jan 21, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
GE side by side with ice and water in door
This is a problem with my GE side by side also. It only happens occassionally and there doesn't seem to be any fix. I've had GE repair service here more than once. It seems that the insulation in the door is insufficient to keep the water line from freezing up. Small wonder GE is part of this awful financial mess.
Dec 17, 2008 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
54 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
